This is a discussion on REVIEW: Hymotion Battery Plug-In Prius within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hey, thanks for a great review - love the detailed write-up and descriptions! I have a couple of questions for ...
LinkBack (114) Thread Tools
Old 08-24-2008, 01:00 AM   #111
SVPriusFan
Hymotioned and loving it...
SVPriusFan's Avatar
Default Re: REVIEW: Hymotion Battery Plug-In Prius
Hey, thanks for a great review - love the detailed write-up and descriptions! I have a couple of questions for you:
1. Is an EV-mode switch helpful in maximizing MPG? Or is it even necessary? I had one in my previous Prius (a 2007) and loved it. But I've been putting off getting one for my new 2008 since I'm on the list for the Hymotion mod in about 7 weeks.
2. Does the L5 installation hack the 42MPH limit on stealth mode? I thought I read somewhere that it ups the limit on turning the engine crank to somewhere in the 50's, but I'm not sure where I saw that...
Please keep the info coming!
SVPriusFan is offline
Old 08-24-2008, 01:16 AM   #112
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Just for the hell of it I added a graph of the reported SOC from my CAN-view. Just go back to my first post and scroll down to the observations area.
If your driving around town with the Hymotion battery then yes the EV button is a must have.
No the car still acts normal. You can however draw up to about 50 amps in warp stealth above 42MPH. The engine still spins at about 950RPM but you don't burn any gas. Normally when your SOC is at %60 your lucky if you can draw 20 amps in warp stealth and if you can do that your SOC drops quickly because of the small stock battery.
TheForce is offline
Old 08-24-2008, 03:29 PM   #113
9G-man
I get it all now. I couldn't fully understand your review on highway/warp stealth use, and how the Hymotion pack enhanced things, until now.
Does it allow a broader amp draw during stealth operation, with or without an EV switch, than stock?.
I want one.
9G-man is offline
Old 08-24-2008, 03:51 PM   #114
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
I think it does since you have a full SOC. I seen it go as high as about 60 amps or so without using the EV button but the engine will more likely kick on when ever it wants to.
TheForce is offline
Old 08-24-2008, 10:48 PM   #115
Orf
Orf's Avatar
Package: I-Tech
What a grand thread you have created Force. I like the way you add new info to your original post but I am never sure what is new. Could you post the new text in a different color, say red, and then make it black when more new text is added?
Orf is offline
Old 08-24-2008, 11:50 PM   #116
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
I've been thinking how I should handle when I should fill up. Since I can go in EV mode just about anywhere on my normal commute should I just go until I run out of gas and EV it to my preferred gas station or should I fill up when my CAN-view shows about %5 or so fuel remaining? It would be nice to experience running out of gas just once just to see what happens and since I have the extra battery I should be safe from damaging the stock battery on an extended out of gas EV run.
I also don't know if I would be able to even try that since I don't know when this might happen. If it happens on my normal commute then I will be able to do it but if it looks like I might be taking a longer trip I might have to gas up before that. I do know from past experience that when my CAN-vies shows about %10 fuel remaining I have about 10-15 miles before it reaches %0 and then I still have fuel left to get another 5 miles or so to the gas station.
Any one have any thoughts or comments on that?
I though about that but it would get all confusing and and it would be a little too much work. What I would like to do is when I finish my tank I want to clean it up a bit and make some of the pictures smaller or something. If you follow this thread I will try to point you to what was updated and in what section.
TheForce is offline
Old 08-25-2008, 01:15 AM   #117
Orf
Orf's Avatar
Package: I-Tech
It may be an idea to carry a can of gas if you decide to run out.
I do not know which browser you use but in mine (Netscape) all you have to do is select "edit" highlight the text and select a new color, be it black or red. That should not be too much work and it would be easier for all readers to go to the colored text to see if they have read it before.
Orf is offline
Old 08-25-2008, 05:07 AM   #118
lordbah
If someone with this mod were to go months without adding gas, would that cause a new set of problems? Same as leaving gas in the lawnmower over a long winter?
lordbah is offline
Old 08-25-2008, 12:24 PM   #119
David Beale
David Beale's Avatar
It takes about a year, or even longer, to get gasoline to "go bad" in an automobile fuel tank. It happens faster in lawnmowers because they have much smaller fuel tanks, and much dirtier fuel systems.
I had an RX-7, and I used to store it for 6 months every year with a full fuel tank, no "stabilizer". Never had fuel go "bad".
