This is a discussion on REVIEW: Hymotion Battery Plug-In Prius within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 1. Is this a good choice for me? If you want to save money then probably no. If you want ...
LinkBack (114) Thread Tools
Old 04-12-2009, 12:43 PM   #281
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Default Re: REVIEW: Hymotion Battery Plug-In Prius
If you want to save gas then yes.
2. can i plug it in between trips ( car avg about hr off time between jobs, then drive 10 miles to next)?
Yes you can plug it in anywhere there is an outlet and are allowed to charge. You will gain about 4-6 miles per hour of charging depending how you drive. The max charge will give you about 30-50 miles.
3. do i turn it off for those long hwy trips or leave it on?
Since you have longer trips the best way to use it is to deplete the battery on the highway and pulse and glide in town or when ever traffic allows for P&G
4. at what speed does ice turn itself on ( i do have ev mode and and do now how to use it)?
Thats a long answer. It can turn on at any speed depending on the power demand and if the EV button is being used or not.
With the Hymotion battery faking the SOC at %80 the car will try to stay in electric mode more especially if the coolant temp is >159F
TheForce is offline
Old 04-12-2009, 01:13 PM   #282
abra
Thanks for the answers.
forgot one ?
We camp out in the car durring the summer mo's. we keep the on for the a/c (set @ 74) with a 6' exhaust tub. we avg about 1.5 gallons of gas for a 8hr sleep.
can we plug in for no gas?
has this even been tried out?
abra is offline
Old 04-13-2009, 12:28 AM   #283
okpenny
What do you mean by 6' exhaust tub? Please explain.
okpenny is offline
Old 04-13-2009, 12:46 AM   #284
abra
Black tube that attaches to exhaust pipe. to remove exhaust away from car.
some people think that the exhaust fumes might enter into the car cabin over night.
its just for safty
abra is offline
Old 04-13-2009, 11:25 PM   #285
okpenny
its just for safty
Ok Thanks, I thought maybe but wasn't sure.
okpenny is offline
Old 04-14-2009, 04:18 PM   #286
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Well I had my software updated today. The guy ( Jason ) was only there for about 15-20 minutes to install the update.
I asked him what this update does and he said it lets the engine run when first started so the CAT can get warmed up. It also removes the brake light charging status. It will still light up when you first plug it in but the brake lights will go off shortly. This should help fix the issue we were having with the 12v battery being drained while charging.
After he left I started the car to see if everything still worked. I found out the battery did not turn on at all. I had about a 2 hour charge on the battery before the upgrade. So I turned the car back off and plugged it back in. an hour later I turn the car on again and found that the battery would turn on but the SOC showed only 1 bar. So I think that the SOC needs to be recalibrate. By the time I left for work I had just enough charge to make it to work with 200+MPG. Now my car is sitting out side with a 50% charge but I cant use it until the SOC gets recalibrated. I guess I will have to live with the 60MPG ride home. Hopefully a full night charge will get everything back to normal tomorrow.
Also the manual EV button still allows for EV mode at start up if needed even with this update.
I'll report back tomorrow with some more info if I have any.
TheForce is offline
Old 04-14-2009, 07:59 PM   #287
boxer93
Psyched for PHEV
boxer93's Avatar
Jay,
Thanks for the update. I need to drive to Westboro to do mine. I've been holding off since I have not reconnected my EV switch. I may splice it in so the Switch and the L5 can both control EV mode. I also hope the upgrade includes a 'delay' connecting, to eliminate the 13 flashes.
Chris
boxer93 is offline
Old 04-15-2009, 07:43 AM   #288
Flying White Dutchman
Friends: 9
unplug your 12 volt. for e few min.. this wil recalibrate the OEM battery BMS. and set it to 60%
Old 04-15-2009, 11:44 AM   #289
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Its the Hymotion SOC not the OEM SOC that needs recalibrated.
