| This is a discussion on Help on Rims: size question within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Would 17x7.5 rims fit on the prius? What tire size recommendation would I go with on this set up? Any ... |
| Junior Member Join Date: Jul 2007 Location: Southern California
Friends: 0 | Would 17x7.5 rims fit on the prius? What tire size recommendation would I go with on this set up? Any help is greatly appreciated. |
| Senior Member Join Date: Feb 2007
My Car: 2004 Prius Model: Package: #7 Thanks: 2
Friends: 0 | I don't know about 7.5", but a quick look on tirerack.com shows that 17"x7" will fit, and using 205/45 x 17" tire. Look further on tirerack and you may find 7.5" Your investments must be doing better than mine! PA P |
| Member Join Date: Aug 2008 Location: las vegas, nv
My Car: 2005 Prius Model: Package: #1 Thanks: 0
Friends: 0 | yes 17" x 7.5" wide rims would work |
| Junior Member Join Date: Nov 2008 Location: Osaka, Japan
My Car: 2008 Prius Model: Package: G Touring Thanks: 1
Friends: 0 | |
| Pursuing Perfection Join Date: Feb 2008 Location: Torrance
Friends: 0 | Agreed 17x7.5 with a 215/45/17 tire will fit but please dont forget about the wheel's offset |
Friends: 0 | agreed. offset is very important. it doesn't have to be precise on a 17" or 18" on the prius as to other applications though, but it needs to be in a general vicinity. like my cts, i have 22's and its such a precise fit that even a little off will cause problems. i run a +40 offset on my cts and even a +38 will not work w/o modifications. but on the prius if your running a 17" rim you could probably go within -10 to +10 without any problems. it just matters how flush you want them to sit. also 205/45/17 would be the closest overall height to the stock tires. stock tires are: 185/65/15. which gives the overall height of 24.47" 205/45/17 would give you an overall height of 24.30" and the 205 width is ideal for a 7.5" rim
__________________ http://www.cardomain.com/id/mrplease |
Friends: 0 | Thanks for all the information everyone. The wheels I'm looking at has an offset of +48. Will that work? |
| question, rims, size |
| Question about steel wheels / rims? (For winter wheels and tires)... | AdamKPL | Gen II Prius Main Forum | 2 | 09-02-2008 05:41 PM |
| Tire size Vs. Wheel size | Wa1hog | Gen II Prius Care, Maintenance and Troubleshooting | 2 | 08-05-2008 10:47 PM |
| WTB Touring Rims or trade my Scion TC rims | murdog | Private Sales | 0 | 05-19-2008 07:39 PM |
| Rims and tires question | YoDaddyAlex | Gen II Prius Main Forum | 13 | 04-14-2007 05:03 PM |
| Question about interior size/feasibility of Prius. | ericab819 | Gen II Prius Main Forum | 17 | 06-20-2006 01:21 AM |
