| This is a discussion on 2004-06 prius fob hack? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; This is for non sks people, im not sure how safe this is but you can do it at your ... |
Friends: 0 | This is for non sks people, im not sure how safe this is but you can do it at your own risk. step 1 : insert the fob into the slot, do not put it in all the way, just until before it clicks ( therefore the key is in but nto locked in ) keep your hands there. step 2: with your hands holding the fob in the slot, press the power button to start the vehicle, it should start and you may be able to keep the key in your pocket while the power is on. i just was playing around with my prius ( it has SKS ) but i disabled it and tried to start it without the fob in the slot. Im not sure the dangers, but it works ( for me ) , im just not sure about non sks prius's. oh yeah , im not also sure about the purpose of this? but then again i cant understand purpose anyway
__________________ 2005 Toyota Prius Hybrid Package 9 2001 Toyota Prius 2005 Honda Accord Hybrid 3.0 V6 |
Friends: 0 | SKS = smart key system? |
Friends: 0 | You don't have to put the fob in the slot with SKS so you really aren't accomplishing anything. Hack? What hack? <div class='quotetop'>QUOTE(statultra @ Jun 20 2006, 07:09 PM) [snapback]274366[/snapback]</div> Quote:
Friends: 0 | no i meant this for non SKS users, not SKS, i disabled my smart key and tried my procedure to see if it would work, im not sure whether or not it will work on the NON SKS i would like to see, its a interesting concept to me that the transponder ECU would allow the vehicle to be started, and have the fob not present in the slot. if anyone without the smart key system would try this procedure i would like to know the results |
Friends: 0 | I disabled the retention solenoid in my non-sks slot precisely so I *can* start the car and then take the key out and put it away. Slid one pin out of the connector shell, completely reversible. . _H* |
Friends: 0 | <div class='quotetop'>QUOTE(hobbit @ Jun 28 2006, 03:11 PM) [snapback]278264[/snapback]</div> Quote:
Friends: 1 | <div class='quotetop'>QUOTE(statultra @ Jun 21 2006, 10:10 AM) [snapback]274626[/snapback]</div> Quote:
Imagine the newly sophisticated car jacker: "Does this Prius have SKS, because if it does, you need to give me the fob".
__________________ Bruce Mine: Driftwood '04 BC 24 Sept 2004 - added: mudflaps, door edge guards, side panel moldings, Coastal Tech EV switch, OEM Integrity tires, WeatherTech window deflectors. Last tank - 14 Jul '09: 728.9 miles - MFD MPG: 56.0 Actuals Lifetime: 93,087.3 miles, 48.90 MPG. Wife's: Barcelona '06 #7 May 2006 - added: front mudflaps, Coastal Tech EV switch. OEM Integrity tires. Last tank - 21 May '09: 419.4 miles - MFD MPG: 46.7 Actuals Lifetime: 31571.4 miles, 44.82 MPG. | |
| 2007 Prius and the navigation hack | GatorJoe | Gen II Prius Technical Discussion | 4 | 07-18-2007 10:58 PM |
| Prius Hack Installations | starkeef | Gen II Prius Audio and Electronics | 2 | 01-28-2007 01:41 PM |
| Wired Magazine Prius Hack to act as Generator | jonbeck | Gen II Prius Main Forum | 9 | 07-23-2006 02:32 PM |
| Hack Wanted: Karaoke Prius | SluggoLovesNancy | Gen II Prius Modifications | 2 | 05-28-2006 12:42 AM |
| Hack your Mac into your Prius MFD!! | m2oore | Gen II Prius Main Forum | 1 | 03-22-2006 09:04 PM |
