This is a discussion on BT Tech stiffening plate bolts size? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I bought a BT tech stiffening plate from a PC member, but it does not have the 4 allen headed ...
Old 05-18-2009, 02:41 PM   #1
johntpr
Default BT Tech stiffening plate bolts size?
I bought a BT tech stiffening plate from a PC member, but it does not have the 4 allen headed stainless steel attaching bolts. Can anyone tell me of another source for them and know the size, thread and overall length of them? I've heard the tragic news that Brain from BT Tech died May 9th, so I'm not sure if the business will continue.
johntpr is offline
Old 05-18-2009, 04:15 PM   #2
KK6PD
_ . _ . / _ _ . _
KK6PD's Avatar
Friends: 11
Default Re: BT Tech stiffening plate bolts size?
Well its 4 METRIC Hex Socket Screws. Stainless M8 X 25mm It takes a 6MM hex drive socket to install, here are the specs of the screws I would use...
$8.04 per Pack of 25
Head Style - Standard
Standard Head Style - Standard
Material Type Stainless Steel
Finish Plain - Class Not Rated
Stainless Steel Type - 18-8 Stainless Steel
Drive Style - Hex Socket
Metric Thread Size - M8
Metric Thread Pitch - 1.25 mm
Length - 25 mm
Thread Length - Fully Threaded
Thread Direction - Right Handed
Tip Type - Plain
Self-Locking Method - None
Screw Quantity - Individual Screw
Hex Size - 6 mm
Head Diameter - 13 mm
Head Height - 8 mm
Rockwell Hardness - Not Rated
Minimum Tensile Strength - 101,000 psi
Thread Fit - Class 6g
Specifications Met - Deutsche Industrie Normen (DIN)
DIN Specification - DIN 912-A2
You can buy them here...
McMaster-Carr
or print out the specs and run to a Hardware store that sells Metric Hex Socket Screws.
Just be sure you buy the STAINLESS ones. The key numbers are "M8" & "25 mm" length.
The price you pay at the store may how ever, may make buying the 25/bag at McMaster Carr a better deal.
You could sell the extras to other chatters perhaps!
73 de Pat KK6PD
KK6PD is offline
Old 05-18-2009, 04:48 PM   #3
johntpr
Thanks so much!
Length - 25 mm
Tip Type - Plain
Hex Size - 6 mm
Head Height - 8 mm
McMaster-Carr
johntpr is offline
Old 05-31-2009, 07:42 PM   #4
mameyer
Don't waste your time on a stiffening plate! A simple bolt on piece of aluminum isn't going to do anything for the handling. Stop giving BT Tech money for nothing!
mameyer is offline
Old 05-31-2009, 07:55 PM   #5
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
And how do you know that without trying it?
hyo silver is offline
Old 06-02-2009, 10:45 AM   #6
Shawn Clark
Shawn Clark's Avatar
That's interesting, because it's not what you said before:
I am in Los Angeles.
I did notice a difference: a little more composed/ less movement.
But I want more- so I want to do the whole suspension- and they have their own side to side stiffening solution that I was going to get.
Make an offer if you are interested.
Mark
So which time were you lying?
And for the record, I have the plate and have been pleasantly surprised by the degree of improvement it has made in my car's handling. I expected less.
Shawn Clark is offline
Old 06-02-2009, 09:20 PM   #7
Dobey
And of course, you also put on the record that your observation is as good as a double blind test and instrumented measurement, right? Right?
Dobey is offline
Old 06-02-2009, 11:06 PM   #8
Shawn Clark
Begone, Troll!
EDIT:
By the way, for those who are wondering, the following is what Dobey posted with respect to my consideration of rear stiffening plate to address highway instability in winds.
If you can afford it, try the front strut brace instead... you can get either the Tom's or C-One at sigmaauto.com. I have the Tom's and it really does make a big difference not just in crosswinds but in turns and tracking as well.
Then he spent much of the rest of the thread arguing that body rigidity will have no effect on tracking in crosswinds and that folks like myself were just fooling ourselves into believing there was a difference. Go figure. Self-consistency isn't his strong point.
In the thread quoted there are quite a few who observed improved handling with the rear plate. As with any other mod, YMMV.
He does seem to have it in for the BT products though...same as mameyer. Interestingly, mameyer contradicted himself in exactly the same way. You just can't make this stuff up folks.
bolts, plate, size, stiffening, tech
BT Tech Stiffening plate BethlehemPrius Gen II Prius Modifications 1166 03-07-2008 12:56 AM
BT Tech Stiffening Plate moshe1436 PriusChat Shop Forum 6 06-26-2007 08:52 AM
BT Tech Stiffening Plate kayemarschke2 Gen II Prius Main Forum 3 05-13-2007 10:28 PM
WTB: used BT Tech stiffening plate or TOM's bars wenjen54 Private Sales 0 01-22-2007 07:02 PM
BT Tech stiffening plate question dmarcus123 Gen II Prius Modifications 106 11-22-2006 02:23 PM
