This is a discussion on REVIEW: Hybrid Effects Wheel Skirts within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Nice work... one downside is that it's going to be a PITA to check your rear tire pressures now :-)...
LinkBack (10) Thread Tools
Old 07-16-2008, 09:19 AM   #11
Ichiro
Ichiro's Avatar
Default Re: REVIEW: Hybrid Effects Wheel Skirts
Nice work...
Ichiro is offline
Old 07-16-2008, 10:11 AM   #12
Qlara
Qlara's Avatar
Interesting look with the skirt, but what happen if you have a rear flat tire when the skirt is not that easy to remove? That may become PITA.....
Qlara is offline
Old 07-17-2008, 12:49 PM   #13
allargon
allargon's Avatar
Package: #5 Touring
You turned your Prius into a four door Insight? (j/k)
Please continue to let us know how it works out for you.
allargon is offline
Old 07-17-2008, 09:26 PM   #14
Hybrid Effects
Hybrid Effects's Avatar
Checking tire pressure is not a problem, all you do is roll the car until the valve stem is near the ground. If you have flat aero hub caps like the ones I sell there is an access plug on the hub caps.
If you have a flat you will need to jack the car up anyways and that makes it even easier to remove the skirts. I personally can remove the wheel skirts in one minute. There is only two bolts and if you have a ratchet wrench it is not all that hard.
The cost of the wheel skirts is very fair and after looking at what it cost to make and ship the skirts I think the price might just be a little to fair. It takes a half a gallon of high quality resin alone to make a pair of skirts and that's not counting the fiberglass material, gel-coat, acetone, wax, gloves, brushes, rollers and labor etc. Plus these are made in the U.S.A.
Franklin
Hybrid car Accesories http://www.HybridEffects.com
email@HybridEffects.com
Hybrid Effects is offline
Old 07-18-2008, 04:20 AM   #15
Godiva
AmeriKan Citizen
Godiva's Avatar
Package: #1
Friends: 7
Actually I was interested in where you got the wheel skirts and how much they cost.
Godiva is offline
Old 07-18-2008, 05:09 AM   #16
Flying White Dutchman
Friends: 9
theforce
do you have a bigger rear hatch spoiler like the touring? you don't have the bigger touring tires?
do you think there is enough room for the 195 touting tire's?
where did you get the front spoiler i like it
also thx for the great pictures etc.
Old 07-18-2008, 11:35 AM   #17
Hybrid Effects
For pricing go to Hybrid Car Accessories by Hybrid Effects.
Old 07-18-2008, 10:29 PM   #18
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Originally Posted by abra View Post
looks good...
$350.00 hope it gains mpg. update us on that.
btw what type of mpg gain was the caps?
I'll update as soon as I get some time and get this E10 crap out of my tank. Thats the only thing bad about coming to Hybridfest. E10 is everywhere.
I never really did any official tests with the caps. I from what I experienced I guessed about a 2mpg gain with a 2mpg margin of error.
When the E10 is out of my tank I can do some highway test and see if I get better or worse compared to my previous highway experience. If I have time I would like to do a highway run without the skirts and caps for the control, then with the skirts, then with the skirts and caps and then finally without the skirts and caps again to verify the control.
Yes that would be a PITA. The skirts can be removed it just took me a few minutes to do it. I think what I really need is a smaller ratchet. The one I have now is a little big and makes it really awkward to reach up in there. I'm going to try to find another way to attach these things after I get back from Hybridfest.
Originally Posted by Ichiro View Post
Nice work...
With no caps under the skirts all I have to do is roll the car a little bit until the air stem comes in view. When I make my aluminum caps for the rear I will cut a hole in it to get to the air stem.
Originally Posted by Flying White Dutchman View Post
theforce
Yes I have the touring spoiler. I got the spoiler before they even announced the touring would be available in the USA.
I'll have to see if a touring Prius is here at Hybridfest and take a look but I think the skirts should fit just fine.
The front spoiler I got from Sigma Automotive – Toyota Hybrid Prius 2004 - 2009 OEM & JDM auto accessories .
TheForce is offline
Old 07-18-2008, 10:54 PM   #19
problemchild
problemchild's Avatar
That front license plate is creating a lot of drag. Seems like you should remove that. I would remove the mirrors too. Crawl under the car and look at all the drag there. It needs a smooth pan all the way under the car to create better coefficient. They also make a special was for jets that reduces drag.
problemchild is offline
Old 07-18-2008, 11:27 PM   #20
Hybrid Effects
Jay get in touch with me when you are ready to explore more options for attaching the wheel skirts. I have a really good idea but it will require two small screws on the outside bottom edge of the skirt.
I know that a lot of people will say that the price of the wheel skirts are high but I can not dictate the cost of supplies and shipping and so forth but I can control how much research and development that I put into each product. One reason I was able to offer the wheel skirts at the price they are now is that I used the easiest form of attachment.
Franklin
effects, hybrid, review:, skirts, wheel
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/50902-review-hybrid-effects-wheel-skirts.html
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 04-06-2009 08:01 AM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 03-31-2009 01:20 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 03-12-2009 01:57 PM
Plugin Toyota Prius Hybrid, Plug In Saturn Vue, Plus Size Mini Skirts - Carbumpers This thread Refback 03-08-2009 08:12 AM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 10-24-2008 09:24 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 10-18-2008 09:19 AM
Jay Groh dot com This thread Refback 08-18-2008 12:12 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 07-17-2008 03:10 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 07-17-2008 02:56 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 07-17-2008 02:25 PM
Real wheel skirts. bestmapman Gen II Prius Modifications 99 08-09-2008 10:06 PM
Prius Wheel Skirts Hybrid Effects Gen II Prius Modifications 23 07-13-2008 05:10 AM
Making Aerodynamic hubcaps and rear wheel skirts? Tree Hugger Gen II Prius Modifications 28 05-26-2008 02:02 AM
Adding Rear Wheel Skirts TheForce Gen II Prius Modifications 8 04-23-2008 03:59 AM
Aero FRONT Wheel Skirts/Spats Rokeby Gen II Prius Modifications 0 04-18-2008 09:06 PM
