This is a discussion on excessive road noise - how to "fix" it? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just bought a 2008 Prius and drove it about 1,000 miles on the freeway from California to Washington State ...
Old 09-28-2009, 10:52 PM   #1
tomrinbellingham
Default excessive road noise - how to "fix" it?
I just bought a 2008 Prius and drove it about 1,000 miles on the freeway from California to Washington State - home. I loved it all, except that it seems to have an excess of road noise.
Anyone figure out a cure for that? Some kind of undercarriage coating? Special tires? It has the standard 15 inch wheels and original tires on it with now 22,000 miles on them.
It's not "that bad", but, if there is something that would quiet it a bit, I'd probably do it.
Thanks, Tom
tomrinbellingham is offline
Old 09-28-2009, 11:05 PM   #2
richard schumacher
Destination: Eschaton
Default Re: excessive road noise - how to "fix" it?
Not special tires, just different ones. The OEM Goodyear Integrities are great for MPGs and dry traction but not so good for noise or snow. People like Nokians, Michelins, GY Assurance FuelMax. There are zillions of posts of discussion. "Search" is your friend :_>
richard schumacher is offline
Old 09-29-2009, 08:54 AM   #3
Doc Willie
Shuttlecraft Commander
Doc Willie's Avatar
Friends: 11
You can also add sound insulation to the inside of the car: inside the doors, headliner, etc. A good auto sound store can do this. Will make your car stereo sound better, too.
Doc Willie is offline
Old 09-29-2009, 09:14 AM   #4
bighouse
bighouse's Avatar
How much weight does that sounddampening add to a car?
bighouse is offline
Old 09-30-2009, 01:16 PM   #5
qmtran
Depends on the type. If you are using mainly the tar type mats, you are looking at roughly 20-40lbs of extra weight depending on how exteme you go, ie removing all the carpets, door panel, headliner and having a hayday with the stuff.
Changing tires will reduce road noise as mentioned before.
qmtran is offline
excessive, fix, noise, road
Loud Bluetooth noise ("horn" or "tone" sound) prior to dialing Solar_Powered Gen II Prius Audio and Electronics 5 09-26-2009 07:32 PM
Prius airplane sounds "road noise" acarter001 Gen II Prius Technical Discussion 8 11-04-2008 04:29 PM
Correction: Resolved "Clicking Noise From Front Wheel" IndyDoug Gen II Prius Care, Maintenance and Troubleshooting 1 10-10-2008 03:18 PM
Abnormal "water" noise during braking/acceleration flyingprius Gen II Prius Main Forum 7 05-19-2008 06:35 PM
