Do we have Toyota Engineer in PriusChat?
Old 02-20-2007, 10:18 PM   #1
ukr2's Avatar
My Car: 2012 Prius Plug-in
Model: Plug-in Base
I've only driven my Prius for 2 weeks and I really like it.
Then I read how you have to Pulse & Glide to improve the mileage.
Then I read everyone's adding the EV button to keep the engine off on short trips.
Then I read other's complaining that using Cruise Control will NOT get the best results.
WHY???
Why isn't the Computer programmed to get the Best Results???
Even if you need a few modes to tell the computer what you want, like -
perform P&G at desired speed
keep the engine off if battery is above 20% SOC
use cruise control, but be efficieny
And Why must we feather the Accelerator or Brake to get our desired results -
Regen, but don't apply Friction brakes. More Regen. More Regen.
Increase speed, but don't enable the engine yet. Coast. More Speed, without engine.
This Computer, though pretty good, could be even better with some tweeks.
It's only Software !!!
AND
Has the Prius Software been changed over the years?
Have the older models been able to get upgrades?
If you have ever written performance software, you know it's possible to make it better.
Ken R., Victor, NY
got my 2012 Prius Plug-In #110 Sea Glass Pearl (green), Base model, March 14, 2012
Wife drives a 2012 Chevy Camaro Convertable. Big 6 cyl, manual 6-speed and 20 mpg. Opposites attract !!!
Purchased 1st Prius Feb. 5, 2007 using an Auto Broker that I've used 4 other times. No more haggling with Auto Sales, yet still great price. He sold my '99 Avalon with 94K miles that I really liked to one of his clients.
I traded in the 2007 for the PIP myself.
ukr2 is offline
Old 02-20-2007, 10:37 PM   #2
Friends: 47
Then I read how you have to Pulse & Glide to improve the mileage.[/b]
You can P&G to improve gas mileage, but you don't have to do so...there are a number of techniques that will help.
Then I read everyone's adding the EV button to keep the engine off on short trips.[/b]
I don't think there's any truth to that and can't imagine where you read it. Using the EV button can be helpful, but not to stay in electric for short trips. Again, this is a complex subject that you can do a search and find much information on.
WHY???
use cruise control, but be efficieny[/b]
The CC on the Prius is a standard CC at this time. It is not tied to the ECU so it's NOT a software issue. The reason it's not more efficient is b/c there's a slight delay as the CC realizes your speed has dropped below the set point then aggressively accelerates back to speed. It can't anticipate stops or hills or needs to speed up.
Also, the ICE had better be ON if your battery SOC ever gets to 20%. In fact you may not even be able to start the car w/ a 20% SOC. It's programmed to stay b/w 40-80% and rarely goes outside of the 50-65% range. Again, there's a lot of information out there on why this is, but suffice it to say it's to protect the battery from damage and prolong it's life.
AND
If you have ever written performance software, you know it's possible to make it better.[/b]
While it might seem a simple thing on the surface, it isn't. How is the car supposed to know whether to shut down the ICE when you slow down a little bit....maybe it's a temporary slowing for traffic before you go back up to speed. If the ICE shut down you pay a cost in electrical energy to restart, it takes away from the smoothness of the operation of the system and people will complain about the jerky ride.
Now, that said. It's possible that the next generation Prius will be able to do a little better. The NAV may be tied into the ECU with terrain mapping to anticipate terrain and traffic conditions thus telling it when to expend more battery power or to conserve it in anticipation of need. But this is very far from simple programming and it still won't affect the cruise control.
I think the part you're missing is that the car can't anticipate what you're going to do, what the traffic is, etc. Without that it's impossible to program the car to do what you want when you want...so they picked averages and what they thought would be most likely for most conditions.
Evan E. Fusco, MD
efusco is offline
Old 02-20-2007, 11:13 PM   #3
<div class='quotetop'>QUOTE(ukr2 @ Feb 20 2007, 08:18 PM) [snapback]393664[/snapback]</div>
WHY???
