This is a discussion on Cheaper Stiffening Plate within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Did BT get a patent? If so, did the Ebay seller violate it? Did BT get a copywrite? If so, ...
Old 06-09-2008, 07:28 PM   #21
jammin012
The man behind The Man
jammin012's Avatar
Default Re: Cheaper Stiffening Plate
Did BT get a patent? If so, did the Ebay seller violate it? Did BT get a copywrite? If so, did the Ebay seller violate that? If the answer is yes then to court they must go. If the answer is no then stop your whining.
jammin012 is offline
Old 06-09-2008, 07:30 PM   #22
jjksutton
also, I'm not sure again, but I think the burden of patent enforcement falls upon the patent holder and they may not be in a financial situation to press ahead with court costs, etc.
jjksutton is offline
Old 06-09-2008, 07:31 PM   #23
mrblaise
Go Lakers!!!
mrblaise's Avatar
My Car: Other Hybrid
I don't see anyone whining here. I see people stating facts as they know them.
mrblaise is offline
Old 06-09-2008, 09:07 PM   #24
BT Tech
BT Tech's Avatar
I wanted to try to stay out of this "discussion" but due to the overwhelming PM's and emails that I have received, I felt that I had to post a response and shed some light on this.
I first designed our BT Tech stiffening plate almost 4 years ago. The purpose of the design was to help the handling of my 2005 Prius and make it more stable on the highway. I did not intend to produce them for the public and it was only after I made a few that some of my Prius friends urged me to make them available.
I have had several design changes which improved the performance of our part over the past several years.
The person on Ebay probably purchased one of our plates and then tried to copy them. When they first posted this on Ebay, they stole the actual pictures of our product off of this site and even the product description verbatim!!
Anyone can take a piece of aluminum and drill 4 holes in it and attach it to the frame but ours has a lot more engineering into it. For example, all of our plates are CNC machined for an exact fit and finish with tolerances of .002".
All of our plates have been desgined to be as rigid as possible with the least amount of weight. We made our BT stiffening plate wider to provide more rigidity than what a stock sized plate would provide but this ment that we had to include the proper recesses to allow proper frame clearances. We include the proper recesses for a perfect fit.
We had a FEA (Finite Element Analaysis) performed and using this data we improved on its strength even further than with our original design. We use 7075-T6 aluminum which is one of the stiffest metals availabe and then hard annodize all of our plates to mil specs. NONE of these features are availabe on the Ebay copy.
We also include stainless steel with anti-seize coated bolts and washers along with a complete instruction sheet.
If one compares all of the features/engineering of our stiffening plate vs the Ebay fake, they will see that they are in fact NOT the same product as some are claiming it to be.
When Prius Chat members purchase products through the PC store, they are not only assured of getting the best quality products, they are also helping to support the running of the best Prius resource on the internet.
All of our BT Tech products that we manufacture for the Prius including our stiffening plate, strut tower brace and skid plate can ONLY be purchased through the Prius Chat online store and not found anywhere else... This includes Ebay!!
Thanks!!
Brian
BT Tech
305-652-3115
Order our BT Tech stiffening plate here:
http://priuschat.com/shop/product_in...products_id/21
Order our BT Tech skid plate here:
http://priuschat.com/shop/product_in...products_id/99
Order our BT Tech strut tower brace here: http://priuschat.com/shop/product_in...products_id/98
BT Tech is offline
Old 06-09-2008, 09:19 PM   #25
jammin012
jammin012's Avatar
Now that makes a sensible argument towards the pruchase of the BT plate, thank you for that. Better quality, material, construction and R&D. OUTSTANDING
My point would be this. You don't have a valid argumant to tell someone not to buy something "cheaper" just because you don't like their business practice.... ok well maybe you do. BUT, that's not a good argument against the product.
Take ARCO for instance. You can say you don't like who runs ARCO so you wont buy their gas, but to say they copied their formula from Shell to sell it cheaper as the reason not to buy isn't really an argument, that's just their practice.
Steal is also a grey area in the business world. I would agree from what's been posted that the Ebayer acquired the plate and copied the literature. But I don't know all the facts, though these could very well be true, because I didn't see the original advert from BT or the Ebayer. But to say they stole would in fact be liable unless copywrite or patent laws were broken.
Here's what the arguement should have been. Don't buy the Ebay plate because it's an inferior product and you get what you pay for.
2007 Pkg 4 Silver Metalic
EV Mod
Auto Door Lock Mod
Sirius Sat Radio (Howard and the BRN, Learn how to work Kid)
Colgan Custom Car Bra
Shark Fin baby YEAH
NitroTires 55/55
Mud Flaps
No rings
No stupid beeping when backing up or not wearing seatbelts.
