This is a discussion on REVIEW: Hymotion Battery Plug-In Prius within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by TheForce I just got my Hymotion welcome package today. Here is what it includes. Inside the envelope ...
LinkBack (114) Thread Tools
Old 10-09-2008, 12:34 PM   #191
jrmgkia
Wish I was cycling
jrmgkia's Avatar
Default Re: REVIEW: Hymotion Battery Plug-In Prius
Inside the envelope there is an updated instruction manual, a quick start guide that looks like it can hang on your rear view mirror, a square 100+MPG sticker that looks like it will fit on the gas door, a Hymotion window sticker, an oval PHEV sticker and a Hymotion logo "H" keyring.
I have scanned in and uploaded the new manual. This is reversion 03.
http://jaygroh.dreamhost.com/priusch...uide%20V03.pdf
The Force, I read over the new version of the L5 owners manual that you posted and discovered something that I didn't know before. The regen braking of the Prius never charges the L5 battery pack. I am guessing that while using the L5 the stock Prius battery gets "regened" until it is fully charged and then the extra regen is wasted, am I correct? I also noted in the manual that you are strongly warned not to turn off the L5 battery back while driving. My thoughts were this:
1. What would happen if you did turn off the L5 battery while driving, would it really cause any problems?
2. Could you drive with the L5 on and use the regen to fully charge the stock Prius battery. Then switch off the L5 battery and drive in regular EV mode until the stock battery is down to only 2 charge bars. Then switch the L5 back on and regen the stock battery again? Assuming you could do this 5 times before the L5 is discharged it could gain you 5-10 extra miles of EV only driving.
O.K. Force so now tell me why I'm an idiot and how this won't work. The only reason I can see is if the regen does not go to the stock battery when the L5 is engaged, but rather is just wasted as heat. If that is the case then I would love to see the first hack to make it so the L5 accepts the regen charge from the Prius.
Jason Miller
www.jasonandginny.com
jrmgkia is offline
Old 10-09-2008, 04:52 PM   #192
PeakOilGarage
Nothing less than 99.9
PeakOilGarage's Avatar
Friends: 8
That is sort of correct. The regen energy only goes into the NiMH stock battery. In the background, you can see that the stock battery spends most of the time at 7/8 or 8/8 of capacity. It is almost always green. But that energy is being used also at the same time as the Hymotion battery.
I do see it going down to 6/8 sometimes, but it easily goes back up to 7/8 or 8/8 while just driving around town in pure EV mode.
It is as if the Hymotion system just floods the Toyota system will all of the electricity that it could ever want.
Based on where the Hymotion battery is connect, it is directly at the same point between the stock NiMH battery and where those cable lead to the Toyota drive system.
So the Hymotion is not "behind" the NiMH battery. It is accurate to describe them as side by side together feeding the Toyota drive system.
And the NiMH is not being asked nearly as much to contribute, so it is typically at 7/8 or 8/8 most of the time.
Some of the other Hymotion owners might be able to add more to my observation.
I have done it many times to save the Hymotion battery for in city driving, especially if I know I am driving more than 30 miles. I would rather conserve the Hymotion battery for speeds under 40 mph. The only time I use the Hymotion battery on the highway is if I know that I have enough remaining charge to get home or to work (where I can also recharge).
There are no negative effects to turning off the Hymotion system while driving. It might cause your cruise control to lose it's settings. No big deal. The Hymotion system turns off automatically while your are driving if you run out of energy, so clearly there is no harm to the vehicle from turning it off with the switch.
I have done that a little. If I notice that the stock battery is at 8/8, I have switched off the Hymotion battery and driven a little bit until it is 6/8, then I switch the Hymotion battery back on.
I think the gasoline engine would come on automatically a long time before getting to 2/8. But also, it would be difficult to maintain EV mode that long with only the stock battery.
When the Hymotion battery is on, it give you A LOT more play in the gas pedal to stay in EV mode. Very easy to maintain EV mode. Also, the Hymotion battery will go all the way down to 0/8 and keep providing 100% until the bitter end.
With the stock battery, it turns on the gas engine to recharge a long time before it gets too low.
PeakOilGarage is offline
Old 10-10-2008, 01:24 AM   #193
PeakOilGarage
Friends: 8
I did a Hymotion pure EV range test tonight.
Here is what I did. Full Hymotion battery to start.
