| This is a discussion on Help: Need Part Number for Front Dome Circuit Board within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi everyone, I desperately need some help. The front dome circuit board, which contains the map and dome bulbs, is ... |
| Junior Member Join Date: Apr 2006
Friends: 0 | Hi everyone, I desperately need some help. The front dome circuit board, which contains the map and dome bulbs, is cracked. I tried to replace a bulb and put too much pressure on the center location, causing a crack in the circuit board. Does anyone know the part number and where I can buy a new front circuit board. Here is a picture for reference. (borrowing pic from evnut) |
| Senior Member Join Date: Aug 2008 Location: Phoenix, AZ
My Car: 2009 Prius Model: N/A Package: #5 Thanks: 0
Friends: 1 | If someone doesn't chime in with a part number, you should try a slavage or junk yard. You'd likely buy one there for $10 or so and I'm sure a replacement from Toyota would set you back6 or 8 times that much. |
Friends: 0 | Thanks. I've thought about calling some salvage yards but locating one with a prius might not be as fast as just ordering the part from toyota. |
| Senior Member Join Date: May 2007 Location: Phoenix, AZ
My Car: 2007 Prius Model: Package: #5 Thanks: 54
Friends: 0 | This site doesn't show a separate part number for just the board. The whole assembly is $131 or $301 depending on whether it has the NAV microphone or JBL. 81260‑47010‑A0 NHW20; IVORY, TRIM0* 1 $131.53 81260‑47010‑B0 NHW20; GRAY, TRIM1* 1 $131.53 81260‑47010‑E0 NHW20; GREGE, TRIM4* 1 $131.18 81260‑47030‑A0 NHW20..USA; EMV(W/NAVIGATION SYSTEM)-WITH, IVORY, TRIM0* 1 $301.18 81260‑47030‑B0 NHW20..USA; EMV(W/NAVIGATION SYSTEM)-WITH, GRAY, TRIM1* 1 $301.18 81260‑47031‑B0 NHW20; AUDIO-05AM/FM+CD-CHANGER JBL 9 SPEAKER, GRAY, TRIM1* 1 $301.18 81260‑47031‑E0 NHW20; AUDIO-05AM/FM+CD-CHANGER JBL 9 SPEAKER, GREGE, TRIM4* 1 $301.18 |
| Thanked by: | peach (04-13-2009) |
Friends: 0 | Thanks for the link. I decided I will try to have someone solder jumper wires on the board to see if that works. I did not have any luck locating a salvage yard with a prius. Thanks again. Quote:
My Car: 2004 Prius Model: N/A Package: Base Thanks: 203
Friends: 36 | Good luck with that, sounds like the way to go. How do you remove the roof console? |
| board, circuit, dome, front, number, part |
| Key blade part number? | snijd | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 07-19-2008 10:36 AM |
| Part number? | emery | Gen II Prius Modifications | 0 | 08-27-2007 12:24 AM |
| Center Cap Part Number! | aldo | Gen II Prius Main Forum | 0 | 08-21-2007 07:19 PM |
| Looking for a part number... | yarzy | Gen II Prius Main Forum | 2 | 10-16-2006 06:03 PM |
| Any Techs know what this part number does? | Tempus | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 07-22-2006 11:49 AM |
