| This is a discussion on BT Tech Strut Tower Brace install pictures and Text within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello Everyone, I am back after a much needed holiday break!! From all of the strut braces we have sold, ... |
| | LinkBack (8) | Thread Tools |
| | #81 | |
| Senior Member Join Date: Apr 2005 Location: South Florida
Friends: 3 | Hello Everyone, I am back after a much needed holiday break!! From all of the strut braces we have sold, less than 3 of them had an issue with the clearance. I sent CBar a replacement several weeks ago and have not heard back from him. I designed our strut brace so that there is adequate clearance for the brake resevoir and cooling fluid. There are some minor variances with cars but 99 percent of those out there have no clearence issues. The strut brace makes the car feel a lot more stable both at high speeds and when cornering. Quote:
__________________ Thanks!! Brian BT Tech 305-652-3115 Order our BT Tech stiffening plate here: http://priuschat.com/shop/product_in...products_id/21 Order our BT Tech skid plate here: http://priuschat.com/shop/product_in...products_id/99 Order our BT Tech strut tower brace here: http://priuschat.com/shop/product_in...products_id/98 | |
| | #82 |
| Senior Member Join Date: Sep 2007 Location: Charlotte, NC
My Car: 2006 Prius Model: Package: #7 Thanks: 10
Friends: 0 | Brian, I received the replacement a few weeks ago but was out of the country for a while then traveling a bunch for business. I haven't even taken it out of the box it was shipped in yet. I probably need to do that and compare it to the one that doesn't fit to see if the new one is any better. I still plan on modifying it to fit because I feel it does improve performance but since you can't remove the inverter coolant cap with it on I don't have one currently installed. Haven't decided if we are going to make new strut mounts for the brace itself or simply make a new brace with a better bend profile to get it to fit. Either way I will let you know how it ends up. Sorry for taken so long to give an update. Chris |
| | #83 | |
Friends: 3 | No problem Chris... I installed your brace to test fittment so please let me know what you find and report back. Quote:
| | #84 |
| Member Join Date: Aug 2005 Location: SFV
Friends: 0 | Brian I just installed the brace, your instructions were great only took about 40 minutes to install. I can get to the brake reservoir, just a tight squeeze Everything where else no clearance problems. I just drove the car around the streets and it seems to ride better. Big test tomorrow when I drive to work. I also installed a TRD rear sway bar and it works great. Car also has the stiffener and the skid plate. I think this enough. Thanks again for all of your support. |
| | #85 | |
Friends: 3 | Thanks for your most informative write-up on our product. Please report back once you put a few miles on your car and let us know what you think!! Quote:
| | #86 |
Friends: 5 | According to a couple of guys who studied under the hood, they thought the 2010 was different enough that the kit would not fit without altering. |
| | #87 | |
Brian was great with and thanks again for your help. | |
| | #88 | |
Friends: 3 | Thanks again for your feedback!! Quote:
| | #89 |
| Junior Member Join Date: May 2008 Location: Italy - Europe
My Car: 2007 Prius Model: Package: #7 Thanks: 2
Friends: 0 | I received and installed BT strut tower brace on my 2007 Prius. I would like to thank Brian, a true enthusiast, and report my impressions after driving the change. I am Italian, mechanical engineer, although today I am dealing with solar energy, in the past I worked as car engineer on competition cars such as Italian Formula Renault Championship and European 360 Ferrari Challenge. Let us return to the Prius: after brace installation, I left the garage and the first thing I noticed was the improved stiffness of the forecarriage. That annoying creaking dashboard has ceased to make noise. Immediately after, the feeling was that of another car. Here is the strength and the compactness of a chassis that everyone desire for precise trajectories and predictability in behavior. Surely it is clear a reduction of understeer, which now still exists, but occurs at a higher limit and there is no longer that “pudding” stock Prius steering. But the biggest surprise was the improved ride of the car to a gain of comfort. If the chassis is more rigid, the shock will be to work pumping oil and not flexing steel chassis. This is obvious on paper, but it is nice to experience this concept driving a car modified in this sense and feel the difference. Obviously the Prius comes with a little rigid frame, that flexes a lot when the car is involved in the curve. However, even on straight you may notice increased stiffness and compactness front with BT tower strut brace. These are feelings that make the car more enjoyable and the time you spend on it will simply become more pleasant. Another thing I noticed is that the engine elastic media work better with a stiffer chassis and engine vibrations are better filtered. This is something that is appreciated every kilometre that the car runs, not only in the curve. This vibration reduction is one of the reasons way so many people is enthusiast about this brace, in my opinion. We can certainly appreciate the handling improvements, but if this is added the more comfort due to less vibration of the engine and better ride comfort, we have done bingo !! I would like to thank the forum for all the valuable information contained. Hi, Paolo |
| | #90 | |
My Car: 2008 Prius Model: Package: #6 Touring Thanks: 168
Friends: 2 | Quote:
There has been a number of threads on sway bars here, aka "anti- roll bars." To my knowledge, yours is the first reference to a TRD sway bar. Can't find it via Google search. Can you provide a site? Perhaps you're referring to a Tom's rear suspension member strenghtening brace: Carson Toyota TRD Parts, Replacement parts and accessories for Southern California | |
| brace, install, pictures, strut, tech, text, tower |
