This is a discussion on 16" Tiuring Wheel Trim Rings within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; [Edit] Oops, sorry about the misspelling in the title.] When the subject of trim rings comes up, it has always ...
Old 10-26-2008, 08:13 PM   #1
Rokeby
Rokeby's Avatar
Default 16" Touring Wheel Trim Rings
When the subject of trim rings comes up, it has always been for the 15"
standard wheels.
There is however a 16" chromed ABS trim ring available that fits the Touring
wheel:
Flat Narrow Chrome Trim Rings Stylish Look, Great Prices, AutoAmenity
If you look carefully at the pictures showing what wheels the rings will fit, the
first picture is the 16" Touring wheel.
For additional pictures of these trim rings on a Prius, go here:
PriusChat Forums - metagrey's Album: A Few Changes
This info orignally from metagrey, who made a single unrelated post
on 9.01.08. This important tidbit is from a PM exchange we had: "You need
to use a rubber mallet to get them on, as the clips are a little tight on the
prius' alloy wheels."
These rings could be used stand-alone, or as a foundation for mounting
aero discs. Flat discs made from pizza pans wont work because the center
of the wheel sticks out past the rim's edge.
Thank you, metagrey.
Rokeby is offline
16", rings, tiuring, trim, wheel
Wheel Trim Rings Reid Gen II Prius Main Forum 8 10-19-2008 06:20 PM
"Real" reason to remove wheel trim rings David Beale Gen II Prius Main Forum 28 09-10-2007 12:04 AM
FS: Set of 4 new wheel trim rings hyacinth Private Sales 1 02-13-2007 02:00 AM
Ditching your wheel trim rings? Bob Allen Gen II Prius Modifications 4 02-07-2007 06:23 PM
So THAT's what those wheel trim rings are for! kjb516 Gen II Prius Main Forum 2 07-10-2004 01:18 PM
