This is a discussion on stiffening plate for $53! within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by Ytsejamer1 I just installed mine in a few minutes...easy peasy. However, did you reuse the old washers ...
Old 03-16-2009, 09:06 PM   #21
MO Dale
MO Dale's Avatar
Default Re: stiffening plate for $53!
Originally Posted by Ytsejamer1 View Post
I just installed mine in a few minutes...easy peasy. However, did you reuse the old washers with the provided screws?
I thought to check that when I put mine on, and the washers don't fit the holes. So, it seems it wasn't made for them to be reused. Once tightened, the bolts fit flush. I've got a little over a week and about 400 miles since I installed, and all is well. I don't think we have anything to worry about.
MO Dale is offline
Old 03-16-2009, 09:29 PM   #22
Ytsejamer1
Ytsejamer1's Avatar
Dale, good stuff..Thx for the info. Yeah, mine are flush and nice and tight. For $50 it seems pretty decent...actually it looks like the BT Tech unit...except someone got it off the back of their truck or something!
Ytsejamer1 is offline
Old 03-17-2009, 08:58 AM   #23
Qlara
Qlara's Avatar
What's the torque spec for the hex screws used on this G7 plate?
Qlara is offline
Old 03-17-2009, 10:32 AM   #24
Ytsejamer1
Ytsejamer1's Avatar
Not sure...I think the BT Tech plate which is pretty much the exact same thing indicated 17 I believe. I just tightened them until secure, but didn't overdo it. I then went for a drive to make sure all was good and there was nothing rattling around.
Old 03-17-2009, 12:17 PM   #25
Qlara
Qlara's Avatar
Yea, like the BT plate....guess 17 ft-lb can be used on this similar G7 too.
Qlara is offline
Old 05-03-2009, 04:30 AM   #26
djasonw
I bought the original BT plate when it first became available (back in early 05??). Can't remember. Anyway, I think the one on eBay is merely a copy of the BT plate at 1/3 the cost. IMHO the BT plate is great but overpriced.
djasonw is online now
Old 05-31-2009, 07:39 PM   #27
mameyer
These stiffening plates are a panacea! You can't bolt on a piece of aluminum and transform an engineered platform's handling! Don't waste your money on either. I did. It didn't do anything!
mameyer is offline
Old 06-02-2009, 10:01 AM   #28
Qlara
Qlara's Avatar
The placebo effect is just hard to resist.
Just do/buy whatever which makes you feel good about your Prius....
Qlara is offline
Old 06-02-2009, 10:31 AM   #29
djasonw
Normally, I'd agree with you on something like that. I am not a technical person, but one thing is certain and that plate definitely works. I always take a roundabout going to work and always noticed how the Prius leaned. Well after I installed the plate the lean was MUCH less and it cornered flatter. I definitely think it works. Is it overpriced? Yes. However, I could never imagine going back to that original OEM skimpy plate.
Old 06-02-2009, 10:57 AM   #30
Shawn Clark
Shawn Clark's Avatar
Same here. My wife noticed this as well when she drove it.
mamayer has some credibility issues anyway, this is what he said about the BT plate before:
I am in Los Angeles.
I did notice a difference: a little more composed/ less movement.
But I want more- so I want to do the whole suspension- and they have their own side to side stiffening solution that I was going to get.
Make an offer if you are interested.
Mark
About the plate in this thread, I would have ethical issues with ordering unauthorized copies of someone else's design.
Shawn Clark is online now
$53!, plate, stiffening
BT Stiffening Plate AOV Gen II Prius Modifications 11 07-17-2007 12:40 PM
English Teacher Twists OEM Stiffening Plate w/ Bare Hands, Installs BT Stiffening Plate... Free One Gen II Prius Modifications 11 04-22-2007 01:26 PM
BT Stiffening Plate versus Tom's Floor Strengthening Plate adamorzol Gen II Prius Modifications 1 04-18-2007 10:33 PM
BT Stiffening Plate Firefighter Gen II Prius Technical Discussion 20 09-06-2006 02:14 AM
