This is a discussion on ScanGauge II Questions within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I installed the ScanGauge II today. My questions what do you folks find the most helpful to set the gauges ...
LinkBack (8) Thread Tools
Old 10-18-2008, 05:26 PM   8 links from elsewhere to this Post. Click to view. #1
Goldwingerx2
Goldwingerx2's Avatar
Default ScanGauge II Questions
I installed the ScanGauge II today. My questions what do you folks find the most helpful to set the gauges to. I know I want water temp of engine but don't know what to use for the other settings. I am interested in getting even better mpg. Will be putting the grill blocking on shortly, which is why I wanted the water temp.
Thanking you all in advance for the advice.
Goldwingerx2 is offline
Old 10-18-2008, 08:33 PM   #2
sandman
sandman's Avatar
Default Re: ScanGauge II Questions
I keep the water temp on at all times now that I am blocking my grill. Some of the other ones I use are:
1. CFE(current fuel economy) this one is good because you can reset it and it also resets on its own each day. On my way to and from work I like to try different things and this allows me to see if it is helping or not without losing my MFD MPG..
2. RPM allows you to DWL up hills and also during your glides you can make sure your RPM's are at 0.
3. MPG I really like seeing my MPG go way over 99.9 MPG...
4. EV (lets you know if your EV is off/on)
Some of those are X-gauges so you will need to program them into your scangauge..
sandman is offline
Old 10-18-2008, 08:37 PM   #3
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Take a look at this thread and those that are linked from it. They should give you lots of ideas to get started and, just as importantly, to fully understand how best to interpret the readings and exploit the car's capabilities for maximum fuel economy.
JimboK is offline
Old 10-18-2008, 10:19 PM   #4
Goldwingerx2
Thanks for the help. That is exactly what I was looking for, I must not have searched correctly.
Thanks for the help!!!!
Old 10-26-2008, 07:48 PM   #5
bubbacs
bubbacs's Avatar
New Scan Gauge II today.....yeppie!
So I must jack this thread instead of starting a new one, yes I searched, but couldn't find this.
Is there a way to have the Scan Gauge II stay on?
During the 30 mile trip to work today I had to turn it back on about 60 times. :-(
Don't we want this on so we can see it?
Am I missing the intent?
Do we "Only" look @ it when we think something is wrong or needs monitoring?
I feel so newbish.....
bubbacs is offline
Old 10-26-2008, 08:40 PM   #6
maseace
Prius enthusiast
maseace's Avatar
You have to set it to "hybrid" engine type and it will be on while the car is on, and turn off automatically when you turn the car off.
maseace is offline
Old 10-27-2008, 02:08 AM   #7
bubbacs
bubbacs's Avatar
Once again, read more and post less.
And all this time, (3 months), I thought I had a "gas" engine type.
But then I didn't scroll through the gauge far enough to actually "SEE" the Hybrid choice.
Thanks maseace.
bubbacs is offline
Old 11-01-2008, 11:21 PM   #8
bubbacs
bubbacs's Avatar
Trying to stay on topic and NOT start new threads......more SG II ?'s
I was successful in adding two XGauges hope that's the terminology.
The one I was most interested in is the "SOC", state of charge.
I didn't see any adjustments or %'s to input, and while doing a short drive tonight, the "SOC" went from 54.5 to a high of 60.0.
Looking @ the "MFD" it shows a higher level than this!?
Assumeing the half way break is 50% and I had two (2) additional bars showing.
Wouldn't this be 70% "SOC"?
I've searched and now I have a headache....
Hoping for a guru to show me the light.
bubbacs is offline
Old 11-02-2008, 01:55 AM   #9
maseace
Prius enthusiast
maseace's Avatar
The charge level on the car's MFD display is not 0-100%, it's more like 40-80%. The hybrid battery is kept within a specific SOC range to extend it's useful life.
Full explanation here: http://privatenrg.com/#Full_SOC
maseace is offline
questions, scangauge
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/54749-scangauge-ii-questions.html
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 05-26-2009 04:10 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 04-17-2009 04:29 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 12-14-2008 09:24 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 11-21-2008 08:46 AM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 11-03-2008 05:21 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 11-02-2008 10:34 PM
Toyota Prius MPG-Real World Numbers - CarSpace Automotive Forums This thread Refback 11-02-2008 08:12 PM
What Four Gauges For Prius? - BlendMount Forum This thread Refback 10-19-2008 02:25 PM
ScanGauge and RPM help homerj742 Gen II Prius Modifications 10 12-04-2007 02:04 PM
European Prius 2007 Questions, questions montecarlomonaco Gen II Prius Audio and Electronics 0 10-25-2007 05:18 PM
So where did everyone mount their Scangauge?? treehggr Gen II Prius Audio and Electronics 17 09-11-2007 02:46 PM
ScanGauge II - NIB - $130 mpgFanatic Private Sales 2 07-17-2007 09:08 PM
Scangauge- Need Help Tyrin Gen II Prius Fuel Economy 4 06-12-2007 05:01 PM
