| This is a discussion on Would this horn fit? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Can anyone tell from the picture whether this horn would fit in the Prius in place of the current (whimpy) ... |
#1 |
| AmeriKan Citizen Join Date: Apr 2005 Location: San Diego, CA
My Car: 2005 Prius Model: Package: #1 Thanks: 0
Friends: 7 | Can anyone tell from the picture whether this horn would fit in the Prius in place of the current (whimpy) horn? |
My Car: 2008 Prius Model: Package: #6 Touring Thanks: 82
Friends: 2 | Godiva, Can't tell from the pix how big it is. In the Q&A section the same question is unanswered. That said, unless the horn/compressor is bigger than a 6-pack it will fit between the radiator and bumper. One of the OEM horns mounts near the top of the radiator. Room is hard to find here. But there is lots of room at the bottom of the radiator. I suspect that you'd have to remove the center section of the lower grill to get the horn in and have room to manipulate your hands/tools. There are a number of "new horn" threads that have pictures of the area at top and bottom of the radiator. BTW, the second OEM horn is crammed into a really tight spot at the top of the radiator on the pax side. The aforesaid pix show the layout. |
| Senior Member Join Date: Nov 2007
Friends: 2 | I just replaced my OEM horns with the PIAA horns (available from Amazon.) They fit fine, but they're pretty small. Even so, it was a chore in the heat and humidity, and I came away with bruises on my arms. They sound great, though. One thought: How are you going to wire the horn/compressor? The wire going to the OEM horn is very small, probably 22 gauge or smaller (and it has no ground wire), and I doubt it would handle the load. So you might have to do some additional wiring -- maybe not -- I just don't know. The dimensions of your proposed horns are: 2-1/2" W x 4-1/2" L x 4-1/2" H. I'm pretty sure these would not fit without relocating at least one. I am almost positive you could not put these in without removing the grill, etc. As I said, the horn replacement is a bit more of a chore than it seems due to the tight space. You might want to take the above dimensions and make sort of a mockup to check the fit before you order. And the chromes cost $15 more -- is this really important for hidden horns? Good luck. |
Friends: 7 | Okay. It was a thought. The present horn is just so whimpy. But I am not going to go to the trouble of rewiring, etc. If it was a simple swap in/out yes. But looks like not. So I'm abandoning the idea. |
Friends: 44 | I understand that some Prius owners have installed Camry horns to beef up the sound. |
Friends: 2 | Quote:
Nah, don't give up. The OEM horns DO sound wimpy, so wimpy I think they might be a safety factor because of the high noise levels in other modern cars. You really need to be heard. Go to Amazon and search on PIAA horns. These sound like "normal" horns from American cars (2 tones). These will fit without doing any rewiring or re-locating, but like others here I extended the "hot" wire a few inches so as to relieve the strain on the original wire. The ground wire simply goes under the original bolt when you attach it since the OEM horn is grounded through the car frame. It's a slightly annoying task, but certainly nothing beyond the range of someone who's had middle school shop class. Try it! | |
Friends: 7 | Quote:
I'm looking at getting a 2009 and planning on what I want to do to upgrade it beyond what I did with my current car. Better horn is on the list. | |
| _ . _ . / _ _ . _ Join Date: Mar 2008 Location: Los Angeles
My Car: 2008 Prius Model: Package: #5 Thanks: 73
Friends: 11 | Quote:
They are about $50 for the pair from Amazon.com Good Luck 73 de Pat KK6PD | |
| Senior Member Join Date: Oct 2007 Location: Gilbert, AZ
My Car: 2008 Prius Model: Package: #6 Thanks: 1
Friends: 1 | I don't think I've ever used my horn in the 10 months I've owned my Prius. Am I doing something wrong? |
| fit?, horn |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/51874-would-horn-fit.html | ||||
| Would this horn fit? - Latest Toyota Prius News - Toyota Prius: Blogs and News - Newsbeet | This thread | Refback | 10-05-2008 08:10 PM | |
| What's up with the horn?? | PriuStorm | Gen II Prius Main Forum | 23 | 05-30-2009 02:17 PM |
| Horn | filmguy | Gen II Prius Modifications | 3 | 11-03-2007 06:27 AM |
| Where's that horn? | tessar | Gen II Prius Main Forum | 54 | 09-08-2007 07:44 PM |
| Horn | andyprius | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 03-19-2005 12:09 PM |
| Horn | seeh2o | Gen II Prius Modifications | 6 | 03-08-2004 10:26 PM |
