| This is a discussion on Grinding noise 2005 Prius Sounds like Wheel Bearing within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; In other cars I've had, if this sound came from wheel bearings, then the sound changed a lot when I ... |
| | #11 |
| Senior Member Join Date: Dec 2008 Location: Kingston Ontario
My Car: 2009 Prius Model: N/A Package: C Thanks: 10
Friends: 0 | In other cars I've had, if this sound came from wheel bearings, then the sound changed a lot when I was turning left or right. If it didn't change, then it was likely a cv joint. |
| 2005, bearing, grinding, noise, prius, sounds, wheel |
| Front Wheel Bearing | Russell | Gen II Prius Technical Discussion | 10 | 08-21-2009 10:42 PM |
| Wheel bearing needs replacing - how to avoid? | mikepaul | Gen II Prius Care, Maintenance and Troubleshooting | 18 | 08-08-2008 08:29 AM |
| Grinding noise | Rxmxsh | Gen II Prius Main Forum | 9 | 03-16-2007 12:22 PM |
| Grinding noise when braking - Only 42000 km on 2004 Prius | Eug | Gen II Prius Care, Maintenance and Troubleshooting | 9 | 02-02-2007 11:33 PM |
| $900 single rear wheel bearing | 200Volts | Gen II Prius Care, Maintenance and Troubleshooting | 16 | 11-22-2006 02:00 PM |
