This is a discussion on REVIEW: ExtendMySeat driver's seat extenders within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by Eddie Kent I bought a seat extender back in the beginning of July (7/9/09) and installed it. ...
Old 10-19-2009, 10:10 AM   #31
boppo
boppo's Avatar
Model: II
Default Re: REVIEW: ExtendMySeat driver's seat extenders
Originally Posted by Eddie Kent View Post
I bought a seat extender back in the beginning of July (7/9/09) and installed it. I really enjoyed the extra room. Yesterday (10/15/09- 3 months of use), I noticed the seat was rocking a little bit and took a look at the seat extender and the right rail had broken in 2 places near where the right front seat bolt attaches. I have e-mailed the Prius Chat Shop to see if they will either send me a new one that I can take to a machine shop to have reinforced or give me my money back. I haven't heard anything back from them and not sure if I will. The last time that I e-mailed them with an issue on another product, I never received a response and had to go directly to the manufacturer (on this- I have no idea who that is).
Full disclosure- I am 6'1" and 245 lbs, and have had no panic stops since installing this seat extender. I have a real safety concern with this product as it is- if it breaks after 3 months of normal use, think about what might happen in a severe accident. This seat extender needs to be either reinforced or made out of thicker stock. The stress points where mine broke are less than 1/8" thick and about 3/8" wide.
I just installed mine but haven't drove it yet. I put mine away for the winter and drive my camry, I looked at that area and can see it might be a problem it it flexes there, since it is thin. I am 6'1" and 255 lbs. I will just keep a eye on it when I start driving it in the spring.
Thanks fo the heads up,
boppo is offline
Old 10-19-2009, 02:50 PM   #32
Eddie Kent
Model: II
Package: #3 Touring
In the course of taking out the seat to install the seat extender, you actually realize that the seatbelt assembly on the right drivers side is actually attached to the seat frame and not the floor of the prius- so if the seat goes, so does your anchor to the vehicle.
I heard back from Danny at Prius Chat and he is having the manufacturer send out a replacement that is actually an improved design, so hopefully it's a non-issue now (for me anyway)
Eddie Kent is offline
Old 10-19-2009, 05:17 PM   #33
boppo
boppo's Avatar
Model: II
that's good to hear, so I must have the lastest since I just got mine.
boppo is offline
Old 11-14-2009, 05:41 PM   #34
orange4boy
My Car: 2003 Prius
Package: Base (Canada)
I hate to be a nanny here but I see a strength issue on these units which could be very dangerous. The way the front attachment point is pierced and bent leaves very little steel on either side. A better design would bend down 90 degrees at that spot and then back up to the correct angle for the front of the seat mount this would allow the full material width and strength.
If I were the manufacturer, I would be very worried about liability with only those thin bits holding the front of the seat.
Just my 2 cents
Added: Just read the above posts about the broken bracket and new design. hopefully the issues are fixed. They need to update the pictures though.
orange4boy is offline
Old 11-17-2009, 12:35 PM   #35
Rusty Hooks
Thanks for all the info here folks...just got our first Prius and the seat extenders were first on the list.....checking with the mfrs this am....again....THANKS TO ALL!!
Rusty Hooks is offline
Old 11-19-2009, 11:41 AM   #36
problemchild
problemchild's Avatar
Just wait till some grieving widow takes you to the 9th circus court for the loss of her husband because the bracket broke or the airbag didnt work. I was the inventor of the seat bracket idea a few years ago. We quit before we started because people were complaining about safety.
Not worth a few hundred in profit.
problemchild is offline
Old 11-19-2009, 10:32 PM   #37
cycledrum
Prius Aficionado
cycledrum's Avatar
Check the disclaimer on the website. It looked quite detailed when I briefed though it.
I'm the only person to drive my car with my altered seat mounts. If it fails, I have only myself to hold accountable.
But, those welds won't fail.
Last week I had my original seat in the car for 6 days. Wow, did that stink.
I only have my remounted seat 2 clicks further back than the original stock max position, which turns out to 1 3/8" further back, but wow, it sure makes a nice difference. I would put it a click more back, but I can't deal with the reach to steering wheel while having a little tilt of seatback which I like.
If I'm between jobs (have lots of time), I'd like to do the full monty job of getting a Corolla seat, wiring and upholstering it up with Prius stuff, and making so it can slide back a bit further while lowering with height adjust. That might take me weeks to finish full time, it could be nice though.
Brett
09 Spectra Blue Mica Package #5 : 06 Prius driver's seat - remounted 2 5/8" back, 7/8" foam added in headrest covers, inverted auto-dimming rearview mirror
cycledrum is offline
Old 11-20-2009, 12:33 AM   #38
problemchild
The prius seats suck beyond belief. Moving them back doesnt fix how bad they suck. I bought volvo v70 8 way electric heated seats and bolted them in. Sooooooooo much nicer then scooted back junk pri seats.
I drove 18 hours in one stent across country and my back never hurt.
The Following User Says Thank You to problemchild For This Useful Post:
cycledrum (11-21-2009)
Old 11-20-2009, 12:45 AM   #39
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
problemchild,
I don't remember -- did you also replace the passenger seat with a Volvo seat?
Also, your sheepskin covers -- I remember photos of them from another thread and they looked great. Where did you get them? Do you have an extra one for the Prius seat that you'd like to sell?
Boo is offline
Old 11-21-2009, 11:43 AM   #40
problemchild
Originally Posted by Boo View Post
problemchild,
Yes I replaced both seats. I do have both slightly used (3 weeks I think) sheepskins.
email me at mkdickson (at) gmail (dot) (com).
driver, extenders, extendmyseat, review, seat
Prius driver's seat rail extenders mjustice Gen II Prius Modifications 15 09-28-2009 04:52 PM
Your Height and the Driver's Seat loyalty4life Gen II Prius Main Forum 78 12-30-2008 12:14 PM
just noticed under the driver's seat...... taggart Gen II Prius Main Forum 7 07-31-2008 10:02 PM
Driver's seat modification in Chicago ljdemaster Gen II Prius Modifications 3 03-18-2008 09:33 PM
Love the car... but let's improve the driver's seat! JohnCalabrese Gen II Prius Main Forum 23 06-23-2004 07:55 PM
