This is a discussion on New Owner Tire Question, SAFETY ISSUES? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I picked up my car 7-10-07. I have a little over 1000 miles on the car. My AVG MPG is ...
Old 08-08-2007, 02:07 PM   #1
NYPrius1
NYPrius1's Avatar
Thumbs up
I picked up my car 7-10-07. I have a little over 1000 miles on the car. My AVG MPG is 52. My best tank was 54.4. :P
My question is this, today I checked the tire pressure and it's 37 in all tires. I have seen postings saying to get it higher (40 something).
Are there any safety issues with this? Why would Toyota and the Tire MGR suggest 37??
Thanks For Any Info on This.
NYPrius1 is offline
Old 08-08-2007, 02:30 PM   #2
finman
I have 42 front/ 40 rear on my Goodyear Comfortreds, the "upgrade" from the factory Goodyear Integrities. Max psi on the sidewall of both these tires says 44 psi, so I'm right up near the max. Ride is great, but that's subjective...YMMV.
Lower tire pressure numbers on the door jam from Toyota would give you a softer ride, again, subjective to what you are used to.
It's yet another choice you have concerning the Prius. Most on this site run 42/40. some run the 35/33 (door jam numbers). Many can't stand even numbers so they run 39/37 (sarcasm). All have opinions, all enjoy their cars immensely!
04' Seaside Pearl #7. Fumoto oil drain, add-on mudflaps, rear bumper scuff protector & rear sensor warn, compass mirror, EV mode, synthetic oil, 8" custom sub in right rear cubby, 6" subs under front seats, power lumbar and seat heaters in front seats, Coastaletech hitch with Aspen bike/snowboard rack, iPod2car, DVD video, 2 amps, Alpine component speakers, solid 47 MPG @81000 miles, best tank 56 MPG.
finman is offline
Old 08-08-2007, 02:36 PM   #3
NYPrius1
NYPrius1's Avatar
<div class='quotetop'>QUOTE(finman @ Aug 8 2007, 02:30 PM) [snapback]492536[/snapback]</div>
Well It seems like no safety issues...... I will try the 42/40 and see what happens to the MPG.
Thanks So Much For The Reply
NYPrius1 is offline
Old 08-08-2007, 03:19 PM   #4
NYPrius1
NYPrius1's Avatar
Smile
<div class='quotetop'>QUOTE(NYPrius1 @ Aug 8 2007, 02:36 PM) [snapback]492540[/snapback]</div>
It seems I have a faulty tire gauge..... The Air Compressor says 42 ( after I put some additional air in ) One Tire Gauge says 38.5 the other 35. Beats Me!!
So What I said in my first post about 37 psi all tires my be wrong...
NYPrius1 is offline
Old 08-08-2007, 05:39 PM   #5
David Beale
David Beale's Avatar
The higher pressures will put you in greater danger of impact damage to the tire (possible blowout on violent impacts). There haven't been any reports of this being a problem, so we must be operating in a safe area.
An expert in the industry told me a few months ago the higher pressures increase the possibility of impact problems.
I run 40 front, 38 rear. Seems to work fine.
Perhaps you should invest in a nice gauge. I use an accugauge (digital). $20 at an auto center. It's consistent with another make/model and with commercial gauges.
Edmonton Alberta
David Beale is offline
Old 08-08-2007, 11:11 PM   #6
JimN
P719 of ???
JimN's Avatar
<div class='quotetop'>QUOTE(NYPrius1 @ Aug 8 2007, 02:07 PM) [snapback]492517[/snapback]</div>
Softer tires wear faster (who does that benefit?) and give a softer ride. If your tires are circles while supporting the car then you may be dangerously overinflated. IMO you are in no increased danger if you are within the manufacturer's spec or close to it.
You are doing good out of the gate. Block your upper grill and you should be able to pick up a bit more.
JimN is offline
Old 02-21-2008, 11:11 AM   #7
RobertQ
Default Re: New Owner Tire Question, SAFETY ISSUES?
Question: Are tires considered overinflated or dangerously overinflated if the pressure is higher than that recommended on the sidewall, or if the pressure is higher than recommended by the car maker (in the Prius-35 in the front and 33 in the back)?
RobertQ is offline
Old 02-21-2008, 03:53 PM   #8
Bob64
Sapphire of the Blue Sky
Bob64's Avatar
The psi number on the side of a tire only reflects the “maximum permissible” inflation pressure for that tire.
FYI: The maximum permissible for the OEM tires are 44psi.
Keep in mind that the psi number on the side of the tire does NOT represent the "blowout" pressure or anywhere close to it for that matter. Otherwise we hypermilers would need new tires each time we hit a bump!
I've read before that the blowout pressures are usually upward around 200psi or so.
Bob64 is offline
Old 02-21-2008, 08:24 PM   #9
Bear68
Friends: 7
Overinflation is when you exceed the maximum pressure listed on the sidewall of the tire. It is HIGHLY recommended to never exceed the pressure listed on the sidewall. I would also caution against going below the pressures listed on the door jamb. Too low a pressure will cause edge wear and possible tire failure.
Bear68 is offline
Toyota issues safety recall Tideland Prius Prius and Hybrid News 2 09-27-2007 08:05 AM
Safety question rkoska Gen II Prius Care, Maintenance and Troubleshooting 7 02-02-2007 04:53 PM
Safety issues marty Gen II Prius Main Forum 14 11-22-2005 12:44 AM
Question: safety of the Smart Key system Sun__Tzu Gen II Prius Main Forum 5 05-28-2004 04:25 PM
Safety question Dick K Gen II Prius Technical Discussion 0 12-31-1969 07:00 PM
