ICE Runs in reverse..
Old 06-19-2007, 09:30 PM   #1
seftonde's Avatar
Model: Two
I live at the top of a very steep driveway. I am used to backing up it, and when I first got my Prius in March I did the same. I was amazed that I had to push the accellerator almost to the floor to go up! Then I read that in reverse it only uses the MG's, so it takes a lot of power.
Now, yesterday and today I did the same thing. When driving home I had almost depleted the battery. As I started up the driveway (in reverse) i heard the ICE running. I paused and hit the energy screen and sure enough there was a power line from the ICE to the MG only. I am sure it was kicking in to charge the battery, but I didn't realize it would run in reverse.
My understanding of the planetary gear system is not too good, and I'm trying to justify in my mind how it works in reverse - obviously the ICE only turns in one directoin....
Just thought it was interesting!
Daniel
seftonde is offline
Old 06-19-2007, 09:57 PM   #2
john1701a's Avatar
My Car: 2012 Prius Plug-in
Model: Plug-in Advanced
Friends: 22
Yes, the engine running while in reverse is somewhat counter-productive. In fact, you can see that process in action at the bottom of this webpage.
Look at those animations closely. Though a little on choppy side, they do get the point across. The PSD is a very interesting device.
john1701a is offline
Old 06-19-2007, 10:09 PM   #3
seftonde's Avatar
Model: Two
<div class='quotetop'>QUOTE(john1701a @ Jun 19 2007, 09:57 PM) [snapback]464996[/snapback]</div>
Hi John,
Thanks! Yes, I saw your animations and your excellent page on the Prius before I bought it. I had not been to your site since I bought the car; thanks for reminding me - now the animations mean more to me since I have better understanding of how the beast operates. Yes, truly an interesting (wonderful) device.
Daniel
seftonde is offline
Old 06-20-2007, 12:06 PM   #4
Cat Lovers Against the Bomb
daniel's Avatar
Amazing, indeed! The ICE runs (forward, of course), turning MG1, which generates electricity, which goes to MG2, which propels the car (backwards, in this case). I believe the geometry of the PSD limits how fast you can back up.
60% of the torque of the engine goes to MG2 and the wheels (forward) but force does work only in proportion to distance traveled, so that at slow speeds, where MG1 is turning very fast and MG2 is turning slowly, most of the power from the ICE goes through MG1 rather than directly to the wheels and MG2, so I believe there is little energy lost when going backwards at slow speeds. The counter-productive work done by the ICE on MG2 is small, while the work that follows the electrical path from MG1 to MG2 is large.
Daniel
Primary car: 2010 Tesla Roadster. Range: 245 miles on a charge. Zero to sixty: 3.9 seconds. Torque: 273 foot-pounds. Horsepower: 288. 100% electric @ 2 cents per mile.
Gas guzzler for road trips or when I park at the airport: 2004 Prius.
-- Emma Goldman
-- Otto von Bismarck
daniel is online now
Old 06-20-2007, 01:51 PM   #5
My other car is a boat
Friends: 19
<div class='quotetop'>QUOTE(daniel @ Jun 20 2007, 12:06 PM) [snapback]465247[/snapback]</div>
This is correct. The HSD is a work of wonder. As an engineer, as soon as I understood how the HSD worked, I knew I had to have a Prius.
As for backing up, most cars are geared down in reverse. Most people don't need to drive fast in reverse, and car companies (and insurers) would just as soon you didn't.
Old 06-20-2007, 02:06 PM   #6
Pinto Girl's Avatar
<div class='quotetop'>QUOTE(qbee42 @ Jun 20 2007, 12:51 PM) [snapback]465323[/snapback]</div>
One cool little thing about the Prius is that the digital speedometer works in reverse (this is the first car I've owned without analogue gauges; those didn't)...I've seen it display 16mph, backing down my driveway in the morning, late to the transit station (but I always stop to look before pulling into the street!)
I'm fascinated by this for some strange reason.
Pinto Girl is offline
Old 06-20-2007, 03:38 PM   #7
subarutoo's Avatar
<div class='quotetop'>QUOTE(Pinto Girl @ Jun 20 2007, 11:06 AM) [snapback]465332[/snapback]</div>
What's your best 0-16 time, or is it 0 to minus 16?
subarutoo is offline
Old 06-20-2007, 03:45 PM   #8
HSD PhD
usbseawolf2000's Avatar
Friends: 81
You don't understand how PSD works until you "get" why the ICE can spin forward yet the Prius moves backward.
Planetary gear-set is amusing. I bought some to play/show around from a hobby store.
usbseawolf2000 is offline
Old 06-20-2007, 03:54 PM   #9
Retired
Tom6850's Avatar
<div class='quotetop'>QUOTE(Pinto Girl @ Jun 20 2007, 02:06 PM) [snapback]465332[/snapback]</div>
If I was backing up at 16MPH I sure would not be looking at the speedometer!!!!!!
Tom6850 is offline
Old 06-20-2007, 04:28 PM   #10
Pinto Girl's Avatar
<div class='quotetop'>QUOTE(Tom 6850 @ Jun 20 2007, 02:54 PM) [snapback]465380[/snapback]</div>
You know, I didn't have my head turned to look behind me (I normally back up using the mirrors and maybe the rear view camera)...and --darn--- the yard was sure going by fast that day (I had the pedal to the floor for a little bit); I simply *had* to see exactly *how* fast...
I'm not sure if this has anything to do with what we're discussing or not, but I've always wanted to take the body off of a car and put it on facing the opposite direction, so you'd drive down the road looking through the rear window.
I guess you'd still be using the forward gears, though, normally...
Hmmmmmm....
This brings up the philosophical question: does a car with its body on backwards drive backwards...or not...?? I mean the chassis thinks it's still going forward, but the body doesn't.
Wondering, now, if I'm not overthinking this just a bit.
What if: The Oil Runs Out Washington1788 Fred's House of Pancakes 8 08-03-2007 03:56 PM
What's the chron job that runs at about 03:15 EDT? Bill Merchant PriusChat Website Questions 3 06-29-2007 04:30 PM
Engine Runs a Lot? mcontrols Gen II Prius Fuel Economy 2 06-06-2007 09:47 AM
How a new one runs... bweston Gen II Prius Main Forum 3 12-15-2004 09:06 AM
After The Oil Runs Out DaveinOlyWA Environmental Discussion 86 07-11-2004 06:50 PM
