This is a discussion on REVIEW: Hymotion Battery Plug-In Prius within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by TheForce Well since I said I would fill up on October 12th I figure I better tell ...
LinkBack (114) Thread Tools
Old 10-13-2008, 08:31 PM   #201
miscrms
Plug Envious Member
Default Re: REVIEW: Hymotion Battery Plug-In Prius
Originally Posted by TheForce View Post
Well since I said I would fill up on October 12th I figure I better tell you my results. I actually filled up on the 11th because my preferred gas station is closed on Sundays.
Anyway here are the numbers.
1275 Miles
7.862 Gallons of gas @3.199/gal
210.403kWh @ 8 cents per kWh
162.2MPG
Cost is 3.3 cents per mile on this tank.
According to my CAN-View I could have gone another 400-500 miles before I needed to fill up.
I'm finishing up the review and should have the final draft ready in the next week or two. I'm sure you all have a lot of questions and I'm sure my final review will answer most of them. If you have any questions just post them here and I will try to answer them.
very impressive!
miscrms is offline
Old 10-14-2008, 06:57 AM   #202
Flying White Dutchman
Friends: 9
TheForce
what is the maximum amps you can draw before the ice kicksin when speeding up
is that the same with the standard prius
and please of so.. remember me what the standard max current draw is before the ice kicksin when in EV mode.
Old 10-14-2008, 12:21 PM   #203
boxer93
Psyched for PHEV
boxer93's Avatar
Originally Posted by ibcs View Post
What is the inverter temp symbol on the scangauge? This would be very interesting to watch when doing a lot of EV.
---Kent
Kent,
From what I understand it's not available on the Scangauge. The CAN View does have it. I could be wrong.
Chris
boxer93 is offline
Old 10-14-2008, 12:23 PM   #204
ibcs
I have a computer in the car, I will look into what it takes to run canview.
Thanks,
---Kent
ibcs is offline
Old 10-15-2008, 12:41 AM   #205
Codyroo
Here is a little update on the difference between the SG average and CAN-view average. Since my CV lost power for some reason it reset the trip to my last save point which was at around 500 miles into the tank. So what I have been doing the past few days is to reset the trip info on the CV and compare it with the trip MPG on the SG.
What I have found was that on my first trip to work the SG reported about 180MPG and the CV reported 255MPG. 255 is the max the CV can display and could mean 0 gas used or greater than 255MPG. In this case its greater than 255 apparently. On my way home the SG reported 150MPG and the CV reported 220MPG. These numbers were consistent the past few days.
If you were to take the miles driven so far which is 1100 miles and divide it by the percent of the gas used which is %60 you get about 18.333 miles per percent. If I ran my tank down to %0 I would expect to get about 1833 miles on a tank. If that tank was a 10 gallon fill up then my average would be 183MPG which is pretty much spot on to my last CV reading. If it took 11 gallons my average would be 167MPG and is more close to the SG.
Based on what I have seen so far I think the CAN-view will be a lot more accurate for a running average but I'm not sure on which would be more accurate on a trip by trip calculation.
With your recent fill up, do you think the CAN-view is more accurate or did the scan gauge come out on top?
Codyroo is offline
Old 10-22-2008, 06:00 PM   #206
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Just to let everyone know I'm still working of the final writeup. There is a lot to type out, organize, spllcheck, organize again, read everything, correct mistakes, read again, add some more stuff, and correct more mistakes. I haven't had much time to work on it but with any luck I hope to have it done by the end of October.
Originally Posted by boxer93 View Post
Jay,
On your review will you show inverter temp? I've been reading up on Grill Blocking and I didn't know if you saw a difference between pre and post Hymotion install.
Thanks
Chris
According to my CAN-View the max invert temperature was around 175.
Originally Posted by Flying White Dutchman View Post
TheForce
If your in EV mode below 34mph then you can draw about 120 amps.
Normal mode up to 41mph is about 40-50 amps.
