| This is a discussion on Driver's Seat Remount at Home - 2 5/8" Back within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; 3 month follow up - Was in grumpy mood this morning and wishing for even a little more legroom reach ... |
| | LinkBack (4) | Thread Tools |
| | #41 |
| Prius Aficionado Join Date: Apr 2008 Location: Union City, CA
My Car: 2009 Prius Model: N/A Package: #5 Thanks: 27
Friends: 4 | 3 month follow up - Was in grumpy mood this morning and wishing for even a little more legroom reach to brake pedal while driving to the store. I'm pretty hesitant to move the seat back the last click due to non-telescoping steering wheel. So, at work, I'm kinda thinking, geez is it really going to work out with this car? Anyrate, after work, clicked the seat back that one last notch, drove the freeway South to Fremont. Stopped at Fremont Mazda to compare the steering wheel reach in mine to a Mazda3 hatch set up optimally. The steering wheel reach is maybe 1 - 1.5" less in the Mazda. Interestingly, the legroom in mine can match the Mazda3 which basically has sports car legroom, although its seat can go a little lower than mine. I still have a few tricks to lessen the reach to the wheel.
__________________ Brett 09 Spectra Blue Mica Package #5 : 06 Prius driver's seat - remounted 2 5/8" back, 7/8" foam added in headrest covers, inverted auto-dimming rearview mirror Last edited by cycledrum; 09-11-2009 at 12:22 PM. |
| | #42 |
Friends: 4 | post deleted Last edited by cycledrum; 09-11-2009 at 12:22 PM. |
| | #43 |
Friends: 4 | Well, for 3 weeks I tried getting comfortable using the 4th and last click back on the seat, but it's a 'no go' - the steering wheel reach is just too far for comfortable driving and there's no fixing that. So, lack of telescopic steering adjustment spoils the mod somewhat. 3 clicks back is decent which is exactly 2" further from stock max position, and of course much better than stock for me. At 4 clicks, I moved the seatback forward one extra notch for decent reach to wheel, but got tired of looking down on the dash. Interestingly, the 2009 Scion xB has tons of legroom with height adjuster and generous seat travel, but it lacks a telescopic steering wheel, so that 1st class legroom is mostly for nought (and I have long arms, so I'm a pretty good judge of this). For a relatively pain-free seat remount, get these ... REVIEW: ExtendMySeat driver's seat extenders Last edited by cycledrum; 09-11-2009 at 11:36 PM. |
| | #44 |
| Junior Member Join Date: Oct 2008 Location: Florida
Friends: 0 | I was disapointed with drivers leather seat in 08 Prius. Bad back inflamed with seat. Tempted to sell, so I bought an 06 pontiac Vibe. (all Toyota.) Seat is cloth and comfortable, and fully manually adjustable. Can I get an electric power seat from salvage yard to fit the Prius? Instead of welding I can transision the rails with bolts and flat iron. |
| | #45 | |
Friends: 4 | Quote:
Good news is, the 'extendmyseat.com' brackets sold here on Priuschat shop have a solid brackets, one for the entire right side, one for left. I think they would be very sturdy and will allow you to slide seat back up to 4" further without any welding involved, just bolt brackets, seat in. About seats, power seat from a junkyard - any other seat likely would not have the same electrical connections for seat position, seatbelt and airbag as the Prius, and would not bolt into the Prius floorboard. It's easier to remount the Prius seat if need to and dress it up with seat cushions, wedge cushions, lumbar supports, etc... Couple of people here actually morphed a Corolla seat with height adjuster into a Prius seat, mounted into their cars. Mad skills though. btw, I would have bought the extendmyseat brackets except they came out a month or so after I finished this mod. A little surprising it took 5 years for someone to build a set of remount brackets. Ah well. Last edited by cycledrum; 10-31-2009 at 10:17 PM. | |
| | #46 |
Friends: 4 | post deleted. Last edited by cycledrum; 10-03-2009 at 09:06 PM. |
| | #47 |
Friends: 4 | Finally ditched using my 'custom seat cushion' this week. Although the seat is not great (it's still a Gen2 seat afterall), it works well enough, and still much improved over stock for me. Last edited by cycledrum; 10-16-2009 at 12:07 AM. |
| | #48 |