I drove around with the Hymotion battery off in order to warm up the Prius. Then I made sure I had a relatively flat course and traffic was at a minimum. The traffic was light, but for the first 10 miles, I hit a lot of red lights. I tried to maintain a speed of about 33 to 35 mph. Also, it was raining and there were a lot of puddles on the ground. I am not sure if that causes a measurable difference in terms of resistance on the road.
Under these conditions, I got 20 miles out of the Hymotion system in pure EV mode.
I think that if I had not been dealing with so many red lights I would have gotten 22 to 25 miles in pure EV mode.
Also, I have heard that the battery range gets better after a few discharge cycles. We will see. I will try again tomorrow night on a route without the red lights.
After that, I will be testing my highway electric assist range at 60 mph with cruise control on.
Old 10-10-2008, 05:58 AM   #194
Flying White Dutchman
Friends: 9
"After that, I will be testing my highway electric assist range at 60 mph with cruise control on."
want to see that!
Old 10-10-2008, 06:31 AM   #195
Friends: 9
.double
Old 10-12-2008, 09:38 PM   #196
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Well since I said I would fill up on October 12th I figure I better tell you my results. I actually filled up on the 11th because my preferred gas station is closed on Sundays.
Anyway here are the numbers.
1275 Miles
7.862 Gallons of gas @3.199/gal
210.403kWh @ 8 cents per kWh
162.2MPG
Cost is 3.3 cents per mile on this tank.
According to my CAN-View I could have gone another 400-500 miles before I needed to fill up.
I'm finishing up the review and should have the final draft ready in the next week or two. I'm sure you all have a lot of questions and I'm sure my final review will answer most of them. If you have any questions just post them here and I will try to answer them.
TheForce is offline
Old 10-12-2008, 09:53 PM   #197
ualdriver
1275 Miles
162.2MPG
Very interesting. Thanks for such a detailed analysis.
ualdriver is offline
Old 10-12-2008, 10:02 PM   #198
ibcs
Great job Jay,
Thank you for keeping everyone informed. I'm anxious to see your final write up, but the mileage alone is very impressive.
---Kent
ibcs is offline
Old 10-13-2008, 12:51 PM   #199
boxer93
Psyched for PHEV
boxer93's Avatar
Jay,
On your review will you show inverter temp? I've been reading up on Grill Blocking and I didn't know if you saw a difference between pre and post Hymotion install.
Thanks
Chris
boxer93 is offline
Old 10-13-2008, 12:53 PM   #200
ibcs
What is the inverter temp symbol on the scangauge? This would be very interesting to watch when doing a lot of EV.
---Kent
ibcs is offline
battery, hymotion, plug-in, prius, review:
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/52157-review-hymotion-battery-plug-in-prius.html
Software update allows 70 mph in EV mode for Prius - PriusChat Forums This thread Refback 09-06-2009 06:20 PM
Tryin' to find a car using the CARS program: where'd all the fun cars go? - Page 2 - MY350Z.COM Forums This thread Refback 08-05-2009 06:07 AM
REVIEW: Hymotion Battery Plug-In Prius - PriusChat Forums This thread Refback 07-03-2009 09:23 PM
????? ???????????????? ????????? ? ???????? -> IR3SP - Sistemsko programiranje This thread Refback 03-31-2009 10:01 AM
????? ???????????????? ????????? ? ???????? -> IR3SP - Sistemsko programiranje This thread Refback 03-31-2009 07:31 AM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-27-2009 06:38 AM
Prodajem Palit 8800GT Sonic (OC) i LC 550W - BENCHforum This thread Refback 03-26-2009 07:15 PM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-26-2009 07:09 PM
Prodajem Palit 8800GT Sonic (OC) i LC 550W - BENCHforum This thread Refback 03-26-2009 05:17 PM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-26-2009 04:51 PM
STA UZETI SEAGATE ST31500341AS ili WD WD1001FALS - BENCHforum This thread Refback 03-24-2009 08:16 AM
????? ???????????????? ????????? ? ???????? -> Ekspertski sistemi IR4ES This thread Refback 03-23-2009 04:06 PM
Qtek 9000 (HTC Universal) WM6 Rom pa ajd sad... - BENCHforum This thread Refback 03-22-2009 08:10 PM
Gde da kupim Logitech Lapdesk for Notebooks u BG - BENCHforum This thread Refback 03-21-2009 10:05 AM
iPod touch restore greska ???? - BENCHforum This thread Refback 03-15-2009 02:03 PM
