This is a discussion on Transmission Locked In Park within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; two questions; 1, 04 prius stuck in park! jumped but to no avail. need to move it to my garage ...
Old 07-30-2007, 07:10 PM   #1
larry jones
two questions; 1, 04 prius stuck in park! jumped but to no avail. need to move it to my garage so i can work on it! has anyone removed the park lock selinoid from under the car? 2, 01prius; what batt. could i use without using the factory type? i mod. my conectors and installed a lawn type batt. ant it has worked for several mo.s. do not feel it is going to last though!!! thanks, larryjo2
larry jones is offline
Old 07-30-2007, 07:54 PM   #2
FL_Prius_Driver
FL_Prius_Driver's Avatar
My Car: 2001 Prius
For moving the Prius while off see the slide on removing the relay that locks the parking pawl. (Need to scroll down some to "parking games" slide.)
http://techno-fandom.org/~hobbit/car...g/prius01.html
Of course you have to be able to start the car to do this, otherwise you have to get 10 friends and lift.....or have one friend who owns a crane.
I will let someone else chime in about replacement batteries. However one option is
http://www.elearnaid.com/12vobaforpr2.html
FL_Prius_Driver is offline
Old 07-31-2007, 08:20 PM   #3
larry jones
<div class='quotetop'>QUOTE(FL_Prius_Driver @ Jul 30 2007, 05:54 PM) [snapback]487687[/snapback]</div>
Old 08-03-2007, 08:09 PM   #4
larry jones
this site is a bit difficult for me to operate. i am not much on computers and can get mixed up very easy. thank you for your help and good advise. i bought this car on the internet with front end dmg. and not running. 1/2 of the relays in the fuse box were missing. i borrowed some from a friend and jumped the car but to no avail. i need to get it home where all my tools and equipment are so that i can start to trouble shoot it. do you know anyone that has disconnected the park mechinisum from the transmission? i am sure i can find it when i get under the car, but any advanced info might help. thanks again, larry
Old 08-03-2007, 10:43 PM   #5
hobbit
hobbit's Avatar
If you successfully jumped the car and got the dash to light up,
then it's likely you can shift it to Neutral. But you need to then
pull the PCON MTR relay *before* letting it power down again, or it
goes right back into park. So try that first; it's a heck of a lot
easier than going after the parking actuator which is buried deep
on the backside of the transaxle and very close to other things.
_H*
hobbit is offline
Old 08-04-2007, 09:11 PM   #6
1fixitman
<div class='quotetop'>QUOTE(larryjo2 @ Aug 3 2007, 08:09 PM) [snapback]490228[/snapback]</div>
If you don't mind telling us....How much did you pay for the vehicle and how many miles are on it????
[/quote]
The elearnaid battery and kit is for generation 1 prius only. In generation 2 prius the terminal positions are swapped and this kit will not work for what we need in 04-07. Just clarifying this for all. I called elearn and they do not plan on getting a kit together for gen 2 as it is too complicated for the average person to do without screwing up something. FYI
D Rock
Removed wheel trim rings($0), Heat shields(mostly use windshield one since I have tint now) all the way around($120), BT Plate($165), EBH($39), 195/65 R15 Bridgestone Turanza LS-T tires at 42/40(now discontinued $340), Weather tech window vent shields($120), Zaino wax system($93), Scan Guage II($149), Nushield MFD screen protector($19), MFD hood(sun glare reducer $34), Fumoto 103N oil drain plug($21), Daryl the EV nut's Magnificient SUPER LED upgraded interior lights($434), Blocked upper grill($1.42), 35% window tint except front windshield LLumar brand($175), Mud flaps($36) what is next LOL?
1fixitman is offline
Old 08-05-2007, 10:09 AM   #7
FL_Prius_Driver
My Car: 2001 Prius
<div class='quotetop'>QUOTE(D Rock @ Aug 4 2007, 09:11 PM) [snapback]490689[/snapback]</div>
Thanks for the correction.
Old 08-10-2007, 07:48 PM   #8
larry jones
i have about $7,500 in the car and it needs about 2,000 in repairs. miles are about 50,000. thanks for your help on the questions i have about this car.
drained 12V battery, Transmission was locked in Park findlj Gen II Prius Technical Discussion 9 07-08-2007 10:29 AM
Locked Smart Key In The Car! razzledazzlebee Gen II Prius Main Forum 6 03-29-2007 09:12 AM
MPG locked at 99.9 - bug? SoopahMan Gen II Prius Care, Maintenance and Troubleshooting 8 09-29-2006 09:36 AM
Locked Out genalex Gen II Prius Main Forum 12 08-13-2006 09:54 AM
locked out kenmac Gen II Prius Care, Maintenance and Troubleshooting 19 05-27-2006 12:01 AM
