| This is a discussion on Cheaper Stiffening Plate within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Ummmmm, didn't BT just do that in their post? Check it out again, good reading.... |
| | #31 |
| The man behind The Man Join Date: Nov 2007 Location: Cali
Friends: 1 | Ummmmm, didn't BT just do that in their post? Check it out again, good reading. |
| | #32 |
| Junior Prius Owner Join Date: Apr 2008 Location: Metro Detroit
Friends: 13 | |
| | #33 |
Friends: 1 | Holy crap, are you serious? I can't believe you are unable to reason your way through this. All assertions based on vendor information. BT - For example, all of our plates are CNC machined for an exact fit and finish with tolerances of .002" Ebay - This plate might not necessary for 07 or 08 prius, since their chassis have not enduring rought road. But highly recommneded for any prius with 2-3 years in operation, the underbody chassis needs a stronger and tighter support. BT - All of our plates have been desgined to be as rigid as possible with the least amount of weight. Ebay - approx 2lb 14 oz on this plate BT - We had a FEA (Finite Element Analaysis) performed and using this data we improved on its strength even further than with our original design. Ebay - awaiting answer BT - We use 7075-T6 aluminum which is one of the stiffest metals availabe Ebay - the plate is made of 6061-T6 Alu-Alloy, it is an aircraft material. It yeild 35000psi and heat treated as well. BT - then hard annodize all of our plates to mil specs. Ebay - Surface Finish: Smooth surface BT - We also include stainless steel with anti-seize coated bolts and washers along with a complete instruction sheet. Ebay - Four M8-1.25X25mm STAINLESS socket screws included, no anti-seize and no instructions. Do I have to do all the research around here?
__________________ 2007 Pkg 4 Silver Metalic EV Mod Auto Door Lock Mod Sirius Sat Radio (Howard and the BRN, Learn how to work Kid) Colgan Custom Car Bra Shark Fin baby YEAH NitroTires 55/55 Mud Flaps No rings No stupid beeping when backing up or not wearing seatbelts. Still working on the 24" Wheels. Last edited by jammin012; 06-10-2008 at 01:35 AM. |
| | #34 |
Friends: 13 | Thanks for the post. This descriptional information is already contained within the BT Tech post. Again, I'm asking for operational performance when mated to a Prius underbody. In other words, how does it perform vs. the competition? and why is the alternative plate not good enough, since it's price is 1/3 the BT Tech plate and will be a selling point. ZC1 |
| | #35 |
Friends: 1 | The question was how are they different. If you want to find out specific stress and performance questions then asks the sources. Here's the latest answer to my R&D question: I initially made this plate for my 2006 prius, and many of my friends as well. They are my R&D. Based on the Toyota Prius carbon steel C1010 with through harden heat treatment spec, We select the 6061-T6 alu-alloy which yield 35000 psi strength, with 2 inches thicken, 4 inches wide, 14 inches long, it is overkill compare with the stock OEM steel brace. Your prius will starting to flex more and more after years of operation, so a stronger stiffer plate to support the underbody is a good idea. This type of brace plates is widely available for Japan Prius as an aftermarket performance part, our design is very similar as many other JDM company like HKS, Trust, Tom's, Top Secrets. We did best to keep the price at $49.99. if you are not satisfied with my plate, I will refund total amount plus shipping for your time and inconvenience. BT tech plate is a great choice if you want something nice and clean cuts. Their price is very reasonable since CNC machinist charge $80 per hour plus tooling fee. Best Regards Phillip June 06, 2008 |
| | #36 |
| Senior Member Join Date: May 2008 Location: Florida
My Car: Other Hybrid Model: Package: N/A Thanks: 3
Friends: 0 | 7075-T6 aluminum has substantially higher tensile strength than 6061-T6, but it is far more brittle. |
| | #37 | |
| Go Lakers!!! Join Date: Mar 2008 Location: Southern California
My Car: Other Hybrid Model: Package: N/A Thanks: 23
Friends: 4 | Sorry, but I'm not buying it. This is coming from the same loser who allegedly used BT's photos and text in their original Ebay ads. There's a sucker born every minute and I'm not one of them. Quote:
| plate, stiffener, stiffening |
| BT Stiffening Plate | AOV | Gen II Prius Modifications | 11 | 07-17-2007 12:40 PM |
| English Teacher Twists OEM Stiffening Plate w/ Bare Hands, Installs BT Stiffening Plate... | Free One | Gen II Prius Modifications | 11 | 04-22-2007 01:26 PM |
| BT Stiffening Plate versus Tom's Floor Strengthening Plate | adamorzol | Gen II Prius Modifications | 1 | 04-18-2007 10:33 PM |
| BT Stiffening Plate | ibcs | Gen II Prius Modifications | 18 | 03-07-2006 10:21 PM |
