This is a discussion on Engine Block Heater Cap within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Got one here in MN USA @NAPA Auto Parts store. NAPA PN 605-1545 $5.99 plus tax. Bag label: "Made in ...
Old 10-28-2009, 11:36 AM   #11
recycler
recycler's Avatar
Arrow Re: Engine Block Heater Cap
"Made in Canada, UAP Inc., Montreal, Quebec H1N 283. Mfg
for Balkcamp Inc. Corporate Office: Indianapolis, IN 48241"
Of course, you can get in online @napaonline.com
Originally Posted by Rangerdavid View Post
Has anyone here ever lost the plug cap off your EBH?? I havn't lost mine, yet... but I started wondering if the plug caps were available separately, or if you just got a "make do" cap from the home improvement store?
thanks.....
RD
recycler is offline
Old 10-28-2009, 04:18 PM   #12
PaulHS
Prius named PHriuS
PaulHS's Avatar
Default Re: Engine Block Heater Cap
This solution won't necessarily stop the absentminded from backing out without disconnecting the power cord, but it will eliminate fraying of the wires at the EBH plug end.
I made an 8" extension with a regular female socket on one end, to connect to the EBH plug. For the other end I used a male plug from a PC power supply (as shown on the left in the first picture). This plug I mounted behind the small grille section next to the foglamp. The female end of the PC power cord (on the right in the first picture) slips perfectly between the louvers of the grille to plug into the recessed plug. For an equivalent of the "cap", I cut the female end from another PC power cord to plug into the recessed plug to keep out rain, bugs and debris while on the road.
Works great and is much easier to connect and disconnect.
BTW, if anyone needs a cap, I have two that I won't be using.
Engine Block Heater Cap-100_0791.jpg   Engine Block Heater Cap-100_0792.jpg   Engine Block Heater Cap-100_0794.jpg
Paul
Silenced backup & seatbelt beeps /
All door unlock / Shaved rear windshield wiper cover / Tire Pressure 44/42 / Custom front floor mats / Scangauge II / "Prius" license plate frame / Blocked grille / WeatherTech Cargo Liner Mat / HeatShield Sunshade / Custom Hood for MFD / EBH / Prius Hoods Leather Console and Front / Rear Armrest Covers / CE28 Eco Drive Wheels
PaulHS is offline
The Following User Says Thank You to PaulHS For This Useful Post:
2009Prius (11-03-2009)
Old 10-28-2009, 04:45 PM   #13
patsparks
An Aussie perspective
patsparks's Avatar
Friends: 33
Paul, you're a bloody genius!!
That is brilliant!
Looking up the address for Nobel Foundation now, your going to be a nominee!
If the president can do it ...
patsparks is online now
Old 10-29-2009, 01:24 PM   #14
PaulHS
Prius named PHriuS
PaulHS's Avatar
That is brilliant!
Pat, your comments are so over the top, I can't tell whether you're serious or sarcastic.
PaulHS is offline
Old 10-30-2009, 01:08 AM   #15
kenoarto
kenoarto's Avatar
Have actually found a source for the entire new harness at $15? Mine is dead and I'd love to buy a new one.
Most of the vehicles here have lost the cap over the plug, ages ago. The cap may protect the plug, but there are plenty of other ways to ruin a plug, not just backing out without unplugging first
The flexing of the plug every time you plug in, and unplug, will eventually break the stranded wires inside. I've never got more than 3 years out of a block heater plug before having to replace it. If easy to get to, I just get an entire new harness, usually under $15, and plug it in to the block heater frost plug...
kenoarto is offline
block, cap, engine, heater
Engine Block Heater Raider Gen II Prius Modifications 3 09-20-2008 02:39 PM
Engine Block Heater bestmapman Gen II Prius Care, Maintenance and Troubleshooting 15 08-03-2008 12:13 AM
engine block heater rookie101 Gen II Prius Technical Discussion 11 03-23-2008 01:36 PM
Engine block heater gazz Gen II Prius Technical Discussion 21 05-26-2007 09:00 PM
Engine Block Heater chiprius Gen II Prius Modifications 1 04-08-2006 01:42 PM
