This is a discussion on Auto conversion to Prius drivetrain within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; What a bunch of sick in the muds, if one had the skills it would be fun! I might take ...
LinkBack (2) Thread Tools
Old 07-18-2006, 10:43 PM   #11
hdrygas
What a bunch of sick in the muds, if one had the skills it would be fun! I might take a while but there would be a certain satisfaction. It is out of my league but I can understand the attraction.
hdrygas is offline
Old 07-18-2006, 10:52 PM   #12
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
well, i could see installation being the major problem. there are oh, 40something computers in the car. if it ties into any of the ecu's in any way, it's gotta be transferred.
a couple major things:
you'll have to retrofit a steering rack and steering column since there are no belts to drive a power steering pump. the braking system will probably be the thing that really breaks the project, even if you had the time/money/energy to do this. regen braking is a big source of battery charge.
but hey. if you wanna try it, more power to ya.
black 2005 prius, a few mods that make me happy
g: class of '09 in intense science
DH: class of '09 in medical equipment
hoping to discover the 'reward' part of the sacrifice-reward cycle soon!
galaxee is online now
Old 07-18-2006, 11:01 PM   #13
hdrygas
<div class='quotetop'>QUOTE(galaxee @ Jul 18 2006, 07:52 PM) [snapback]288512[/snapback]</div>
I would bet that DH would take it on! I won't mention it to him but IFixem has designs on doing something like that.
hdrygas is offline
Old 07-21-2006, 07:51 PM   #14
statultra
uber-Senior Member
statultra's Avatar
in 2 years i am going to take a try at doing a prius conversion, i dont believe its too hard, considering i fixed up two salvaged prius', all that you need is a perfectly good wiring harness for the vehicle.
what it hink the procedure for doing this swap is :
1. Disconnect HV Service plug
2. Drain all fluids (brake, some engine oil, inverter coolant, maybe hv transaxle )
2. Disconnect the inverter, two ( or 3 on the 04 not sure ) HV plugs, and the 3 or 4 wires to the elec motor ( 3 bolts )
3. Disconnect inverter circuit breaker sensor, and the 3 wires on the right side of the inverter.
4. Remove inverter ( take out the neccessary bolts)
5. Remove air cleaner
6. Disconnect fuel injectors and spark plugs
7. Disconnect throttle body motor connector
8. Disconnect the sensors located on the front of the electric motor and air compressor and such.
9. Disconnect the fuse boxes ( not too sure if you can ? )
11. Remove the thingy that the exhaust is on, including o2 sensor connectors, and insert random other connectors
Then im not sure what to do from here, either go in the interior of the car strip it and disconnect all ECU's and pull the wiring harness through the firewall into the interior. then..
10. Support the engine and transmission with a jack and remove the mounting bolts including torque rod and remove the engine and trans.
12. Pull the rear of the interior apart, and disconnect the two HV wires behind the back seat, then route it through the floor and remove the high voltage wiring ( this is for the HV battery to inverter connection )
also during this swap i believe the SRS will not work, or it will, it depends on the vehicle you are converting, i believe most new toyota and lexus's share similar airbags, but i believe the SRS is also connected through the HV ECU and the ECM, this is due to the circuit breaker that shuts off power in the event of a airbag deploying , seatbelt charge releasing etc.
and im tired so i wont continue maybe tommorow
oh yeah, after the swap you need to make sure that all the wiring harness's are properly stowed away in the safe places, especially the HV wiring that runs from the rear, also the ambient temperature sensor and random other stuff thats on the prius, its simple, just i hope toyota used connectors on the harness that are different for different ECU's, because im not sure how you would figure out which plug goes to which ECU
im not sure if this applies to the 04-06 but i have worked on the HV system on the 01, including removing the inverter and charging the HV battery, so from the best of my knowledge i think this would be the way to do a swap. i have done a swap on a honda civic that i got for 50 dollars, and i think the prius is no different ( minus the emmense amount of wiring harnesses in the car.
2005 Toyota Prius Hybrid Package 9
2001 Toyota Prius
2005 Honda Accord Hybrid 3.0 V6
statultra is offline
Old 07-21-2006, 08:04 PM   #15
Frank Hudon
call this number and ask for George, he's doing this conversion on Dodge Caravans. 604 438 6611
Frank Hudon is offline
Old 06-22-2009, 01:24 PM   #16
itjstagame
Default Re: Auto conversion to Prius drivetrain
Any updates, anyone else tried this? I had half-hearted thought about this a bit because I really hate automatic transmissions but really love my wifes ES300 or maybe get an RX300.
Was thinking that either of those with a blown engine/tranny and gut them out to make a very slick and economical machine. Of course that's only a someday thing because I don't really have any funds and even parts priuses are waaay pricey.
