| This is a discussion on Prius less efficient at highway speed than two-mode hybrids? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(usbseawolf2000 @ Jun 11 2006, 04:36 AM) [snapback]269256[/snapback]</div> HSD used in GS450h and LS600h (eCVT L110) has two speed ... |
| | #11 | |
Friends: 8 | <div class='quotetop'>QUOTE(usbseawolf2000 @ Jun 11 2006, 04:36 AM) [snapback]269256[/snapback]</div> Quote:
The variable reduction gearset is used to meet wider speed range. Ken@Japan | |
| | #12 |
Friends: 0 | ISTR that the GS450h et al were getting a dual-planetary system, but maybe I'm thinking about something else. There are already such systems on the road, such as in some hybrid buses; see the slides at http://www.engin.umd.umich.edu/vi/w4_works.../Miller_W04.pdf . Also, go read Graham Davies' pages and look up "heretical mode". With the single-planetary HSD as it is in the Prius, the faster you want to cruise at lower RPM, the more that MG1 has to be forced to spin *backwards* by zoobs from MG2. That's a less efficient electrical hop than we might want, but we have no choice there because the tradeoff is letting engine RPM creep up which increases consumption for relatively little proplusive gain. . Changing to a more "overdrive" mechanical ratio is the way to fix the problem. . _H* |
| Most efficient speed for best MPG? | Swamibob | Gen II Prius Fuel Economy | 83 | 06-08-2008 02:57 PM |
| laughing about Mercedes bragging about their C230 w/25 highway mpg and 7 speed transmission | cwerdna | Other Cars | 18 | 05-17-2007 08:36 PM |
| Highway safety and speed limits | tnthub | Fred's House of Pancakes | 0 | 07-08-2006 08:28 AM |
| b-drive at highway speed | waiting | Gen II Prius Care, Maintenance and Troubleshooting | 6 | 03-19-2006 12:55 PM |
| Tech Question: Highway Stealth Mode | 8AA | Gen II Prius Main Forum | 4 | 10-24-2004 06:49 PM |
