This is a discussion on EV button and warranty: updates? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; There are all sorts of reports in these forums about how installing the EV button in a Gen II Prius ...
Old 07-27-2009, 03:25 PM   #1
barefootmatt
Default EV button and warranty: updates?
There are all sorts of reports in these forums about how installing the EV button in a Gen II Prius will void the battery warranty. That's been enough to convince me not to install it, if only to preserve resale value.
Now the Gen III Prius has arrived, and behold! The North American model finally comes with an EV button, and still has a 160,000 km warranty on hybrid components.
Is anyone aware if Toyota has reconsidered its position on the Gen II EV switch now that it's available on the Gen III? Does the Gen III have a totally different control system that reduces the potential for battery wear, or are they essentially comparable?
I'm going to try writing to Toyota, but I wanted to see if there's any "word on the street" as well.
barefootmatt is offline
Old 07-28-2009, 11:49 AM   #2
barefootmatt
Default Re: EV button and warranty: updates?
I got an incredibly vague response from Toyota, as follows:
Thank you for your recent correspondence.
Toyota Canada does not recommend any modifications to the manufacturer's standard specifications.
As specified in the Toyota owner's manual supplement, repairs or adjustments that are required as a result of misuse, negligence, modification, alteration, tampering, disconnection, improper adjustments or repairs, accident and use of add-on parts are not covered under the manufacturer's warranty.
We hope this answers your question, and we appreciate your interest in Toyota products.
Does anyone else have any more specific insights? Any ideas on how I can get them to give me a clearer answer?
Old 07-28-2009, 02:04 PM   #3
Friends: 37
The Prius III has much tighter limits on speed, range and kick-out amperage than does the North American EV mod and I suspect you're still SOL if you have a premature failure with an EV mod installed and the dealer and Toyota decide to be sticklers.
That said, I'm at 90k with my EV mod that I've had...a long time, can't even remember my mileage at time of install, but it had to be under 5k miles.
efusco is online now
Old 07-29-2009, 12:47 AM   #4
sorka
How are they going to know if you remove the mod? Does EV usage get logged in the ECU?
sorka is offline
Old 07-29-2009, 07:40 AM   #5
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Best I can tell, all the reports of warranty denial are based on one instance where Toyota ending up replacing the battery after an initial denial and after the owner agreed to remove the switch.
My logic in deciding to install the switch went like this: Battery problems are rare even among cars equipped with it, whether factory or aftermarket. The burden would be on Toyota to demonstrate that the identical switch they include from the factory on overseas Prii somehow harmed the identical battery on my U.S. model. On the other hand, I also acknowledged to myself that that wouldn’t stop them from trying and that I might be confronted with a legal fight if it came down to it. Still, after carefully considering the potential benefits (to me) and the risk (quite small), I chose to install it.
Jim
Click here for car details.
JimboK is offline
Old 07-29-2009, 02:52 PM   #6
Frayadjacent
Resident Conservative
Frayadjacent's Avatar
Magnussen-Moss is your friend. Unless the mod CAUSES damage to a component, it cannot void the warranty.
Frayadjacent is offline
button, updates, warranty
My Prius needs a battery, Toyota denies warranty due to EV button naterprius Gen II Prius Main Forum 145 08-26-2009 12:44 AM
GPS Updates... pr4424 Gen II Prius Main Forum 1 03-06-2008 12:21 AM
EV BUtton Mod - Who can install it without Voiding Warranty? dongwoo Gen II Prius Modifications 13 12-14-2007 03:58 AM
Toyota Will Void Warranty For EV Button ~ '04 & '05 Brian Gen II Prius Modifications 15 11-05-2004 02:45 PM
Battery SOC, EV Button, and Warranty: point to ponder jrawles Gen II Prius Main Forum 2 05-27-2004 10:00 PM