AND
I agree with what Efusco wrote, but in addition...
Toyota sells the car to "the market", which on average is comprised of people who want to press on the gas pedal and go. If they were to program in P&G, the average driver would immediately take it to the dealer complaining that their "car is pulsing and gliding!"
The techniques people use to get the best gas mileage are done at the expense of things like speed and acceleration, things many people don't want to lose.
member is offline
Old 02-22-2007, 08:05 PM   #4
ukr2's Avatar
Model: Plug-in Base
Evan and "Display Name",
Do we have a Toyota Engineer in PriusChat?
I'd enjoy hearing from a Company man about the logic behind the Prius, step-by-step.
I didn't say everyone had to select P&G.
But if P&G can improve mpg, and if you had the ability to select P&G mode, wouldn't you?
And don't we have a lot of posters talking about installing an EV button, and some worrying if it voids the warrenty or not? If there is any advantage in using the EV button, why didn't Toyota make the factory button available to North America? If the advantage of the EV button was, instead, part of the Prius Software Logic, noone would have to install it. We all would get its advantage.
And if the CC on the Prius is a standard CC at this time, WHY didn't Toyota tied it to the ECU to make it a software issue?
All of these questions are best answered by a Toyota Insider. Drivers of the Prius, no mater how experienced, don't have the answer. We can only Guess.
ukr2 is offline
Old 02-22-2007, 08:45 PM   #5
Friends: 47
<div class='quotetop'>QUOTE(ukr2 @ Feb 22 2007, 07:05 PM) [snapback]394931[/snapback]</div>
Well, if we have an engineer from Toyota who's involved with the Prius he's never made him/herself known. So you're stuck with us.
If you look at the info on the new Highlander Hybrid (2008) it will include an ECON button...I don't think it will pulse/glide but rather will aim at keeping the car in it's most efficient rpm band based upon battery SOC. A built in P&G, again, would be difficult or impossible due to the lack of ability to anticipate terrain and the fact that the degree of P&G could be a danger to surrounding traffic....it is a task that can only safely be accomplished by a human.
The reasons for no EV button in the US have mostly been speculated at. However one member has had the opportunity to speak to a Prius Engineer and found that at least part of the answer was related to concern about emissions secondary to cooling of the catalytic converter if used inappropriately. It seems pretty clear from all we've been able to gather over the last 3 1/2 years that we've been researching this through all available resources that the complexity of getting the EPA to approve the EV button in the US was the main thing that prevented it's being included.
The other reasons, again, are well detailed in multiple threads but clearly include the ease of LOWERING FE if misused. That said the fact that it will be included in the '08 Highlander Hybrid suggest the prior concerns have been addressed and that the emissions issues resolved. I expect clear guidelines to the efficient use of an EV button will be included. And, again, it can't be part of the logic b/c the car can't predict or anticipate the best times to go into EV mode. I can't think of a better way to explain that...if you got in my car with me I could demonstrate in about 15 minutes, but there are conditions that the only advantage is when the human driving can predict the future by knowing what the traffic conditions are, where the lights are, what speed you'll be going, etc.
Same thing w/ the CC, if you read my post....the reason is b/c no CC can anticipate terrain or traffic.
I'm sorry I'm not a Prius engineer, but you should take the time to research these issues in prior threads and try to give some credence to those of us who've been asking these questions for 3 1/2 years and sought out the answers. Much of the info is in technical reports done by Toyota and others, much is logic based upon experience, and much is accumulated info from many other places. We know what we're talking about.
efusco is offline
Old 02-22-2007, 09:25 PM   #6
ukr2's Avatar
Model: Plug-in Base
Evan,
Thanks again. I know I ask a lot of Why's and Why Not's. It's the engineer in me.
PriusChat is lucky to have dedicated folks, like you, to assist us newbes.
