| This is a discussion on Aftermarket rim size within the Gen II Prius Modifications forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I want to get some aftermarket rims for my 2001, what is the biggest rim I could get. I seen ... |
Friends: 0 | I want to get some aftermarket rims for my 2001, what is the biggest rim I could get. I seen one with 17" but they seem to big... |
| Senior Member Join Date: Jun 2004 Location: hell
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 9
Friends: 5 | low profiles? i have 17s. they are fine. i was thinking it could probably fit 18s. the clearance is definetly there. 17 low profiles have a smaller diameter than the stock wheels. So.. 18s are safe.. not sure about anything else. your MPG will go down and your ride will turn more solid. Still smooth but more solid. Your handling will improve along with tractions in rain or dry. |
Friends: 5 | hmm.. you have an 01.. didn't see that... if.. hmm.. if the 04 tire isn't too tall for your 01.. then you could still use 17s.. they are wider though. I have my old set of stock tires. If you want to drop by.. you live in Cambel.. i live in San Jose.. we can do a size test. |
Friends: 0 | Is there another toyota rim that is interchangable with the prius? |
Friends: 5 | i'm not sure about the 01. I know for the 04 and 05 you can get scion TC rims. they look really good on it too. you have to figure out what size the wheel is.. er.. well.. lug pattern. 04/05 is a 5/100 5 lugs 100 milimeters apart ... er.. i think that's how it's measured. |
Friends: 0 | I put the stock wheels from a Scion tC, 17"x7", on my 05. The outside diameter of the tire is only slightly bigger than the oem prius tires (0.145 inches). I imagine any toyota rim with a 5-100 lug pattern would work granted it is from a passenger car an not a truck. The Corolla, Matrix, and Celica all have the same pattern as the gen 2 Prius. But it looks like the gen 1 Prius is a 4-100 lug pattern. The Scion xA and xB have a 4-100 lug pattern so you might try looking in that direction.
__________________ Black 05 pkg#6 On the road 10-4-04 |
Friends: 5 | yeah.. his wheels look nice too Your outside diameter is bigger than oem? my 17's with low profiles are smaller than oem... hmm. strange. i guess the tire used makes that much of a difference. You can see mine at the next prius meet.. whenever that may be.. |
Friends: 0 | I have 4 lug... Thanks for the help. There are Prius meets? I just got out of a Mustang car club after I sold my stang. Loved the meets we had. How often do you guys meet up? |
Friends: 5 | our last meet was in nappa valley. i'm owner. I try to attend every meeting. I would like to host another meeting. here.. go up to Usergroup at the top.. .. and click on it... under non-member... find San Francisco Bay area... then join group now your part of my group. then under forum on the left.. (click it).. and then scroll down to the bottom wher eyou were see our club and all the others. you can only view clubs you have joined.
__________________ Silver 9 as of June 12th '04 (over 123k Miles now) Decals, Mud Flaps, 1200Watt Modified sign wave Inverter, BT Tech Rear Brace, coastaletech 2" receiver hitch, and 215/45/17 tires. |
Friends: 0 | I'm about to get a Prius, and I'm wanting to get 17" rims. It appears that the only way to do this is buying an aftermarket set of rims, right? So, for those of you that have done this, what do you do with your existing wheels? Just stash them? How much did a new set of rims and wheels cost? Did anyone find a way to sell their original wheels to recover some of the cost of the upgrade? |
| aftermarket, rim, size |
| Availability in CT... and size. | Malarkey | Gen II Prius Main Forum | 11 | 06-21-2007 01:00 AM |
| What size tires to get? | CoolWind | Gen II Prius Modifications | 13 | 04-10-2006 07:15 PM |
| tire size | kente777 | Gen II Prius Main Forum | 1 | 12-29-2005 04:41 PM |
| tire size 195 60 15 is this okay | robinredbreast | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 07-16-2005 12:36 PM |
| size | togloonda | Gen II Prius Main Forum | 8 | 04-04-2005 09:52 AM |