TheForce is offline
Old 04-15-2009, 03:22 PM   #290
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 22
Every thing is working fine now. The Hymotion SOC is back to normal and you can still go into EV mode at start up if you have a manual EV button. I also noticed that the battery had a few second delay when turning on. This might be a fix for the 13 flashes we was getting if we had a low 12v battery at startup. I will have to monitor this to see if it is in fact delaying the start up of the battery and if so by how many seconds.
TheForce is offline
battery, hymotion, plug-in, prius, review:
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/52157-review-hymotion-battery-plug-in-prius.html
Software update allows 70 mph in EV mode for Prius - PriusChat Forums This thread Refback 09-06-2009 06:20 PM
Tryin' to find a car using the CARS program: where'd all the fun cars go? - Page 2 - MY350Z.COM Forums This thread Refback 08-05-2009 06:07 AM
REVIEW: Hymotion Battery Plug-In Prius - PriusChat Forums This thread Refback 07-03-2009 09:23 PM
????? ???????????????? ????????? ? ???????? -> IR3SP - Sistemsko programiranje This thread Refback 03-31-2009 10:01 AM
????? ???????????????? ????????? ? ???????? -> IR3SP - Sistemsko programiranje This thread Refback 03-31-2009 07:31 AM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-27-2009 06:38 AM
Prodajem Palit 8800GT Sonic (OC) i LC 550W - BENCHforum This thread Refback 03-26-2009 07:15 PM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-26-2009 07:09 PM
Prodajem Palit 8800GT Sonic (OC) i LC 550W - BENCHforum This thread Refback 03-26-2009 05:17 PM
Da li kupce u Srbiji danas DERU ?? - BENCHforum This thread Refback 03-26-2009 04:51 PM
STA UZETI SEAGATE ST31500341AS ili WD WD1001FALS - BENCHforum This thread Refback 03-24-2009 08:16 AM
????? ???????????????? ????????? ? ???????? -> Ekspertski sistemi IR4ES This thread Refback 03-23-2009 04:06 PM
Qtek 9000 (HTC Universal) WM6 Rom pa ajd sad... - BENCHforum This thread Refback 03-22-2009 08:10 PM
Gde da kupim Logitech Lapdesk for Notebooks u BG - BENCHforum This thread Refback 03-21-2009 10:05 AM
iPod touch restore greska ???? - BENCHforum This thread Refback 03-15-2009 02:03 PM
Koji ku?ni plejeri ?itaju .mkv? - Strana 12 - BENCHforum This thread Refback 03-13-2009 07:08 PM
5800 i garmin - BENCHforum This thread Refback 03-13-2009 06:25 PM
Ford 9N, 1996 Ford Thunderbird, Ford Aspire - Mufflerclamp This thread Refback 03-13-2009 06:25 AM
992005 Chevy Gmc Tahoe Truck Console Jumpseat, Chevy Tahoe Door Parts, Carson Tahoe Regional Medical Center - Demoncow This thread Refback 03-12-2009 05:25 AM
Budget Car Rental San Diego, Budget Rental Car Uk, Budget Car Rental Tenerife South Airport - Startersalternator This thread Refback 03-10-2009 07:16 AM
Nintendo DS Lite - BENCHforum This thread Refback 03-06-2009 11:55 AM
Nintendo DS Lite - BENCHforum This thread Refback 03-06-2009 10:54 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - Strana 2 - BENCHforum This thread Refback 03-05-2009 07:04 AM
USB HUB 6+ - BENCHforum This thread Refback 03-03-2009 09:41 AM
[MTS] Promena cena u me?unarodnom saobra?aju - BENCHforum This thread Refback 03-02-2009 06:05 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 03-01-2009 07:25 PM
HDD 2.5" 60GB PATA (idealan za prenosni usb disk) - BENCHforum This thread Refback 03-01-2009 07:43 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 02-28-2009 06:12 AM
Acer Aspire one - zvani?na tema - Strana 20 - BENCHforum This thread Refback 02-28-2009 01:52 AM
????? ???????????????? ????????? ? ???????? -> IR3KDP - Konkurentno i distribuirano programiranje This thread Refback 02-27-2009 02:58 PM
WD 640gb i Pakom - BENCHforum This thread Refback 02-25-2009 10:02 AM