And when in warp stealth up to about 50 amps.
I really wont know for sure which is more accurate untill I get a few more tank fills. This could take a while to find out.
TheForce is offline
Old 10-22-2008, 07:40 PM   #207
San_Carlos_Jeff
San_Carlos_Jeff's Avatar
With the mileage you're getting this could take years
The time you're spending on documenting all this for future Hymotion customers and curious lurkers (like myself) is much appreciated.
San_Carlos_Jeff is offline
Old 10-23-2008, 11:22 AM   #208
DaveinOlyWA
3rd Time was Solariffic!!
DaveinOlyWA's Avatar
3.3 cpm is awesome. with gas going down that will improve. i am also impressed by your electricity costs. does that include taxes?? i am paying just over 9 cents/kwh
DaveinOlyWA is offline
Old 10-24-2008, 05:13 PM   #209
Friends: 9
and this 120amps is special higher with your plugin pack or can you also get this with a normal prius and EV mode
and can you sustain it longer with the plugin pack.
Old 10-24-2008, 06:11 PM   #210
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Its the same for a normal Prius in EV mode. You can sustain 120 amps until you reach 34mph then your kicked out of EV mode.
TheForce is offline
battery, hymotion, plug-in, prius, review:
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/52157-review-hymotion-battery-plug-in-prius.html
Software update allows 70 mph in EV mode for Prius - PriusChat Forums This thread Refback 09-06-2009 06:20 PM
Tryin' to find a car using the CARS program: where'd all the fun cars go? - Page 2 - MY350Z.COM Forums This thread Refback 08-05-2009 06:07 AM
REVIEW: Hymotion Battery Plug-In Prius - PriusChat Forums This thread Refback 07-03-2009 09:23 PM
????? ???????????????? ????????? ? ???????? -> IR3SP - Sistemsko programiranje This thread Refback 03-31-2009 10:01 AM
????? ???????????????? ????????? ? ???????? -> IR3SP - Sistemsko programiranje This thread Refback 03-31-2009 07:31 AM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-27-2009 06:38 AM
Prodajem Palit 8800GT Sonic (OC) i LC 550W - BENCHforum This thread Refback 03-26-2009 07:15 PM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-26-2009 07:09 PM
Prodajem Palit 8800GT Sonic (OC) i LC 550W - BENCHforum This thread Refback 03-26-2009 05:17 PM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-26-2009 04:51 PM
STA UZETI SEAGATE ST31500341AS ili WD WD1001FALS - BENCHforum This thread Refback 03-24-2009 08:16 AM
????? ???????????????? ????????? ? ???????? -> Ekspertski sistemi IR4ES This thread Refback 03-23-2009 04:06 PM
Qtek 9000 (HTC Universal) WM6 Rom pa ajd sad... - BENCHforum This thread Refback 03-22-2009 08:10 PM
Gde da kupim Logitech Lapdesk for Notebooks u BG - BENCHforum This thread Refback 03-21-2009 10:05 AM
iPod touch restore greska ???? - BENCHforum This thread Refback 03-15-2009 02:03 PM
Koji ku?ni plejeri ?itaju .mkv? - Strana 12 - BENCHforum This thread Refback 03-13-2009 07:08 PM
5800 i garmin - BENCHforum This thread Refback 03-13-2009 06:25 PM
Ford 9N, 1996 Ford Thunderbird, Ford Aspire - Mufflerclamp This thread Refback 03-13-2009 06:25 AM
992005 Chevy Gmc Tahoe Truck Console Jumpseat, Chevy Tahoe Door Parts, Carson Tahoe Regional Medical Center - Demoncow This thread Refback 03-12-2009 05:25 AM
Budget Car Rental San Diego, Budget Rental Car Uk, Budget Car Rental Tenerife South Airport - Startersalternator This thread Refback 03-10-2009 07:16 AM
Nintendo DS Lite - BENCHforum This thread Refback 03-06-2009 11:55 AM
Nintendo DS Lite - BENCHforum This thread Refback 03-06-2009 10:54 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - Strana 2 - BENCHforum This thread Refback 03-05-2009 07:04 AM
USB HUB 6+ - BENCHforum This thread Refback 03-03-2009 09:41 AM
[MTS] Promena cena u me?unarodnom saobra?aju - BENCHforum This thread Refback 03-02-2009 06:05 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 03-01-2009 07:25 PM