I'm suprised by the very confused knowledge here though, why do some maybe people think the brakes on the car are special and generate electricity? The Prius uses MG1 for regenerative braking. It does have a special brake pedal system that engages MG1 regeneration first and then applies actual hydralic brakes as needed. This could probably be either swapped over or my thought (ghetto, I know) would be to back off the existing hydralic brake pedal on a car so there's a bit of play or slop, so I press down for 1/2"-1" before I actually start engaging the master cylinder (and hence the hydralic brakes). During this slop area I either engage MG1 or add an actual TPS and increasingly ramp up MG1 until just when the hydralics will kick in. I'd have to play/engineer the Prius brake system a bit to be sure, but I'm sure something like that would work fine.
As for power steering, why do you need it? Disable/remove that junk and go with manual steering. Unless you have a fullsize pickup you really won't notice too much of a difference. Remember the trick is don't just unhook the pump, you want to remove all hydralic lines from the steering column and hook the two on the steering rack in a loop (with fluid still), or else you'll have to fight stale hydralic pressure as you turn the wheels.
The biggest part to me seems mounting the engine (building engine mounts, etc), mating the output of MG2 to the existing driveline, depending on the car, etc, it's probably easier to just swap the Prius axles and hub or possibly entire front suspension. Lastly, making an alcove for the batteries that will get cabin air, with a fan when needed but secured enough to not be messed with and closed off/far enough away the "god forbid" something fails and the li-ion pack explodes.
After that wire routing and multiple 'brain' placements is basic car mod stuff, just rip out the existing wire and make it fit and then find the appropriate outputs for the dash and stuff if you want, but to run you probably don't even need that. Definately you want to pull over the main bus and MFD and not splice into the Prius harness at all. You only really need to do hook in the parking/driving lights and existing dash board indicators if you want to, I suspect the Prius dash is fully electronic and you are probably better off just doing some plastic/fab work to make it fit.
Aside from a Lexus I think a first gen MR2 would be sweet. I love that car and would love more milage and power.
Really the hard part is I'd like to know how the PSD connects to the engine, that is the bellhousing/bolt pattern and if other engines could be used. It'd be much nicer to use the 3.0L V6 from the lexus or maybe a black-top 4AGE, etc.
It'd be even nicer to be able to swap out/upgrade the motors, get a 150HP MG2, 2 battery packs and an MG1 that will go -15k rpm to 15k rpm (instead of -10 to 10) and that'd be a screaming machine. I really want more MG1 range so I can go up to 55-60MPG in EV mode and also for a higher top speed. Because lets face it if it's going in and MR2 and we find out how to hook up a more powerful engine and MG2 then we will want to drag race it :-).
After that all that's left is to find out how we can fool or program the ECU to have a launch program, something that keeps the engine turned on and then right before launch revs to max HP/torgue output and holds that RPM the whole time, using the PSD to adjust drive ratio as needed for acceleration. I long to see the 60 foot time this could achieve.
itjstagame is offline
Old 06-22-2009, 01:53 PM   #17
richard schumacher
Destination: Eschaton
Everyone needs a hobby :_>
richard schumacher is offline
Old 08-10-2009, 12:46 PM   #18
ragman
ragman's Avatar
I bet it wouldn't be easy, but I have seen a Reliant K-car do a 9 second quarter mile so anything is possible. How are your fabrication and welding skills? Any good at geometry?
I worked for a body shop on the mechanical and electrical side of the shop and I have seen some crazy repairs done to these cars involving removing the entire electrical system and replacing it. After the wiring is done, it is all fabrication and engineering. Its hard, but not impossible. (don't I make it sound easy?)
If you are in my area, I'll work on it with ya!
ragman is offline
Old 08-14-2009, 07:22 PM   #19
alanh
Effectively you'd have to build a Prius inside of another car body, at least if you wanted everything to work mostly correctly. The ECUs monitor all the car's systems, so if there's a piece missing they're going to complain.
alanh is offline
auto, conversion, drivetrain, prius
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-technical-discussion/21376-auto-conversion-prius-drivetrain.html
Toyota Celica Convertable, Toyota Celica Backgrounds, Toyota Celica Factory Service Manual - Avantibca4499Ss This thread Refback 03-08-2009 03:43 AM
prius drivetrain - Zuula Search This thread Refback 12-17-2008 09:18 PM
Prius Conversion to E85 Ethanol? adamorzol Gen II Prius Main Forum 33 11-06-2009 05:24 PM
Conversion Packs for Plug-In Prius available in '08 Earthling Prius and Hybrid News 13 05-06-2007 06:52 AM
From Chevy Van Conversion to Prius...WAHOO! caroleberen Gen II Prius Main Forum 12 03-04-2007 07:45 AM
Gen 1 drivetrain bhaynnes Gen II Prius Main Forum 3 01-06-2007 01:32 PM
Researchers developing new hybrid drivetrain cooling system Tideland Prius Prius and Hybrid News 0 05-01-2006 12:41 AM
