This is a discussion on Green Battery Display? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Most of the time the dashboard display has my battery showing the levels in blue. But sometimes the levels are ...
Old 06-06-2007, 02:50 PM   #1
Nicole
Most of the time the dashboard display has my battery showing the levels in blue. But sometimes the levels are green. What does this mean. It is sometimes green early in a trip but then goes to blue for the rest of the trip. I don't remember doing this the first 2 weeks I had the car. I've now had the car 6 weeks.
Nicole is offline
Old 06-06-2007, 03:00 PM   #2
bupah
The top 2 bars will make the whole battery level display turn green. This means your batteries are nearing or at a "full" charge. The middle 4 bars turn it blue and then it turns to purple on the last 2 bars meaning you are low on your battery charge.
<div class='quotetop'>QUOTE(Nicole @ Jun 6 2007, 11:50 AM) [snapback]456699[/snapback]</div>
bupah is offline
Old 06-06-2007, 03:16 PM   #3
Nicole
<div class='quotetop'>QUOTE(bupah @ Jun 6 2007, 03:00 PM) [snapback]456710[/snapback]</div>
Thanks Bupah. Another question I have is that I thought upon starting the car, or moving again after a stop sign that it would only use the battery at least until about 25 mPH. But it seems to use the gas also very early ar even at at start -- along with the battery.
Nicole is offline
Old 06-06-2007, 03:24 PM   #4
SomervillePrius
The prius is an hybrid and not an electric car. It will most of the time use both the gasoline and electric engine. If the car is warmed up it's possible to accelerate REALLY slowly up to 35 mph, but you risk having people honk at you. It's also less efficient for the prius as if you drain the battery doing slow acceleration then at some later point it will (most likely) run the gas engine longer to recharge the battery. People who get great mileage in their car try to use the battery as little as possible.
SomervillePrius is offline
Old 06-06-2007, 08:10 PM   #5
dmckinstry
<div class='quotetop'>QUOTE(bupah @ Jun 6 2007, 12:00 PM) [snapback]456710[/snapback]</div>
And it should be noted that by full it's actually 80% full and by empty it 40% full.
That's the range allowed by the ECU (or whatever computer controls the charging).
Dave M.
dmckinstry is offline
Old 06-10-2007, 09:45 PM   #6
vdubstress
vdubstress's Avatar
Mine always has a white bar on top, even when green
vdubstress is offline
Old 06-11-2007, 05:46 PM   #7
ny biker
ny biker's Avatar
<div class='quotetop'>QUOTE(vdubstress @ Jun 10 2007, 09:45 PM) [snapback]459385[/snapback]</div>
Mine too.
ny biker is offline
Old 06-11-2007, 08:23 PM   #8
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
<div class='quotetop'>QUOTE(vdubstress @ Jun 10 2007, 06:45 PM) [snapback]459385[/snapback]</div>
<div class='quotetop'>QUOTE(nybiker @ Jun 11 2007, 02:46 PM) [snapback]459741[/snapback]</div>
Mine too.
You'll almost never see 8 bars unless you go down a steep hill (or a less steep hill with the battery already at 6 or 7 bars)
Tideland Prius is offline
Old 06-11-2007, 09:25 PM   #9
dmckinstry
<div class='quotetop'>QUOTE(Tideland Prius @ Jun 11 2007, 05:23 PM) [snapback]459824[/snapback]</div>
I got 8 bars today, but rarely do. As you say, a steep or long hill with the batteries at 6 bars or above when starting down. This is about a 2 mile downgrade, and reasonably steep.
Dave M.
Old 06-11-2007, 09:28 PM   #10
priussoris
priussoris's Avatar
We got the full Green bars yesterday on our way back from camping, first time ever down hill for over a few miles even had to use "B" and it works great!
priussoris is offline
Battery display does not turn green Hoser Gen II Prius Technical Discussion 7 09-27-2007 11:20 PM
Green technologies on display at LA Auto Show hb06 Prius and Hybrid News 0 11-26-2006 08:53 PM
Battery display sluggo42 Gen II Prius Care, Maintenance and Troubleshooting 6 08-21-2006 03:43 AM
battery display how on your display duanerw Gen II Prius Main Forum 8 11-07-2005 03:01 PM
Battery Status Display; Never full? Here's why. RobertO Gen II Prius Main Forum 20 08-15-2005 09:06 AM