HDD 2.5" 60GB PATA (idealan za prenosni usb disk) - BENCHforum This thread Refback 03-01-2009 07:43 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 02-28-2009 06:12 AM
Acer Aspire one - zvani?na tema - Strana 20 - BENCHforum This thread Refback 02-28-2009 01:52 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 02-27-2009 02:58 PM
WD 640gb i Pakom - BENCHforum This thread Refback 02-25-2009 10:02 AM
WD 640gb i Pakom - BENCHforum This thread Refback 02-25-2009 06:07 AM
Half-Life 2 Episode Two - Strana 4 - BENCHforum This thread Refback 02-25-2009 04:47 AM
Gde kupiti ketridz za Lexmark? - BENCHforum This thread Refback 02-22-2009 04:53 AM
Sony najavio novi eBook reader - BENCHforum This thread Refback 02-20-2009 07:55 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 02-19-2009 04:43 AM
[MTS] Postpaid - (ne)Mogucnost provere stanja - Strana 14 - BENCHforum This thread Refback 02-17-2009 12:28 PM
Windows Mobile 2005 - BENCHforum This thread Refback 02-16-2009 07:08 AM
Koji ku?ni plejeri ?itaju .mkv? - Strana 9 - BENCHforum This thread Refback 02-14-2009 01:43 PM
Digitus External SATA Docking Station - BENCHforum This thread Refback 02-13-2009 10:01 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 04:50 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 03:47 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 01:28 AM
Adapteri za laptop racunare - BENCHforum This thread Refback 02-11-2009 08:51 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - Strana 2 - BENCHforum This thread Refback 02-10-2009 08:39 AM
STA UZETI SEAGATE ST31500341AS ili WD WD1001FALS - BENCHforum This thread Refback 02-09-2009 03:50 PM
Acer Aspire one - zvani?na tema - Strana 20 - BENCHforum This thread Refback 02-08-2009 01:20 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-08-2009 06:40 AM
Toshiba A10 - kako u BIOS/kalibracija baterije? - BENCHforum This thread Refback 02-07-2009 10:07 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-07-2009 08:56 PM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-07-2009 05:29 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-07-2009 04:47 PM
WD500AAKS SMART error? - BENCHforum This thread Refback 02-06-2009 07:28 PM
SATA to USB adapter, gde kupiti? - BENCHforum This thread Refback 02-05-2009 06:51 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-03-2009 12:07 PM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-03-2009 07:44 AM
4 monitora na jednom racunaru!? - BENCHforum This thread Refback 02-02-2009 06:29 PM
mts 3G net, iskustva korisnika - Strana 2 - BENCHforum This thread Refback 01-29-2009 05:36 PM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????????? 1 This thread Refback 01-29-2009 11:53 AM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 4 - BENCHforum This thread Refback 01-29-2009 09:40 AM
????? ???????????????? ????????? ? ???????? -> ASP This thread Refback 01-27-2009 12:51 PM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 2 - BENCHforum This thread Refback 01-24-2009 09:13 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 01-24-2009 04:38 AM
HTC TyTN - zvani?ni WM6 - BENCHforum This thread Refback 01-21-2009 09:02 PM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 2 - BENCHforum This thread Refback 01-21-2009 08:07 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 01-20-2009 09:08 AM
mts 3G net, iskustva korisnika - Strana 7 - BENCHforum This thread Refback 01-15-2009 05:03 AM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 01-14-2009 06:08 PM
????? ???????????????? ????????? ? ???????? -> Audio snimci predavanja 2008/2009 za RTI This thread Refback 01-11-2009 09:14 AM
PocketPC sa ugradjenim GPSom i Pixma originalna mastila sa cipom - BENCHforum This thread Refback 01-04-2009 03:27 PM
