wattage of DC-DC converter ?
| | #11 | |
My Car: 2010 Prius Model: N/A Package: G Thanks: 51
Friends: 16 | Quote:
No one can exceed 25kW wattage. A safety margin is another story. Ken@Japan | |
| Thanked by: | dave77 (11-23-2009) |
| | #12 | |
My Car: 2008 Prius Model: Package: T3 Thanks: 13
Let's say we're accelerating hard at 30mph (48km/h). 72% of the torque produced by the engine goes straight to the ring gear whereupon it goes to the reduction gear (via the chain in Gen 1 and 2), differential and front wheels. 28% of the torque goes to drive MG1 to produce power which goes to MG2. To get more acceleration we also add the power from the battery to MG2. However, MG1 and MG2 are rotating at different rates. According to a Prius simulator, MG2 (which is directly related to the road speed) is turning at 1,800rpm. The highest speed we can set the engine to and keep MG1 within the ±6,500rpm bracket is 3,000rpm. If the engine is rotating at this speed MG1 must turn at about 6,100rpm. Clearly we can't just take the waveform directly from MG1 and apply it to MG2, the wrong coils would be driven. So that all the voltages and timings work out, the power generated by MG1 - which due to the setup of the coils and magnets is also three-phase, at high voltages - has to be converted back to around 200V DC. That allows power to be directly taken off from or returned to the battery. The MG2 inverter must be able to handle the entirety of the power capability of MG2 itself - a full 50kW for Gen 2, 60kW for Gen 3. I believe that the inverter is actually a pulse-width-modulated variable-frequency drive as described at Variable-frequency drive - Wikipedia, the free encyclopedia. From what I recall of Gen 3 marketing materials, the battery supplies up to 25kW on Gen 2, up to 27kW on Gen 3. The remaining power for large outputs from MG2 comes from MG1. | |
| converter, dcdc, wattage |
| Lowest wattage plug in CO monitors? | Celtic Blue | Environmental Discussion | 14 | 03-26-2009 11:04 PM |
| Anyone tried higher wattage bulbs for headlights? | Blackbird | Gen II Prius Modifications | 6 | 11-12-2008 02:10 AM |
| EBH--lower wattage and lower temp...? cold related? | efusco | Gen II Prius Modifications | 3 | 02-03-2008 02:30 PM |
| Higher Wattage?? | TheParadox66b | Gen II Prius Modifications | 5 | 06-05-2006 05:43 PM |
| A/C Wattage vs lights | thorn | Gen II Prius Fuel Economy | 33 | 07-28-2005 08:26 AM |