David Beale is offline
Old 08-25-2008, 02:59 PM   #120
zcat3
As the Hymotion battery allows to draw more amps, does that mean you can accelerate faster in EV mode without triggering the ICE - or does it function the same way as the stock setup - meaning very little pressure on the pedal or the ICE comes on.
zcat3 is offline
battery, hymotion, plug-in, prius, review:
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/52157-review-hymotion-battery-plug-in-prius.html
Software update allows 70 mph in EV mode for Prius - PriusChat Forums This thread Refback 09-06-2009 06:20 PM
Tryin' to find a car using the CARS program: where'd all the fun cars go? - Page 2 - MY350Z.COM Forums This thread Refback 08-05-2009 06:07 AM
REVIEW: Hymotion Battery Plug-In Prius - PriusChat Forums This thread Refback 07-03-2009 09:23 PM
????? ???????????????? ????????? ? ???????? -> IR3SP - Sistemsko programiranje This thread Refback 03-31-2009 10:01 AM
????? ???????????????? ????????? ? ???????? -> IR3SP - Sistemsko programiranje This thread Refback 03-31-2009 07:31 AM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-27-2009 06:38 AM
Prodajem Palit 8800GT Sonic (OC) i LC 550W - BENCHforum This thread Refback 03-26-2009 07:15 PM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-26-2009 07:09 PM
Prodajem Palit 8800GT Sonic (OC) i LC 550W - BENCHforum This thread Refback 03-26-2009 05:17 PM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-26-2009 04:51 PM
STA UZETI SEAGATE ST31500341AS ili WD WD1001FALS - BENCHforum This thread Refback 03-24-2009 08:16 AM
????? ???????????????? ????????? ? ???????? -> Ekspertski sistemi IR4ES This thread Refback 03-23-2009 04:06 PM
Qtek 9000 (HTC Universal) WM6 Rom pa ajd sad... - BENCHforum This thread Refback 03-22-2009 08:10 PM
Gde da kupim Logitech Lapdesk for Notebooks u BG - BENCHforum This thread Refback 03-21-2009 10:05 AM
iPod touch restore greska ???? - BENCHforum This thread Refback 03-15-2009 02:03 PM
Koji ku?ni plejeri ?itaju .mkv? - Strana 12 - BENCHforum This thread Refback 03-13-2009 07:08 PM
5800 i garmin - BENCHforum This thread Refback 03-13-2009 06:25 PM
Ford 9N, 1996 Ford Thunderbird, Ford Aspire - Mufflerclamp This thread Refback 03-13-2009 06:25 AM
992005 Chevy Gmc Tahoe Truck Console Jumpseat, Chevy Tahoe Door Parts, Carson Tahoe Regional Medical Center - Demoncow This thread Refback 03-12-2009 05:25 AM
Budget Car Rental San Diego, Budget Rental Car Uk, Budget Car Rental Tenerife South Airport - Startersalternator This thread Refback 03-10-2009 07:16 AM
Nintendo DS Lite - BENCHforum This thread Refback 03-06-2009 11:55 AM
Nintendo DS Lite - BENCHforum This thread Refback 03-06-2009 10:54 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - Strana 2 - BENCHforum This thread Refback 03-05-2009 07:04 AM
USB HUB 6+ - BENCHforum This thread Refback 03-03-2009 09:41 AM
[MTS] Promena cena u me?unarodnom saobra?aju - BENCHforum This thread Refback 03-02-2009 06:05 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 03-01-2009 07:25 PM
HDD 2.5" 60GB PATA (idealan za prenosni usb disk) - BENCHforum This thread Refback 03-01-2009 07:43 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 02-28-2009 06:12 AM
Acer Aspire one - zvani?na tema - Strana 20 - BENCHforum This thread Refback 02-28-2009 01:52 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 02-27-2009 02:58 PM
WD 640gb i Pakom - BENCHforum This thread Refback 02-25-2009 10:02 AM
WD 640gb i Pakom - BENCHforum This thread Refback 02-25-2009 06:07 AM
Half-Life 2 Episode Two - Strana 4 - BENCHforum This thread Refback 02-25-2009 04:47 AM
Gde kupiti ketridz za Lexmark? - BENCHforum This thread Refback 02-22-2009 04:53 AM
Sony najavio novi eBook reader - BENCHforum This thread Refback 02-20-2009 07:55 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 02-19-2009 04:43 AM
[MTS] Postpaid - (ne)Mogucnost provere stanja - Strana 14 - BENCHforum This thread Refback 02-17-2009 12:28 PM
Windows Mobile 2005 - BENCHforum This thread Refback 02-16-2009 07:08 AM
Koji ku?ni plejeri ?itaju .mkv? - Strana 9 - BENCHforum This thread Refback 02-14-2009 01:43 PM
Digitus External SATA Docking Station - BENCHforum This thread Refback 02-13-2009 10:01 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 04:50 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 03:47 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 01:28 AM
Adapteri za laptop racunare - BENCHforum This thread Refback 02-11-2009 08:51 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - Strana 2 - BENCHforum This thread Refback 02-10-2009 08:39 AM
STA UZETI SEAGATE ST31500341AS ili WD WD1001FALS - BENCHforum This thread Refback 02-09-2009 03:50 PM
Acer Aspire one - zvani?na tema - Strana 20 - BENCHforum This thread Refback 02-08-2009 01:20 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-08-2009 06:40 AM
Toshiba A10 - kako u BIOS/kalibracija baterije? - BENCHforum This thread Refback 02-07-2009 10:07 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-07-2009 08:56 PM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-07-2009 05:29 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-07-2009 04:47 PM
WD500AAKS SMART error? - BENCHforum This thread Refback 02-06-2009 07:28 PM
SATA to USB adapter, gde kupiti? - BENCHforum This thread Refback 02-05-2009 06:51 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-03-2009 12:07 PM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-03-2009 07:44 AM