Friends: 4 | I fixed a minor problem with my driver's seat headrest by putting a 3/4" thick rectangle of dense foam sandwiched between the headrest and its cover (I have a 'one size fits all' seat / headrest cover) I used to think the best seatback angle is when the headrest is fairly close to my head, but this is not correct, IMO. Many cars headrests end up a bit too far behind a driver's head which is not good, because if you get rear ended, you're head will snap back upon impact (this happened to me in 1991), and you'll end up with a whiplash injury. Adding 3/4" of foam has brought the headrest closer and will do more to protect against whiplash. And I can lean the seatback a little extra the way I like it ... a bit of gangsta lean. Cost of 3/4", 7/8" and 1" foam all in 4" x 12" .... dirt cheap - $4.29 including the cutting at Bob's Foam Factory Last edited by cycledrum; 10-25-2009 at 12:23 PM. |
| | #49 |
Friends: 4 | Whewwwwwwwww..... After 14 months and 4 days of 2009 Prius ownership ... I am finally comfortable enough in my driver's seat for the first time! So this is what thigh support in a Gen2 Prius feels like! During the first seat mod attempt and before the modification in this thread, I added, to my detriment, this thing on the gas pedal ... ![]() It has 1/2" foam underneath the pedal pad. I took it off yesterday and voila, I gained back space to stretch my leg forward, not sideways. Now I've got thigh support! Last edited by cycledrum; 11-07-2009 at 10:09 PM. |
| | #50 |
Friends: 4 | Well, I'm pretty darn sure I am going to fashion a height-adjustable Toyota driver's seat to put in my 2009 Prius. PC'er 'nyprius' said it years ago after having his remount or shift back of the seat mod done ... that he really wished the seat had height adjustment. He made many posts expressing a lot of frustration that Toyota left out the height adjustment which the Gen2 sorely needs being that it has a fairly low top of windshield, and not much tilt to seat bottom. The height adjuster tilts down the seat bottom as it moves back some. So, my plan goes like this * Buy a used Corolla driver seat out of an 03 -08, gray fabric, LE or CE model, not S. Looking for a nice used one. Cost about $150. I've located a dismantler within 150 miles that has like 11 Corolla driver seats. * Also buy another used Prius driver seat with airbag, because I will not touch my original seat in any way, and I won't touch my already modified used seat, in case this whole Corolla seat thing doesn't work out. Cost over $200. * Use an upholstery shop to remove airbag from left side of used Prius driver seat. Install that airbag onto the Corolla seat much like PC'er Solar_Powered did. * Move the Prius seat belt latch and wiring and seat position sensor over to the Corolla seat * The Corolla upholstery will be left intact as I use generic seat covers on the front seat. Then start the metal work of removing mounting feet from both seats. I will have the metal shop fab another seat of braces or 'rail extenders' for the front of the Corolla seat. This time I'll use a thicker gauge of metal, something near 1/4" Have the 4 Prius feet welded onto the Corolla seat At this point I should be ready to mount the Corolla seat in, plug in and hit the road. I would really like for this to work out as I seriously want to sit lower in this Prius, the way I should be sitting in the car, like in the 2010 model. I'll keep ya posted. Last edited by cycledrum; 11-07-2009 at 10:46 PM. |
| back |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-modifications/62153-drivers-seat-remount-home-2-5-8-back.html | ||||
| Web Server Statistics for extendmyseat.com | This thread | Refback | 07-08-2009 12:05 PM | |
| SMR 6/6/09 - Page 2 - South Bay Riders | This thread | Refback | 06-08-2009 11:05 AM | |
| SMR 6/6/09 - Page 2 - South Bay Riders | This thread | Refback | 06-08-2009 03:35 AM | |
| SMR 6/6/09 - Page 2 - South Bay Riders | This thread | Refback | 06-08-2009 02:17 AM | |
| Driver's Seat Remounted 3.75" Back | cycledrum | Gen II Prius Modifications | 44 | 08-28-2009 02:02 AM |
| Seat Height Adjuster vs. Seat Remount - Checking them Out | cycledrum | Gen II Prius Modifications | 1 | 05-24-2009 02:18 PM |
| Your Height and the Driver's Seat | loyalty4life | Gen II Prius Main Forum | 78 | 12-30-2008 12:14 PM |
| Is two position "memory" driver's seat available? | RtStuf | Newbie Forum | 2 | 05-25-2008 08:54 PM |
| "Vent" on the back next to the seat | maggieddd | Gen II Prius Main Forum | 18 | 08-06-2005 09:48 PM |