WD 640gb i Pakom - BENCHforum This thread Refback 02-25-2009 06:07 AM
Half-Life 2 Episode Two - Strana 4 - BENCHforum This thread Refback 02-25-2009 04:47 AM
Gde kupiti ketridz za Lexmark? - BENCHforum This thread Refback 02-22-2009 04:53 AM
Sony najavio novi eBook reader - BENCHforum This thread Refback 02-20-2009 07:55 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 02-19-2009 04:43 AM
[MTS] Postpaid - (ne)Mogucnost provere stanja - Strana 14 - BENCHforum This thread Refback 02-17-2009 12:28 PM
Windows Mobile 2005 - BENCHforum This thread Refback 02-16-2009 07:08 AM
Koji ku?ni plejeri ?itaju .mkv? - Strana 9 - BENCHforum This thread Refback 02-14-2009 01:43 PM
Digitus External SATA Docking Station - BENCHforum This thread Refback 02-13-2009 10:01 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 04:50 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 03:47 AM
Transcend StoreJet 25 radi i kad je racunar ugasen? - BENCHforum This thread Refback 02-13-2009 01:28 AM
Adapteri za laptop racunare - BENCHforum This thread Refback 02-11-2009 08:51 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - Strana 2 - BENCHforum This thread Refback 02-10-2009 08:39 AM
STA UZETI SEAGATE ST31500341AS ili WD WD1001FALS - BENCHforum This thread Refback 02-09-2009 03:50 PM
Acer Aspire one - zvani?na tema - Strana 20 - BENCHforum This thread Refback 02-08-2009 01:20 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-08-2009 06:40 AM
Toshiba A10 - kako u BIOS/kalibracija baterije? - BENCHforum This thread Refback 02-07-2009 10:07 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-07-2009 08:56 PM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-07-2009 05:29 PM
Dell Mini 9n Netbook za 249$ - BENCHforum This thread Refback 02-07-2009 04:47 PM
WD500AAKS SMART error? - BENCHforum This thread Refback 02-06-2009 07:28 PM
SATA to USB adapter, gde kupiti? - BENCHforum This thread Refback 02-05-2009 06:51 AM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-03-2009 12:07 PM
Novi best buy SAMSUNG 2343BW 16:9 dvi 220e - BENCHforum This thread Refback 02-03-2009 07:44 AM
4 monitora na jednom racunaru!? - BENCHforum This thread Refback 02-02-2009 06:29 PM
mts 3G net, iskustva korisnika - Strana 2 - BENCHforum This thread Refback 01-29-2009 05:36 PM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????????? 1 This thread Refback 01-29-2009 11:53 AM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 4 - BENCHforum This thread Refback 01-29-2009 09:40 AM
????? ???????????????? ????????? ? ???????? -> ASP This thread Refback 01-27-2009 12:51 PM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 2 - BENCHforum This thread Refback 01-24-2009 09:13 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 01-24-2009 04:38 AM
HTC TyTN - zvani?ni WM6 - BENCHforum This thread Refback 01-21-2009 09:02 PM
VAZNO: Seagate drives EPIC FAIL!!! - Strana 2 - BENCHforum This thread Refback 01-21-2009 08:07 AM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 01-20-2009 09:08 AM
mts 3G net, iskustva korisnika - Strana 7 - BENCHforum This thread Refback 01-15-2009 05:03 AM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 01-14-2009 06:08 PM
????? ???????????????? ????????? ? ???????? -> Audio snimci predavanja 2008/2009 za RTI This thread Refback 01-11-2009 09:14 AM
PocketPC sa ugradjenim GPSom i Pixma originalna mastila sa cipom - BENCHforum This thread Refback 01-04-2009 03:27 PM
PocketPC sa ugradjenim GPSom i Pixma originalna mastila sa cipom - BENCHforum This thread Refback 01-04-2009 02:34 PM
????? ???????????????? ????????? ? ???????? -> Januarski ispitni rok This thread Refback 12-28-2008 01:06 PM
MTS Postpaid -- Provera stanja *797# - BENCHforum This thread Refback 12-26-2008 12:45 PM
