This is a discussion on B&G Suspension S2 Sports springs now available for the 04-09 Prius within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by wicastawakan It all sounds good, except the 1" lowering. I live in a rural area & ground ...
LinkBack (1) Thread Tools
Old 05-16-2009, 03:04 AM   #71
DaveLadely
Lightbulb Re: B&G Suspension S2 Sports springs now available for the 04-09 Prius
Originally Posted by wicastawakan View Post
It all sounds good, except the 1" lowering. I live in a rural area & ground clearance can be a problem & I couldn't drive my car during an ice storm this winter, took 45minutes to make 7 miles in my 4wd pickup.
I have stongly been considering the skid plate as protection. Do you make an improved spring without losing ground clearance? It simply is not acceptable in my environment. Sounds like the easiest way to improve my suspension.
An advantage of progressive springs over the stock linear springs is that the progressive springs will progressively resist bottoming out whereas the stock springs don't, and so stock springs can allow the car to get very low. The handling is vastly improved, way less tipping, much better control around curves, turns. I added Air Lift air bags that fit inside the coil springs. The air bags can be used to lift the car an inch or more by more inflation. Also the front and rear air bags can be inflated separately, so the rear bags can be inflated further, for leveling the car with a load, for example, and also allows greater load carrying capacity. The air bags are FAR superior to any "air shocks".
Just measure the diameter of the coil spring, front and rear, and Air Lift can supply the appropriate air bags as they are not listed specifically for the Prius. They also offer a compressor which allows inflating while driving, etc. With air bags on any springs, stock or progressive, bottoming out is prevented by the progressive resistance to the loading that air provides. And they are very inexpensive, work great! The combination of compressive springs and Air Lift air bags makes a huge difference, more improvement than a stiffer anti-sway bar. Anti-sway bars can have a negative effect on steering.
Progressive springs generally have a quicker rate than stock, so replacing stock shocks with fast acting gas shocks are highly recommended! Altogether, they make the Prius handle far better with negligible detractions of ride. In fact, progressive springs tend to have a smoother ride when not pressed and will provide a lot more control, preventing lurching, etc, increasing confidence, when the road gets rough, and greatly reduces tilt/tipping, a great benefit.
DaveLadely is offline
Old 05-19-2009, 09:13 PM   #72
DaveLadely
will provide further resistance to scraping, especially since air bags can be inflated to compensate, and can provide lift to the car. Since the spring rate is increased, a fast responding gas shock/strut should also be purchased, manufacturer can be buyer's choice as long as it is fast responding. Eibach can advise, 800-507-2338
PRO-KIT (PERFORMANCE LOWERING SPRINGS) 1.4 in 1.0 in Number: 8298.140
PRO-ALIGNMENT KIT Rear +/- 1.5 deg. of camber & toe adjustments. Number 5.75800K
PRO-ALIGNMENT KIT Front +/- 1.75 degrees of adjustment. Number 5.81270K
The lower ride height does improve economy due to less drag, also the lower center of gravity adds to the handling improvement.
When I bought Eibach springs for my van, I also installed inexpensive but high quality Air Lift air bags that fit inside the coil springs, eliminated bottoming out, ride improved, was able to raise and lower front/rear, such as adjusting for loads so that headlights aim correctly.
I believe the Eibach springs will work on both the basic and touring Prius models, but check with Eibach for any questions.
I called Eibach today, the springs do work on 04-09 basic and touring Prius' and the alignment kits are necessary for any springs that lower the car as there are no adjustments on stock Prius'. The alignment kits allow adjustment, which is a bonus for cars like the Prius where otherwise you can't align the car period!
Old 06-17-2009, 08:08 PM   #73
Ken@kobetoba
Package: G Touring
Default Re: B&G Suspension S2 Sports springs now available for the 04-09 Prius
Whoever interested please PM me or Ken@kobetoba.com
Ken@kobetoba is offline
Old 06-18-2009, 11:51 AM   #74
turnerdhr
HellaFlush(TM) Prius
turnerdhr's Avatar
Package: Premium (Europe)
Friends: 26
Hey Ken... Please check your email.
Thank you...
turnerdhr is offline
Old 07-02-2009, 06:36 PM   #75
B&G Suspension
B&G Suspension's Avatar
Whats up guys just got a new conatiner of Prius springs instock!
B&G Suspension is offline
Old 07-02-2009, 07:09 PM   #76
tinyfoot
1" lowering?
fit 2008 touring?
tinyfoot is offline
Old 07-06-2009, 02:29 PM   #77
B&G Suspension
Originally Posted by tinyfoot View Post
1" lowering?
fit 2008 touring?
yes and yes
0409, bandg, prius, sports, springs, suspension
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/59580-b-g-suspension-s2-sports-springs-now-available-04-09-prius.html
B&G Suspension - Page 4 | BoardReader This thread Refback 05-04-2009 03:05 PM
Progressive rear springs for Prius? nfschlaack Gen II Prius Technical Discussion 1 05-21-2009 02:37 AM
B&G Suspension S2 Sports springs now available for the 04-09 Prius B&G Suspension Sponsored Commercial Sales 0 03-18-2009 01:57 PM
Why can't they make the Prius technology into more of a sports car? pphil09 Gen II Prius Main Forum 19 07-10-2008 05:24 PM
I have new TRD suspension- anyone want my old (100miles) 2007 touring suspension? freesolar Private Sales 20 09-26-2007 08:12 PM
FS: '06 Prius Shocks/Springs hngu7721 Private Sales 1 02-01-2006 02:45 AM
