| This is a discussion on 2007 Prius Alarm Activation within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I’m buying a new Prius with the #2 package and the dealer said he would activate the alarm, The only ... |
| Junior Member Join Date: Aug 2007
Friends: 0 | I’m buying a new Prius with the #2 package and the dealer said he would activate the alarm, The only thing is that the mechanic had never heard of the Prius alarm activation. The sales person told me that if I got the instructions he would have the mechanic do it. I’ve searched several times and have only been able to find instructions for the 2005. I’m not sure if they are the same for the 2007. I found the pdf files in the PriusChat Shop under the glass breakage sensor page but the links don’t work. The pdf files are for the 2005-06 models I don't know if it the same for the 2007. Could someone please post the instructions or the link to the instructions for the alarm activation on the 2007 Prius. These are the instructons I found for the 2005 Prius by DanMAn32. Will these work on the 2007? H. Security Setting Procedure. NOTE: Check for the latest version of the software on Toyota Information System (TIS) before setting up the security system. NOTE: Ensure the software is the latest version (Production Version 10.2a. (07/18/03) or later.) NOTE: Download the latest software from Toyota Information System (TIS). 1. Connect the scan tool connector to the vehicle's diagnostic connector in the lower dash area. (Fig. H-1) 2. Insert the remote key or smart key (as appropriate) into the key slot. Press the power button once to select "ACC" position. i. Verify the shift position is in "N" position and LED on "P" switch is illuminated. 3. Push the scan tool main switch "ON" and then press the ENTER key. (Fig. H-2) "SELECT VEHICLE PROCESS 4. Select the correct vehicle application, Prius MY2004 . "SECURITY FUNCTION ON" PROCESS 5. Verify the connection of the DLC3 Cable. Press the "YES" button to continue. (Fig. H-3) 6. Select "OPTION SETUP" in the customize menu with the scroll key, then press the "ENTER" key. (Fig. H-4) 7. Press the "ENTER" key to select "DOP SECURITY" in the Option Setup menu. (Fig. H-5) 8. Select "ON" with the scroll key, then press the "ENTER" key. (Fig. H-6) 9. Press the "YES" key. (Fig. H-7) 10. Press the "ENTER" key. (Fig. H-8) |
| Phantom Panic Alarm Activation | david.pool | Gen II Prius Care, Maintenance and Troubleshooting | 7 | 07-17-2007 12:34 AM |
| 2007 Prius with only Security alarm | unknownone | Gen II Prius Main Forum | 0 | 05-15-2007 03:58 PM |
| Voice activation | Gadgetdad | Gen II Prius Modifications | 11 | 03-08-2007 11:26 AM |
| alarm activation | vitaly | Gen II Prius Main Forum | 1 | 01-08-2007 12:20 PM |
| Security Alarm too quiet? Does alarm trigger shut down? | crtolin | Gen II Prius Main Forum | 4 | 06-20-2005 05:09 PM |