Core i7-920 vs Core2Quad Q9550? - BENCHforum This thread Refback 12-24-2008 02:09 PM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 12-24-2008 05:35 AM
iPhone - FAQ - Strana 2 - BENCHforum This thread Refback 12-23-2008 04:07 AM
HTC vs. Omnia vs. iPhone - BENCHforum This thread Refback 12-22-2008 04:39 PM
HTC vs. Omnia vs. iPhone - BENCHforum This thread Refback 12-21-2008 06:21 PM
????? ???????????????? ????????? ? ???????? -> IR3BP1 - Baze podataka 1 This thread Refback 12-20-2008 09:10 AM
HP 1020, istrosio se toner posle 100 stampanja - BENCHforum This thread Refback 12-19-2008 10:33 AM
????? ???????????????? ????????? ? ???????? -> ASP This thread Refback 12-18-2008 02:07 PM
Acer Aspire one - zvani?na tema - Strana 19 - BENCHforum This thread Refback 12-18-2008 12:30 PM
mt:s bezobrazluk - BENCHforum This thread Refback 12-18-2008 10:56 AM
????? ???????????????? ????????? ? ???????? -> ?????????? ?????? ????????? This thread Refback 12-17-2008 09:53 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 12-02-2008 03:04 AM
Connecting the Dots This thread Refback 11-17-2008 04:17 AM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 11-15-2008 03:17 AM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 11-05-2008 04:01 PM
Prius on Hymotion steroids: Highway and City Peak Oil Garage This thread Refback 10-11-2008 11:26 AM
Hymotion battery install on Monday Peak Oil Garage This thread Refback 10-04-2008 02:56 AM
Peak Oil Garage This thread Refback 10-03-2008 11:31 PM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 09-11-2008 02:42 PM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 09-11-2008 07:34 AM
EVcast #68: Interview with Danny Fleet This thread Refback 09-06-2008 02:48 AM
Recent ElectricVehicle Bookmarks on Delicious This thread Refback 09-06-2008 12:12 AM
Prius Hymotion Plug-In Conversion This thread Refback 09-05-2008 11:35 AM
YouTube - 171mpg in Prius Plug-in Hybrid Electric (PHEV) This thread Refback 08-24-2008 03:52 PM
ltzoschke's Bookmarks on Delicious This thread Refback 08-20-2008 10:20 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 08-20-2008 01:26 AM
PHEV (Plugin Hybrid Electric Vehicle) - Page 11 - Forum Prius Touring Club This thread Refback 08-19-2008 02:24 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-18-2008 09:51 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-14-2008 09:34 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 06:50 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 02:19 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-14-2008 12:19 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 08:53 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 08:03 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 06:17 PM
PriusOnline.com • View topic - Gen III Plug-In PHEV Prius Focus Group and waiters club! This thread Refback 08-13-2008 05:46 PM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-13-2008 03:16 PM
GM-VOLT : Chevy Volt Electric Car Site Blog Archive GM Expects an Initial Shortage for the Volt This thread Refback 08-13-2008 09:24 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 01:36 PM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 08:45 AM
REVIEW: Hymotion Battery Plug-In Prius - CleanMPG Forums This thread Refback 08-12-2008 08:31 AM
Method to extend Hymotion Battery by 25% rwyckoff Gen II Prius Technical Discussion 12 10-20-2008 10:51 PM
Hymotion Plug-in a123 battery pack available for consumer purchase pelewis2 Prius and Hybrid News 92 05-26-2008 08:45 PM
A123/Hymotion taking order for Prius Plug in mods this week? ualdriver Gen II Prius Main Forum 7 04-26-2008 01:47 PM
Prius plug-in displays battery of good points Proco Prius and Hybrid News 26 02-01-2008 11:32 AM
AfterMarket Plug-In company Hymotion bought EricGo Prius and Hybrid News 3 05-20-2007 02:44 PM
