This is a discussion on REVIEW: Hybrid Effects Wheel Skirts within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I found a small issue with the skirts. Long time exposure to rocks will chip away at the paint in ...
LinkBack (10) Thread Tools
Old 02-26-2009, 01:48 PM   #31
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Default Re: REVIEW: Hybrid Effects Wheel Skirts
I found a small issue with the skirts. Long time exposure to rocks will chip away at the paint in the front lower corner of each skirt.
My solution to this small issue is to touch up the affected area with touch up paint then put a 3"x3" square piece of clear plastic over this area. Kind of like a small clear bra for the wheel skirt. I guess you would call it a clear thong.
When the temps warm up I will paint them and apply some left over clear bra material that I have laying around.
I will report back when that project is finished.
I will pass this tip along to Hybrid Effects to make a better product.
TheForce is online now
Old 02-26-2009, 11:03 PM   #32
josh2008
TheForce,
Hello, were you able to tell a difference in aerodynamics/efficiency after installing the rear wheel skirts?
Thanks,
Josh
josh2008 is offline
Old 02-27-2009, 12:43 AM   #33
CharlesJ
CharlesJ's Avatar
Just a thought: if there is a clear patter to the rock damage area, may wan to round off that inner corner of that clear sheet. I think that might look better than a corner. even is it will be hard to see just up close.
CharlesJ is offline
Old 02-27-2009, 07:17 AM   #34
Rokeby
Rokeby's Avatar
chip away at the paint in the front lower corner of each skirt...
area. Kind of like a small clear bra for the wheel skirt...
The Force,
Thanks for the update.
I stared my wheel skirt project back in the fall but was overaken by
cold weather. I've modded the skirts to a "three-quarter length:"
http://priuschat.com/forums/attachme...h-img_0008.jpg
(Not yet painted -- color is duct tape -- or permanently mounted, note
the "kick stand" positioning the skirt.)
From your picture, it looks like I won't be seeing as much of he
chipping as you have. Nonetheless, it looks like a clear plastic overlay
will be a good idea.
Hurry up springtime and warmer weather so I can complete this
project!
Rokeby is offline
Old 02-27-2009, 11:10 AM   #35
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Originally Posted by josh2008 View Post
TheForce,
Thanks,
Josh
No.
I plan on not making it a true 3x3 square. I plan on rounding or tapering it down some how. Maybe more like a triangle. I just wont know until I go try it.
Rokeby it looks like you will have less surface area down there but it looks like your still in the chip zone. Go ahead and put some protecting down there just to be on the safe side.
The Following User Says Thank You to TheForce For This Useful Post:
sdserene (06-07-2009)
Old 05-31-2009, 11:49 PM   #36
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Well I got done fixing the chipped areas on the skirts Thursday.
What I did was clean them really well and applied 3 thick coats of touch up paint to the deep areas. Then I applied a coat of paint to the triangle area that was pitted. I did this all with the small brush and it looks just fine. You have to be really close to tell it was brushed on. Plus the protective 3M clear bra material helps hide it. I used some spare 3M clear bra material I had left over from a previous project so I cut out a large enough square to cover the affected area. Here are some pictures of the result. We will see how well this works out over the next year.
You can just barely make out the 3M clear bra material in the corner.
Here I have outlined where the edge of the clear bra is. The painted area is about a half inch in from the edge of the film. To anyone that has these wheel skirts I highly recomend covering at least this much of the corner. Most of the damage was at the very bottom but %99 of the pitting was with in this triangle area.
Rokeby (06-01-2009)
Old 06-07-2009, 01:16 AM   #37
sdserene
For some reason I think the caps look cool. Aerodynamically I'm sure makes a difference because I've seen some top speed cars that has them installed. No reason putting effort in unless it does help somewhat. It is a mod that should help on freeways more then local driving.
sdserene is offline
effects, hybrid, review:, skirts, wheel
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/50902-review-hybrid-effects-wheel-skirts.html
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 04-06-2009 08:01 AM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 03-31-2009 01:20 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 03-12-2009 01:57 PM
Plugin Toyota Prius Hybrid, Plug In Saturn Vue, Plus Size Mini Skirts - Carbumpers This thread Refback 03-08-2009 08:12 AM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 10-24-2008 09:24 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 10-18-2008 09:19 AM
Jay Groh dot com This thread Refback 08-18-2008 12:12 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 07-17-2008 03:10 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 07-17-2008 02:56 PM
Priusfreunde.de - Re: Aerodynamikabdeckung (Weglassen derselben) - Priusforum This thread Refback 07-17-2008 02:25 PM
Real wheel skirts. bestmapman Gen II Prius Modifications 99 08-09-2008 10:06 PM
Prius Wheel Skirts Hybrid Effects Gen II Prius Modifications 23 07-13-2008 05:10 AM
Making Aerodynamic hubcaps and rear wheel skirts? Tree Hugger Gen II Prius Modifications 28 05-26-2008 02:02 AM
Adding Rear Wheel Skirts TheForce Gen II Prius Modifications 8 04-23-2008 03:59 AM
Aero FRONT Wheel Skirts/Spats Rokeby Gen II Prius Modifications 0 04-18-2008 09:06 PM