Koji ku?ni plejeri ?itaju .mkv? - Strana 12 - BENCHforum This thread Refback 03-13-2009 07:08 PM
5800 i garmin - BENCHforum This thread Refback 03-13-2009 06:25 PM
Ford 9N, 1996 Ford Thunderbird, Ford Aspire - Mufflerclamp This thread Refback 03-13-2009 06:25 AM
992005 Chevy Gmc Tahoe Truck Console Jumpseat, Chevy Tahoe Door Parts, Carson Tahoe Regional Medical Center - Demoncow This thread Refback 03-12-2009 05:25 AM
Budget Car Rental San Diego, Budget Rental Car Uk, Budget Car Rental Tenerife South Airport - Startersalternator This thread Refback 03-10-2009 07:16 AM
Nintendo DS Lite - BENCHforum This thread Refback 03-06-2009 11:55 AM
Nintendo DS Lite - BENCHforum This thread Refback 03-06-2009 10:54 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - Strana 2 - BENCHforum This thread Refback 03-05-2009 07:04 AM
USB HUB 6+ - BENCHforum This thread Refback 03-03-2009 09:41 AM
[MTS] Promena cena u me?unarodnom saobra?aju - BENCHforum This thread Refback 03-02-2009 06:05 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 03-01-2009 07:25 PM
HDD 2.5" 60GB PATA (idealan za prenosni usb disk) - BENCHforum This thread Refback 03-01-2009 07:43 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 02-28-2009 06:12 AM
Acer Aspire one - zvani?na tema - Strana 20 - BENCHforum This thread Refback 02-28-2009 01:52 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 02-27-2009 02:58 PM
WD 640gb i Pakom - BENCHforum This thread Refback 02-25-2009 10:02 AM
WD 640gb i Pakom - BENCHforum This thread Refback 02-25-2009 06:07 AM
Half-Life 2 Episode Two - Strana 4 - BENCHforum This thread Refback 02-25-2009 04:47 AM
Gde kupiti ketridz za Lexmark? - BENCHforum This thread Refback 02-22-2009 04:53 AM
Sony najavio novi eBook reader - BENCHforum This thread Refback 02-20-2009 07:55 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 02-19-2009 04:43 AM
[MTS] Postpaid - (ne)Mogucnost provere stanja - Strana 14 - BENCHforum This thread Refback 02-17-2009 12:28 PM
Windows Mobile 2005 - BENCHforum This thread Refback 02-16-2009 07:08 AM
Koji ku?ni plejeri ?itaju .mkv? - Strana 9 - BENCHforum This thread Refback 02-14-2009 01:43 PM
Digitus External SATA Docking Station - BENCHforum This thread Refback 02-13-2009 10:01 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 04:50 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 03:47 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 01:28 AM
Adapteri za laptop racunare - BENCHforum This thread Refback 02-11-2009 08:51 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - Strana 2 - BENCHforum This thread Refback 02-10-2009 08:39 AM
STA UZETI SEAGATE ST31500341AS ili WD WD1001FALS - BENCHforum This thread Refback 02-09-2009 03:50 PM
Acer Aspire one - zvani?na tema - Strana 20 - BENCHforum This thread Refback 02-08-2009 01:20 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-08-2009 06:40 AM
Toshiba A10 - kako u BIOS/kalibracija baterije? - BENCHforum This thread Refback 02-07-2009 10:07 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-07-2009 08:56 PM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-07-2009 05:29 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-07-2009 04:47 PM
WD500AAKS SMART error? - BENCHforum This thread Refback 02-06-2009 07:28 PM
SATA to USB adapter, gde kupiti? - BENCHforum This thread Refback 02-05-2009 06:51 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-03-2009 12:07 PM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-03-2009 07:44 AM
4 monitora na jednom racunaru!? - BENCHforum This thread Refback 02-02-2009 06:29 PM
mts 3G net, iskustva korisnika - Strana 2 - BENCHforum This thread Refback 01-29-2009 05:36 PM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????????? 1 This thread Refback 01-29-2009 11:53 AM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 4 - BENCHforum This thread Refback 01-29-2009 09:40 AM
????? ???????????????? ????????? ? ???????? -> ASP This thread Refback 01-27-2009 12:51 PM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 2 - BENCHforum This thread Refback 01-24-2009 09:13 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 01-24-2009 04:38 AM
HTC TyTN - zvani?ni WM6 - BENCHforum This thread Refback 01-21-2009 09:02 PM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 2 - BENCHforum This thread Refback 01-21-2009 08:07 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 01-20-2009 09:08 AM
