This is a discussion on Tire upgrade and pressure sensor question within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(David Beale @ Jul 29 2007, 01:23 PM) [snapback]487106[/snapback]</div> The tire size has no effect on sensor calibration. The ...
Old 08-19-2007, 05:26 PM   #11
rudiger
The tire size has no effect on sensor calibration. The tire sensor measures pressure inside the tire, and compares it to the setting you make once in a while when you press the button (after you check and inflate/deflate appropriately).[/b]
I didn't think the TPM measured air pressure at all. My understanding was it simply compared tire rotation between each side of the vehicle. A preset level of deviation between rotation (as when one of the tires had lost air pressure) was what triggered the warning light. This makes a certain amount of sense since atmospheric conditions would cause tire pressure to fluctuate, but it would cause both tires to fluctuate at the same rate and not cause a warning light.
Of course, if correct, it would seem to mean that there would be certain rare instances where a loss of tire pressure would not cause the warning light, say, if someone drove over a tire deflation strip. In such a circumstance, both deflated tires would be rotating at the same rate.
rudiger is offline
Old 08-19-2007, 05:51 PM   #12
IsrAmeriPrius
Progressive Member
IsrAmeriPrius's Avatar
<div class='quotetop'>QUOTE(rudiger @ Aug 19 2007, 02:26 PM) [snapback]498798[/snapback]</div>
My understanding was it simply compared tire rotation between each side of the vehicle. A preset level of deviation between rotation (as when one of the tires had lost air pressure) was what triggered the warning light.[/b]
That is not the tire pressure monitoring system that Toyota uses for the Prius. The Prius has actual pressure sensors mounted in each wheel which detect deflation and then transmit that information via radio signal.
IsrAmeriPrius is offline
Old 08-19-2007, 09:55 PM   #13
postal1
Wanderer
Package: #2 Touring
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Aug 19 2007, 04:51 PM) [snapback]498810[/snapback]</div>
What ever you do, don't trust the shop mechanics. I did and may have gone for six months with low tire pressure. Never assume that they do what you would do. Check your own tires!
I had my car in three times for low pressure, each time they found a nail or screw. One the fourth time I checked it myself, all four times were around 24 pounds. Once I fixed the tire myself and inflated the tires, no problems for the last two months.
postal1 is offline
Old 08-20-2007, 02:49 PM   #14
rudiger
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Aug 19 2007, 05:51 PM) [snapback]498810[/snapback]</div>
It was my salesman that told me it was a tire-rotation-based monitoring system so that explains why the information was incorrect.
What other vehicles (Toyota or otherwise) use a system based not on tire pressure but rotation?
rudiger is offline
Old 08-20-2007, 04:18 PM   #15
apriusfan
<div class='quotetop'>QUOTE(rudiger @ Aug 20 2007, 11:49 AM) [snapback]499248[/snapback]</div>
...What other vehicles (Toyota or otherwise) use a system based not on tire pressure but rotation?[/b]
BMW is one of the manufacturers that use the rotational method. There may be others but I have personal knowledge regarding BMW.
apriusfan is offline
Old 08-20-2007, 05:01 PM   #16
IsrAmeriPrius
Progressive Member
I do not know about other manufacturers, but according to this post by Galaxee, Toyota switched to direct TPMS for the '06 model year. Your salesman was out of date, as Toyota previously used an indirect rotation based system on some models.
Old 08-20-2007, 06:01 PM   #17
rudiger
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Aug 20 2007, 05:01 PM) [snapback]499364[/snapback]</div>
That's good to know. With the exception of this one somewhat esoteric faux pas, he had an otherwise reasonable grasp of Prius features.
rudiger is offline
tire shop broke a TPMS tire pressure monitor sensor during tire change theorist Gen II Prius Care, Maintenance and Troubleshooting 32 04-08-2009 11:57 PM
Tire Pressure Sensor Question peach Gen II Prius Main Forum 7 07-26-2007 12:39 PM
question about the tire pressure sensor hybrid_batmobile Gen II Prius Main Forum 2 12-27-2006 04:01 PM
Tire pressure sensor mssmith95 Gen II Prius Main Forum 2 06-04-2006 02:09 PM
Tire Pressure Monitor, where is the sensor? DocVijay Gen II Prius Main Forum 28 12-19-2005 06:08 PM