Also Toyota recognizes the efforts of PriusChat by listing it on the top of its Hybrid Synergy Drive - related sites -
http://www.toyota.com/vehicles/minisite/hy...ANDING_MINISITE
By the way, what is your speciality as an MD?
Or does your MD not mean Medical Doctor ???
ukr2 is offline
Old 02-22-2007, 09:34 PM   #7
Friends: 47
Emergency Medicine.
efusco is offline
Old 02-23-2007, 07:36 AM   #8
Pulse and glide is optional and helps with any car using a gas engine. It works better in a Prius because the engine can be off, but you would not want the car doing it all the time on its own. I virtually never pulse and glide myself and have gotton a full tank at over 60 mpg.
I have the EV button and it helps a lot in some situations but short trips are not it.
I understand we'll have the button in the next version.
Cruise control is bad because it is designed to keep speed constant. This is not best for economy especially when cresting a hill where you will need to brake on the down side, but that is what most people expect cruise control to do.
The computer is programmed to give you the best possible results. There are some limitations to this that we can take advantage of: We can see what is coming or plan what we want to do next and the car can't know these things. Secondly the car must have some hysteresis around it's operating point to prevent oscillation. That is why we can get to the peak economy when done accelerating by feathering the pedal a bit. There's the same hysteresis with the engine on off switching so we can do a lot to control that too and stay in battery mode without the ev button quite often.
Adding a button for more economy has been rumored for the next model.
I really don't see them fixing the cruise control to do pulse and glide. There's just too many ways to do it with terrain effects that even a nav hook up won't likely handle, as well as traffic issues. When cruse control can do this we won't need to drive as the car should be able to do that too.
You need some practice and you can do all the things you mention regarding regen vs friction brakes,
controlling engine on, coasting. If you add a Can View you'll find it much easier. Worth it just for the ice-spin indicator alone.
And the Prius software has been changed a lot over the years. My car is far better now than when I got it. I've only had one software upgrade but it made all the difference I needed for my driving. But they have to save some improvements for the next model which should get a big boost in economy.
tomdeimos is offline
Old 02-23-2007, 10:26 PM   #9
ukr2's Avatar
Model: Plug-in Base
P&G takes practice at feathering the accelerator to get it to Glide.
Wouldn't it be nice to be able to push a "Glide" button or pull the CC handle, like Cancelling", to Force the Prius to stop energy flow ???
Then to Glide would be easier.
Now there's an Option I'd implement?
Who can find out how to do it?
ukr2 is offline
Old 02-23-2007, 11:15 PM   #10
<div class='quotetop'>QUOTE(tomdeimos @ Feb 23 2007, 07:36 AM) [snapback]395097[/snapback]</div>
i am a new owner with about 1,700 on a 2007 touring model Prius. I am getting 40 MPG. That is 20 less than you have gotten on one tank. I am not looking for 60. I am looking for 45-47 MPG average. but i do not understand why i am getting 40. i am not an agressive driver with the car. I am mindfull of the concept of P&G even though i dont think i actually practice it regularly. I have not checked my tire pressure but the car is only 1 month or more old. the temperature here in Seattle has been a bit chilly, averaging about 38-49 during the period i have owned the car.
I cannot figure why i am getting this low a milage and i took one long trip during this time, (290 miles each way, again in cold weather, and i did use cruise control) and still have not gotten better than 40.7 on any tank.
Any ideas?
squall is offline
Nice Words by Toyota about PriusChat! Jerry W Gen II Prius Main Forum 13 04-23-2007 07:39 PM
Does Toyota watch PriusChat / post here? bigdaddy Gen II Prius Main Forum 20 08-30-2006 11:10 PM
response from Toyota to PriusChat input galaxee Gen II Prius Main Forum 11 12-30-2005 12:24 AM
Toyota GB PriusChat Link IsrAmeriPrius Gen II Prius Main Forum 1 07-18-2005 07:38 PM
Toyota GB recognises PriusChat! Tideland Prius Gen II Prius Main Forum 2 06-15-2005 01:15 PM
