| This is a discussion on Will Installing the Shark Fin Antenna void any part of factory warranty? within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I want to order the shark fin antenna but want to know if it will void any part of the ... |
| Senior Member Join Date: Sep 2009 Location: Bay Area
My Car: 2009 Prius Model: N/A Package: #5 Touring Thanks: 8
Friends: 1 | I want to order the shark fin antenna but want to know if it will void any part of the factory warranty (such as for the radio, etc). Also, I'm kind of interested in installing these blue 2010 Toyota Emblems, and similarly, will this exterior mod void the warranty? And how difficult/ugly is it to take off the current emblem? Toyota Prius 2004 ~ 2009 NHW20 Exterior Accessories :: Sigma Automotive You'll have to 'Find' "Heat Blue Emblem." Thanks! Last edited by macmaster05; 11-02-2009 at 10:20 PM. |
| Shuttlecraft Commander Join Date: Jun 2007 Location: Out there, somewhere
My Car: 2007 Prius Model: Package: #5 Thanks: 2
Friends: 13 | In brief, no. If a problem develops with your radio after you install it, the dealer may refuse to deal with it. However, they will have to prove that the mod was the cause (?Magnusson law?). It may be a hassle to go through that process, but legally, the burden of proof is on them if they claim the mod caused the problem. The emblems are not to difficult to remove. They are held on by a layer of adhesive, which you can pull off with dental floss. Warming things up a bit helps. There are two nubbins in the back of the emblems that go in to holes to hold them in place. Get something cool to replace them:
__________________ 2207 Prius-class Shuttlecraft, Level 5 technology Exterior: Starfleet Graphics; Antigrav Generators; Velocity Transducer Disks Performance: Toroidal Velocity Transducer Resize; Auxiliary Engineering Computer; Intermix Pre-Heater; Structural Integrity Reinforcement; Stealth Mode Interior: Main Screen Security Access w/ In-flight Stellar Cartography; Aft Motion Warning System Upgrade; Weapons and Engineering Controls More Last edited by Doc Willie; 11-03-2009 at 09:48 AM. |
Friends: 1 | Quote: my question is, what other parts of the car are related to the antenna? he wouldn't tell me, didn't know. in fact he said he has never seen anyone do that prius mod. (bay area) |
My Car: 2007 Prius Model: Package: #2 Thanks: 236
Friends: 22 | |
| _ . _ . / _ _ . _ Join Date: Mar 2008 Location: Los Angeles
My Car: 2008 Prius Model: Package: #5 Thanks: 151
Friends: 17 | Boo, you forgot... "Dolt" macmaste05, I see you do not have a location listed, but a couple of points to consider. If you live in a large metopolitan area, a Sharkfin will work OK. If however you live in the Burbs or further out, and the station you want to listen to has poor coverage in you area with the standard whip, you can petty much bet a sharkfin wont hear it at all! It all depends on A-Your location, B-The station ERP, and C-The stations footprint! Basic RF transmission theory 101. By the way you dealer is an , well Boo summed it up. It should have NO effect on you warrenty status. It sounds like this is the kind of dealer who will say or do anything to get out of doing a LEGITIMITE repair job!!! Then turn right around and charge you up the ass for a simple repair job!!! |
| Senior Member Join Date: Mar 2008 Location: Rancho Cucamonga,CA
My Car: 2008 Prius Model: Package: #5 Thanks: 8
Friends: 3 | look for another dealer... that dealer as Boo have said... is an idiot.. or a liar... or both..... |
| Senior Member Join Date: Apr 2008 Location: Pennsylvania
My Car: 2008 Prius Model: Package: #6 Thanks: 7
Friends: 1 | |
Friends: 22 | Quote:
I think it depends on the area and terrain where you live and drive, and the strength of the transmitting signals of the stations that you normally listen to. I live and drive in and around New York City. 99% of the time I listen to strong signal stations, and I still receive those stations strongly with the shark fin antenna. So for me (and I think many others), the loss of reception and function has been di minimis. But for others whose normal reception of radio stations is weak or poor, the loss of function can be near total.