4 monitora na jednom racunaru!? - BENCHforum This thread Refback 02-02-2009 06:29 PM
mts 3G net, iskustva korisnika - Strana 2 - BENCHforum This thread Refback 01-29-2009 05:36 PM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????????? 1 This thread Refback 01-29-2009 11:53 AM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 4 - BENCHforum This thread Refback 01-29-2009 09:40 AM
????? ???????????????? ????????? ? ???????? -> ASP This thread Refback 01-27-2009 12:51 PM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 2 - BENCHforum This thread Refback 01-24-2009 09:13 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 01-24-2009 04:38 AM
HTC TyTN - zvani?ni WM6 - BENCHforum This thread Refback 01-21-2009 09:02 PM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 2 - BENCHforum This thread Refback 01-21-2009 08:07 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 01-20-2009 09:08 AM
mts 3G net, iskustva korisnika - Strana 7 - BENCHforum This thread Refback 01-15-2009 05:03 AM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 01-14-2009 06:08 PM
????? ???????????????? ????????? ? ???????? -> Audio snimci predavanja 2008/2009 za RTI This thread Refback 01-11-2009 09:14 AM
PocketPC sa ugradjenim GPSom i Pixma originalna mastila sa cipom - BENCHforum This thread Refback 01-04-2009 03:27 PM
PocketPC sa ugradjenim GPSom i Pixma originalna mastila sa cipom - BENCHforum This thread Refback 01-04-2009 02:34 PM
????? ???????????????? ????????? ? ???????? -> Januarski ispitni rok This thread Refback 12-28-2008 01:06 PM
MTS Postpaid -- Provera stanja *797# - BENCHforum This thread Refback 12-26-2008 12:45 PM
Core i7-920 vs Core2Quad Q9550? - BENCHforum This thread Refback 12-24-2008 02:09 PM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 12-24-2008 05:35 AM
iPhone - FAQ - Strana 2 - BENCHforum This thread Refback 12-23-2008 04:07 AM
HTC vs. Omnia vs. iPhone - BENCHforum This thread Refback 12-22-2008 04:39 PM
HTC vs. Omnia vs. iPhone - BENCHforum This thread Refback 12-21-2008 06:21 PM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 12-20-2008 09:10 AM
HP 1020, istrosio se toner posle 100 stampanja - BENCHforum This thread Refback 12-19-2008 10:33 AM
????? ???????????????? ????????? ? ???????? -> ASP This thread Refback 12-18-2008 02:07 PM
Acer Aspire one - zvani?na tema - Strana 19 - BENCHforum This thread Refback 12-18-2008 12:30 PM
mt:s bezobrazluk - BENCHforum This thread Refback 12-18-2008 10:56 AM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 12-17-2008 09:53 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 12-02-2008 03:04 AM
Connecting the Dots This thread Refback 11-17-2008 04:17 AM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 11-15-2008 03:17 AM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 11-05-2008 04:01 PM
Prius on Hymotion steroids: Highway and City Peak Oil Garage This thread Refback 10-11-2008 11:26 AM
Hymotion battery install on Monday Peak Oil Garage This thread Refback 10-04-2008 02:56 AM
Peak Oil Garage This thread Refback 10-03-2008 11:31 PM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 09-11-2008 02:42 PM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 09-11-2008 07:34 AM
EVcast #68: Interview with Danny Fleet This thread Refback 09-06-2008 02:48 AM
Recent ElectricVehicle Bookmarks on Delicious This thread Refback 09-06-2008 12:12 AM
Prius Hymotion Plug-In Conversion This thread Refback 09-05-2008 11:35 AM
YouTube - 171mpg in Prius Plug-in Hybrid Electric (PHEV) This thread Refback 08-24-2008 03:52 PM
ltzoschke's Bookmarks on Delicious This thread Refback 08-20-2008 10:20 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 08-20-2008 01:26 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 08-19-2008 02:24 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-18-2008 09:51 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-14-2008 09:34 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 06:50 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 02:19 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 12:19 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 08:53 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 08:03 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 06:17 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 05:46 PM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-13-2008 03:16 PM
GM-VOLT : Chevy Volt Electric Car Site Blog Archive GM Expects an Initial Shortage for the Volt This thread Refback 08-13-2008 09:24 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 01:36 PM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 08:45 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 08:31 AM
Method to extend Hymotion Battery by 25% rwyckoff Gen II Prius Technical Discussion 12 10-20-2008 10:51 PM
Hymotion Plug-in a123 battery pack available for consumer purchase pelewis2 Prius and Hybrid News 92 05-26-2008 08:45 PM
A123/Hymotion taking order for Prius Plug in mods this week? ualdriver Gen II Prius Main Forum 7 04-26-2008 01:47 PM
Prius plug-in displays battery of good points Proco Prius and Hybrid News 26 02-01-2008 11:32 AM
AfterMarket Plug-In company Hymotion bought EricGo Prius and Hybrid News 3 05-20-2007 02:44 PM
