| This is a discussion on RPM at 70% maximum within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I've read this in several websites including http://john1701a.com/prius/prius-advice02.htm . Is this informatation available from the car, as is (without adding ... |
RPM at 70% maximum
Friends: 0 | I've read this in several websites including http://john1701a.com/prius/prius-advice02.htm . Is this informatation available from the car, as is (without adding extra dials)? I have a 2006. "A gasoline engine works more efficiently when running at higher RPM, about 70 percent of maximum." Thanks in advance. |
| Artist In Residence Join Date: Jul 2006 Location: Newton, MA
Friends: 7 | No, as of yet, that info is not available without finding a way to rig up a tach yourself. What you do have is ears though! You can learn to hear and feel what "about 70%" feels and sounds like. But I have a feeling you're in the same boat with me right now: We're both better off driving our new cars like they're just regular cars. We'll figure out all the subtleties of improving our MPGs through a lot of experience. I've been using pulse/glide a bit, and it's fun to feel more in-tune with the car, the way I used to feel driving a manual-transmission. But I also don't pretend to be better at overall balance of the system than the computers.
__________________ 2006 Barcelona Red Metallic - a.k.a. "The Professor" :: Accessories/Mods :: BT Tech Stiffening Plate - Engine Block Heater - OEM EV button - OEM Mud guards - Rear Bumper Protector :: Near-future :: ScangaugeII |
Friends: 0 | Well I don't know about 70% of max, I will look into that over the next few weeks, but I will tell you something you can get at on any Prius, It appears to me that when the car is between 20 and 38 mpg during acceleration you are in the grove for pulse and glide. I will pay more attention to the RPM's for the next few days. |
Friends: 0 | <div class='quotetop'>QUOTE(dachshund @ Sep 4 2006, 05:21 PM) [snapback]314236[/snapback]</div> Quote:
IIRC, diesels are much more efficient than gasoline engines at small throttle openings, which is why diesels get very good mileage on the freeway. Well actually, I guess they don't have throttles like gasoline engines, which is why the pumping losses are low at lower RPM.
__________________ 2009 Toyota Camry Hybrid Black (hers) JBL Audio, Bluetooth, Moonroof, Alloy Wheels, Pink Fuzzy Dice on rearview mirror 2005 Driftwood Pearl Pkg #6 (mine) Katzkin Leather Interior Diamond Audio D661s Component Speakers JL Audio 8W3 Subwoofer JL Audio CleanSweep CL441dsp MTX Thunder 564 Amp 4x100 watts MTX Thunder 421D Amp 1x300 watts OEM Sirius Tuner 2004 Super White Pkg #9 (hers) - sold | |
Friends: 0 | 70% of *RPM*?? That does *not* sound right. Load, yes. Not RPM, especially where over-the-road efficiency is concerned. . John? You might want to nose around on cleanmpg.com, and rethink this statement a little. . _H* |
Friends: 0 | <div class='quotetop'>QUOTE(Ichabod @ Sep 4 2006, 05:33 PM) [snapback]314239[/snapback]</div> Quote:
They have that big display - they could embed a digital readout of RPM in the picture of the gas engine in the Energy Monitor. | |
| maximum speed for gliding? | psikot | Gen II Prius Fuel Economy | 1 | 09-11-2007 07:07 AM |
| Maximum Luggage Capacity | clintd555 | Gen II Prius Main Forum | 4 | 02-25-2007 07:28 AM |
| forget the maximum, what's the minimum MPG? | busyrosy | Gen II Prius Main Forum | 60 | 11-13-2006 04:32 PM |
| Maximum MPG - It can't get any better than this | mtsarpilot | Gen II Prius Fuel Economy | 15 | 09-10-2006 03:22 PM |
| 810 Pounds Maximum Weight | justin96039 | Gen II Prius Main Forum | 18 | 07-03-2006 12:18 AM |