Still working on the 24" Wheels.
Old 06-09-2008, 10:17 PM   #26
ZC1
Junior Prius Owner
ZC1's Avatar
Friends: 13
The OP seems very suspicious by posting his/her first and *only* time advancing a product recommendation.
I also checked out the Ebay product online and the only thing *similar* to the BT Tech product is:
Both are intended for the same function.
Both are aluminum
Both have holes matching the Prius underbody (for the 4 bolts)
Both come with 4 bolts and washers
Both are manufacturered larger than the original plate
Both are shipped to the purchaser
Despite the previous allegations of Ebay text/photo copycatting, common sense says it doesn't look to be worth any lawyers time in pursuing a case against this individual.
It's been unconvincing, by previous arguments, how this thick aluminum product is actively inferior to the BT Tech product. In other words, how it provides LESS performance when mated to a Prius underbody.
Personally, I like the asthetic design on the BT Tech product (which is really meant to provide strength while allowing the manufacturer to shave weight.)
I also like the BT Tech annodized surface and it's black color.
I like knowing that BT Tech spent much time, effort and money into the design of this product.
I like the fact that BT Tech supports the Prius community.
When the rubber meets the road (proverbially), historically the lower cost wins out, unless the lower cost product cannot begin to resemble the expected performance. But when performance figures are dictated by seat of the pants results the lines of separation become even more blurred.
Sidenote: The first time I noted a user-replaceable underbody stiffening plate was in the 74-79 unibody Mustang II.
ZC1
Last edited by ZC1; 06-09-2008 at 10:21 PM. Reason: Punctuation, the bane of my existence.
ZC1 is offline
Old 06-09-2008, 10:30 PM   #27
mrblaise
Go Lakers!!!
mrblaise's Avatar
You've indicated how you believe it is "similar". Tell us how you believe it is not "similar".
Both are aluminum
ZC1
mrblaise is offline
Old 06-09-2008, 10:32 PM   #28
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
I'm a believer in paying my way. Now I must admit I bought my BT tech plate second hand but have purchased several item from the PC shop and currently have an order with them. I have saved thousands using information on this forum (thanks Hobbit) so in effect I have actually saved much more than I have spent with the PC Shop, if buying stuff from PC costs a little more (which it doesn't) I don't mind because it keeps the site which is a very busy site going. I have reaped benefits now I help by using the PC store so others may be helped.
Do you think it is fair to recoup development costs?
BTW, there are many different grades of aluminium.
Untreated aluminium against steel in the presence of water and particularly salt will cause the steel to rust. Save a little on a cheap plate and pay for it in a few years. Please remember who you got the plate from when it happens.
Stuff from the PC shop is very competitively priced.
Click the image to open in full size. All the warranty I need.
2004 silver base model Prius
patsparks is offline
Old 06-10-2008, 12:01 AM   #29
Friends: 37
I'm certainly not whining, and expressing my view is not telling people what direction to take the thread ProblemChild.
I encourage people to support BTTech and Priuschat in part b/c it would be far too expensive to pursue any sort of legal action. The scale of the market for this thing is just way too small to justify the legal costs. But that doesn't make what the ebay guy is doing right and people, as I suggested, should let their own sense of values determine where to spend their money.
My values make it such that I appreciate Brian and his ongoing support of PC, his ongoing efforts to produce products for the Prius that people want, his personal support of all his products and his personal contribution to the site.
I choose to discourage people from buying from someone who illegally used copyrighted photos (all photos are copyright protected at the moment of creation) and a stolen design for the plate who has contributed zero to the Priuschat community either financially or personally.
Evan E. Fusco, MD
efusco is online now
Old 06-10-2008, 12:48 AM   #30
ZC1
Junior Prius Owner
ZC1's Avatar
Friends: 13
Not indications of belief, rather a short list of "online" observable similarities.
The similarities may not end with the list I've noted, as the short list I provided is a brief synopsis of viewing the alternative product, something I would encourage others to do.
Good statement, exactly the question I was implying.
Perhaps someone with performance information can clue us in to the differences when both products are mated to a Prius underbody.
ZC1
ZC1 is offline
plate, stiffener, stiffening
BT Stiffening Plate AOV Gen II Prius Modifications 11 07-17-2007 12:40 PM
English Teacher Twists OEM Stiffening Plate w/ Bare Hands, Installs BT Stiffening Plate... Free One Gen II Prius Modifications 11 04-22-2007 01:26 PM
BT Stiffening Plate versus Tom's Floor Strengthening Plate adamorzol Gen II Prius Modifications 1 04-18-2007 10:33 PM
BT Stiffening Plate ibcs Gen II Prius Modifications 18 03-07-2006 10:21 PM
