| This is a discussion on Bartlett Corporation Leather on Ebay - $150! within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by sl7vk Well, I'm of the opinion that the back seats are harder than the front. I've attached ... |
| | #201 | |
| Senior Member Join Date: Aug 2006
My Car: Model: Package: Thanks: 4
a) you can still drive the car while working out what to do b) It's good practice c) If you dont get it quite right it's less noticable than the fronts d) after doing 200 hog rings/tie wraps you'll be relieved when doing the fronts. You do have to work out a plan of attack. When reassembling-the inner most hog wrings tie wraps first. For removal the original covers I didnt cut all the old hog rings. I unbent one end of the wire rod going through them then pulled the rod out from the other end. You can then decide whether to unbend all the old hog rings or leave them. There are loads of sharp metal edges - be very careful! The back of the rear seats is bad but you dont really have to get your fingers near them The front seats -you have to rotate the leather around the front edge which is just waiting to slice your hand off. Managed it ok - but be very aware. All the covers need cutting of the leather for inserting the headrest holders. Do this after youre sure you have the cover correctly in place and feel along the top edge for the hole in the seat back. Make a small hole first, you can feel through that with a small electrical screwdriver. Then carefully cut an X in the leather to the corners of the seat hole. The headrest holders can go in the wrong way & the headrests wont lock! Last edited by prius2go; 05-10-2009 at 04:40 AM. | |
| The Following 4 Users Say Thank You to prius2go For This Useful Post: |
| | #202 |
| Junior Member Join Date: Mar 2009 Location: PA
My Car: 2009 Prius Model: Package: #2 Thanks: 8
Friends: 1 | I've done the rear seat and found 2 problems. One was already discussed here... the extra wire... I chose not to use the extra wire but use the plastric that was on the leather. Another problem I found was that there weren't any holes for the 2 hooks that are used to connect to the vehicle body. It wasn't bad... Just had to cut 2 places and let the hooks thru... |
| | #203 |
My Car: 2007 Prius Model: Package: #2 Thanks: 165
Friends: 22 | prius2go, Wow, your tips are invaluable, e.g., -- Front Seat Side: Finding and removing that little front seat screw so that you don't break that one-way screw/clip. -- Carpet Clips: Your explanation of how upholsterers remove those molly type carpet screws with something akin to a BBQ fork to go in beneath the head to squeeze the screw's prongs; and your suggestion of using a knife instead to squeeze one side of the screw's prongs. -- Headrest Holder Holes: Fit the leather first, then carefully cut an X (not a big hole) .... The infrequent times I work on my car, I always find that I spend at least an equal amount of time trying to figure out those types of things, especially all the plastic screws, clips, tabs, etc. on the car, as I spend doing the real work.
__________________ Best regards, Tom 07 Magnetic Gray #2 - GY TripleTreds 195/60R15, BT Tech Stiffening Plate & Strut Tower Brace, Philips X-Treme Power Headlights, Webasto 4300 Sunroof, Sharkfin Antenna, Chrome Wheelskins Wheel Covers & Door Handles, BumperDefender.com Bumper Guard Strips, Body Side Moldings & Rear Bumper Protector, NoBump.com License Plate Screw Bumpers, Bumper Bully, Sheepskin Seat Cover, Leather Steering Wheel Cover, Leather Center Console Cover, Center-Hump Litter Basket, Non-Slip Pads, Dalmatian Bobble Heads. |
| | #204 |
| Senior Member Join Date: Jul 2006 Location: Salt Lake City
My Car: 2006 Prius Model: Package: #3 Thanks: 2
Friends: 1 | Anyone tackled the fabric that is to the side of the two rear seats? I'm scratching my head a little bit on how to attack these........ |
| | #205 |
| Senior Member Join Date: Mar 2009 Location: Queens, NY
My Car: 2009 Prius Model: N/A Package: #2 Thanks: 72
Friends: 1 | Does anyone know how this leather compares with an OEM Prius leather seats? Just curious if anyone has had the opportunity to see/feel both to make a comparison. |
| | #206 |
Friends: 59 | Here are pics I took during the day (Saturday work) and the driver's seat (took 5 hours). I get to enjoy the leather seats starting from tomorrow! ![]() ![]() ![]() ![]() ![]()
__________________ Prius shaped the form of future cars. Hybrid Synergy Drive is the engine of change that moved us forward. Kyowa KR206 17" Black Chrome Lips | Sherwood Wood Dash (Birds Eye) | Infinity 6020CS Front | Kappa 62.7i Rear | B-Quiet Ultimate | LED Interior+License Plate | EV Button | Auterra Dyno Scan | Professionally Self-Installed Leather |
| | #207 |
Friends: 22 | Congrats usbseawolf. Looking good! Suggestions: 1. Go back to the PriusHoods black leather center console cover? 2. Consider getting black rubber or carpet mats like on the 2010 Prius Misty Gray interior? |
| | #208 | |
Friends: 1 | Quote:
Between a mad scramble to get this car done so that I can drive to work tomorrow, and getting a mothers day gift for my wife.... I made it! Only thing left is the door arm rests. I think that'll be for next weekend! What a ton of work. Whatever it is that they charge for this type of god awful work.... It's too little.... | |
| | #209 |
Friends: 1 | Late night photo (pardon the flash) of the fabric section that is below the vent redone...l For those that have done, or are doing this.... I feel like I'm part of a blood order with you.... I think we've all seen things, and done things, we'd rather forget during this ordeal...... Only time will tell if it was worth it! |
| The Following 2 Users Say Thank You to sl7vk For This Useful Post: | Boo (05-11-2009), PriusLewis (05-11-2009) |
| bartlett, corporation, ebay, leather |
| ebay leather interior | omgitsroy326 | Gen II Prius Main Forum | 42 | 02-01-2008 03:30 PM |
| 625 corporation | bwilson4web | Fred's House of Pancakes | 1 | 10-18-2007 08:27 PM |
| Stay away from ACCESSORIESRUS on eBay for interior Leather | Virodeath | Gen II Prius Modifications | 5 | 10-10-2007 07:24 AM |
| Second Bartlett Speech to Congress on Peak Oil | thorn | Prius and Hybrid News | 6 | 04-21-2005 06:11 PM |
| Congressman Bartlett Discussed Peak Oil Last night | thorn | Prius and Hybrid News | 0 | 04-21-2005 10:48 AM |