mts 3G net, iskustva korisnika - Strana 7 - BENCHforum This thread Refback 01-15-2009 05:03 AM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 01-14-2009 06:08 PM
????? ???????????????? ????????? ? ???????? -> Audio snimci predavanja 2008/2009 za RTI This thread Refback 01-11-2009 09:14 AM
PocketPC sa ugradjenim GPSom i Pixma originalna mastila sa cipom - BENCHforum This thread Refback 01-04-2009 03:27 PM
PocketPC sa ugradjenim GPSom i Pixma originalna mastila sa cipom - BENCHforum This thread Refback 01-04-2009 02:34 PM
????? ???????????????? ????????? ? ???????? -> Januarski ispitni rok This thread Refback 12-28-2008 01:06 PM
MTS Postpaid -- Provera stanja *797# - BENCHforum This thread Refback 12-26-2008 12:45 PM
Core i7-920 vs Core2Quad Q9550? - BENCHforum This thread Refback 12-24-2008 02:09 PM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 12-24-2008 05:35 AM
iPhone - FAQ - Strana 2 - BENCHforum This thread Refback 12-23-2008 04:07 AM
HTC vs. Omnia vs. iPhone - BENCHforum This thread Refback 12-22-2008 04:39 PM
HTC vs. Omnia vs. iPhone - BENCHforum This thread Refback 12-21-2008 06:21 PM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 12-20-2008 09:10 AM
HP 1020, istrosio se toner posle 100 stampanja - BENCHforum This thread Refback 12-19-2008 10:33 AM
????? ???????????????? ????????? ? ???????? -> ASP This thread Refback 12-18-2008 02:07 PM
Acer Aspire one - zvani?na tema - Strana 19 - BENCHforum This thread Refback 12-18-2008 12:30 PM
mt:s bezobrazluk - BENCHforum This thread Refback 12-18-2008 10:56 AM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 12-17-2008 09:53 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 12-02-2008 03:04 AM
Connecting the Dots This thread Refback 11-17-2008 04:17 AM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 11-15-2008 03:17 AM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 11-05-2008 04:01 PM
Prius on Hymotion steroids: Highway and City Peak Oil Garage This thread Refback 10-11-2008 11:26 AM
Hymotion battery install on Monday Peak Oil Garage This thread Refback 10-04-2008 02:56 AM
Peak Oil Garage This thread Refback 10-03-2008 11:31 PM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 09-11-2008 02:42 PM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 09-11-2008 07:34 AM
EVcast #68: Interview with Danny Fleet This thread Refback 09-06-2008 02:48 AM
Recent ElectricVehicle Bookmarks on Delicious This thread Refback 09-06-2008 12:12 AM
Prius Hymotion Plug-In Conversion This thread Refback 09-05-2008 11:35 AM
YouTube - 171mpg in Prius Plug-in Hybrid Electric (PHEV) This thread Refback 08-24-2008 03:52 PM
ltzoschke's Bookmarks on Delicious This thread Refback 08-20-2008 10:20 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 08-20-2008 01:26 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 08-19-2008 02:24 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-18-2008 09:51 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-14-2008 09:34 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 06:50 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 02:19 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 12:19 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 08:53 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 08:03 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 06:17 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 05:46 PM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-13-2008 03:16 PM
GM-VOLT : Chevy Volt Electric Car Site Blog Archive GM Expects an Initial Shortage for the Volt This thread Refback 08-13-2008 09:24 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 01:36 PM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 08:45 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 08:31 AM
Method to extend Hymotion Battery by 25% rwyckoff Gen II Prius Technical Discussion 12 10-20-2008 10:51 PM
Hymotion Plug-in a123 battery pack available for consumer purchase pelewis2 Prius and Hybrid News 92 05-26-2008 08:45 PM
A123/Hymotion taking order for Prius Plug in mods this week? ualdriver Gen II Prius Main Forum 7 04-26-2008 01:47 PM
Prius plug-in displays battery of good points Proco Prius and Hybrid News 26 02-01-2008 11:32 AM
AfterMarket Plug-In company Hymotion bought EricGo Prius and Hybrid News 3 05-20-2007 02:44 PM