__________________ Best regards, Tom 07 Magnetic Gray #2 - GY TripleTreds 195/60R15, BT Tech Strut Tower Brace, BT Tech Stiffening Plate, Philips X-Treme Power Headlights, Webasto 4300 Sunroof, Sharkfin Antenna, Chrome Wheel Covers, Chrome Door Handles, BumperDefender.com Bumper Guard Strips, Body Side Moldings, Rear Bumper Protector, NoBump.com License Plate Screw Bumpers, Bumper Bully, Australian Merino Sheepskin Seat Covers, Leather Steering Wheel Cover, Leather Center Console Cover, Center-Hump Litter Basket, Non-Slip Pads, Dalmatian Bobble Heads. | |
My Car: 2008 Prius Model: Package: #6 Touring Thanks: 168
Friends: 2 | Quote:
I beg to disagree. To begin with, both antennas (ae) have the same function, to gather radio signals. There can not be a form/function conflict. On the other hand there could be a form/functionality conflict. Functionality being used here as a synonym for efficiency. In this case the functionality/efficiency varies with how far from ideal the length of an antenna varies from know best length to receive the signal desired. Neither the sharkfin nor the OEM is the most efficient. But the OEM is longer and therefore more efficient. The form of the antenna is inextricably wrapped up in its efficency. The sharkfin's antennas would be no more or less efficient if it were not covered by what some folks think is a very stylish "sharkfin"-shaped hollow shell. If there is a conflict at all, it is between functionality/efficiency/form -- all being the same thing in this case -- and style. Efficiency can be assigned a numerical value, perhaps the ratio of the available signal and the portion that is received. (Input/output) But you can't easily assign a number to coolness, to style. No direct comparison is possible. There are numerous posts/threads on PC that clearly say that the sharkfin will most likely result in some reduction of signal strength. Many folks, after analyzing their particular radio-related environment, have decided that they don't need or want the OEM antenna. (Why? pick one or more: Sirus/XM radio, books on tape/disc, iPod music, Pod casts, whatever, maybe just a silent drive.) I hardly ever listen to the radio. I prefer books on disc, iPod music, silence, or conversation. I think the shape of the sharkfin is stylish and distinctive. After reading many posts/threads I knew full well that the sharkfin had reduced functionality. No problem. I have given up absolutely nothing by opting for a reduction in the antenna/radio functionality I virtually never use. On the other hand, I get to smile every day at how stylish Amapola looks to me with the sharkfin installed instead of the soda straw/RC radio OEM antenna. I have no regrets whatsoever in my choice of style over unneeded functionality. Also, my choice is easily reversible. Next week or next year, should my needs/desires/taste dictate, I can just reinstall the OEM antenna. One man's unanimous opinion. Last edited by Rokeby; 11-08-2009 at 05:55 PM. | |
Friends: 1 | Thanks for all the opinions. I'll let you into my world: Reasons not to get it: - I use the radio almost all the time (40 minutes to work and 40 minutes home) so reception IS important to me. Reasons to get it: -I live in the SF Bay Area (south) and commute to San Francisco for work. Radio reception is generally strong but how worse will it be with a shark fin- that I dont know. -Priuses are a dime a dozen in the Bay Area. I love my dark grey prius, but I am young (23) and I want my car to be unique. With that, this decision is quite hard. I am very open to more opinions and suggestions (especially from those in the Bay Area). |
| antenna, factory, fin, installing, part, shark, void, warranty |
| Does DICE void factory extended warranty? | smith401 | Gen II Prius Audio and Electronics | 2 | 06-16-2009 01:13 PM |
| Installing Aftermarket HID will it void my warranty? | cfive | Gen II Prius Modifications | 6 | 05-12-2008 02:19 AM |
| Sirius antenna under shark fin antenna | efusco | Gen II Prius Audio and Electronics | 13 | 04-14-2008 05:31 PM |
| Trying to decide....Shark fin or regular factory antenna? | gracetaylor | Gen II Prius Main Forum | 16 | 07-23-2006 10:42 PM |
| void warranty | aolm | Gen II Prius Audio and Electronics | 0 | 01-30-2006 08:49 PM |