PocketPC sa ugradjenim GPSom i Pixma originalna mastila sa cipom - BENCHforum This thread Refback 01-04-2009 02:34 PM
????? ???????????????? ????????? ? ???????? -> Januarski ispitni rok This thread Refback 12-28-2008 01:06 PM
MTS Postpaid -- Provera stanja *797# - BENCHforum This thread Refback 12-26-2008 12:45 PM
Core i7-920 vs Core2Quad Q9550? - BENCHforum This thread Refback 12-24-2008 02:09 PM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 12-24-2008 05:35 AM
iPhone - FAQ - Strana 2 - BENCHforum This thread Refback 12-23-2008 04:07 AM
HTC vs. Omnia vs. iPhone - BENCHforum This thread Refback 12-22-2008 04:39 PM
HTC vs. Omnia vs. iPhone - BENCHforum This thread Refback 12-21-2008 06:21 PM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 12-20-2008 09:10 AM
HP 1020, istrosio se toner posle 100 stampanja - BENCHforum This thread Refback 12-19-2008 10:33 AM
????? ???????????????? ????????? ? ???????? -> ASP This thread Refback 12-18-2008 02:07 PM
Acer Aspire one - zvani?na tema - Strana 19 - BENCHforum This thread Refback 12-18-2008 12:30 PM
mt:s bezobrazluk - BENCHforum This thread Refback 12-18-2008 10:56 AM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 12-17-2008 09:53 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 12-02-2008 03:04 AM
Connecting the Dots This thread Refback 11-17-2008 04:17 AM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 11-15-2008 03:17 AM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 11-05-2008 04:01 PM
Prius on Hymotion steroids: Highway and City Peak Oil Garage This thread Refback 10-11-2008 11:26 AM
Hymotion battery install on Monday Peak Oil Garage This thread Refback 10-04-2008 02:56 AM
Peak Oil Garage This thread Refback 10-03-2008 11:31 PM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 09-11-2008 02:42 PM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 09-11-2008 07:34 AM
EVcast #68: Interview with Danny Fleet This thread Refback 09-06-2008 02:48 AM
Recent ElectricVehicle Bookmarks on Delicious This thread Refback 09-06-2008 12:12 AM
Prius Hymotion Plug-In Conversion This thread Refback 09-05-2008 11:35 AM
YouTube - 171mpg in Prius Plug-in Hybrid Electric (PHEV) This thread Refback 08-24-2008 03:52 PM
ltzoschke's Bookmarks on Delicious This thread Refback 08-20-2008 10:20 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 08-20-2008 01:26 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 08-19-2008 02:24 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-18-2008 09:51 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-14-2008 09:34 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 06:50 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 02:19 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 12:19 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 08:53 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 08:03 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 06:17 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 05:46 PM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-13-2008 03:16 PM
GM-VOLT : Chevy Volt Electric Car Site Blog Archive GM Expects an Initial Shortage for the Volt This thread Refback 08-13-2008 09:24 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 01:36 PM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 08:45 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 08:31 AM
Method to extend Hymotion Battery by 25% rwyckoff Gen II Prius Technical Discussion 12 10-20-2008 10:51 PM
Hymotion Plug-in a123 battery pack available for consumer purchase pelewis2 Prius and Hybrid News 92 05-26-2008 08:45 PM
A123/Hymotion taking order for Prius Plug in mods this week? ualdriver Gen II Prius Main Forum 7 04-26-2008 01:47 PM
Prius plug-in displays battery of good points Proco Prius and Hybrid News 26 02-01-2008 11:32 AM
AfterMarket Plug-In company Hymotion bought EricGo Prius and Hybrid News 3 05-20-2007 02:44 PM
