This is a discussion on how do you populate the phonebook manually? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a Motorola RAZR that does not upload entries to the phonebook. Is there a way that I can ...
Old 05-20-2007, 07:40 PM   #1
RadGash
I have a Motorola RAZR that does not upload entries to the phonebook. Is there a way that I can manually add entries to the Prius Phonebook?
RadGash is offline
Old 05-20-2007, 08:01 PM   #2
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
<div class='quotetop'>QUOTE(RadGash @ May 20 2007, 04:40 PM) [snapback]446324[/snapback]</div>
I have a Motorola RAZR that does not upload entries to the phonebook. Is there a way that I can manually add entries to the Prius Phonebook? [/b]
That depends on the model year of the car. No for the 04 and 05 models. Yes for the 06 and newer.
IsrAmeriPrius is offline
Old 05-21-2007, 12:33 AM   #3
chinalfr2
chinalfr2's Avatar
<div class='quotetop'>QUOTE(RadGash @ May 20 2007, 07:40 PM) [snapback]446324[/snapback]</div>
I can upload my phonebook entry on Motorola RAZR to the Prius. It's not the whole phone book, but at least one entries at a time. What kind of problem do you have on BT sync with your RAZR and Prius?
Try follow the steps from toyota site?
I can also manually add entries to the Prius Phonebook on my 07 Prius.
chinalfr2 is offline
Old 06-05-2007, 08:44 PM   #4
TWI
<div class='quotetop'>QUOTE(chinalfr2 @ May 21 2007, 12:33 AM) [snapback]446435[/snapback]</div>
I downloaded the one sheet directions from the Toyota site. Then I started to follow it. However, I noticed after I selected an entry in the contact list and went to 'Send' one of the options was 'Select Multiple'. I selected that, then I was able to select all the other contact I wanted to send over to the Prius. That worked. It was more than just one click (one click for each contact), but not bad.
TWI is offline
How do you manually add phone numbers to Prius? OlsonBW Gen II Prius Audio and Electronics 2 03-14-2007 04:38 PM
Manually charging the hybrid battery? SteveO Gen II Prius Main Forum 3 01-03-2006 09:23 AM
Can i change consump. est MPG to reset manually? wendymo Gen II Prius Care, Maintenance and Troubleshooting 4 11-16-2005 02:16 AM
Entering Phone Numbers manually mcitron Gen II Prius Audio and Electronics 0 12-25-2004 08:17 PM
manually switching gears Raenstoirm Gen II Prius Main Forum 9 04-03-2004 05:05 PM
