This is a discussion on Intake modification within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; After stumbling upon Hobbit's site, I'm not so convinced that a warm-air intake mod is beneficial to fuel economy in ...
Intake modification
Old 09-18-2007, 02:56 PM   #21
ilusnforc
Package: #8
After stumbling upon Hobbit's site, I'm not so convinced that a warm-air intake mod is beneficial to fuel economy in the Prius:
http://techno-fandom.org/~hobbit/cars/warmair/
ilusnforc is offline
Old 09-18-2007, 05:46 PM   #22
hobbit
hobbit's Avatar
Read the second version...
_H*
hobbit is offline
Old 11-17-2007, 11:28 PM   #23
chronon
<div class='quotetop'>QUOTE(David Beale @ Sep 13 2007, 03:29 PM) [snapback]512103[/snapback]</div>
Most of this "mucking about with the intake" just upsets the car. The air intake is measured using a "hot wire" device. When you add a "cold air intake" you change the turbulence around the sensor, throwing it off calibration. Sure, you can get "more HP" at some engine speeds. You also get less at others.
You shouldn't need a warm air intake for a fuel injected engine. The main thing the hot air is for is to improve atomization, and secondly, to reduce icing. Usually the icing is caused by the fuel evaporation taking away heat. A fuel injected engine doesn't need this evaporation. The injector produces a fine spray right at the valve opening, so the fuel doesn't really evaporate or change much at all before it goes into the combustion chamber.
But go ahead and mess with it if you must.
The last time I looked at my classic intake - it is a TBI -- which is a throttle body with an intake runner to the intake valves .. i have not seen a direct port injection on the prius --- i think you're thinking of another car ..
the fine mist is not right at the valve opening by the injector, rather the mist travels the length of the aluminum intake runner.
i would thinkyou would know that if u had a prius and spent a little time observing under the hood.
chronon is offline
Old 11-18-2007, 01:17 AM   #24
Pinto Girl
Pinto Girl's Avatar
Two words: Electric Supercharger
[laughing]
Pinto Girl is offline
Old 11-18-2007, 09:40 AM   #25
statultra
uber-Senior Member
statultra's Avatar
yea warm air isnt beneficial to fuel economy, i took off the hose from the air filter box to the resonator, and discovered the exhaust note is louder, but the fuel economy dropped. Routing the hose to the grille brings some improvement.
statultra is offline
Old 11-20-2007, 11:27 PM   #26
9G-man
Anyone try removing the charcoal filter that resides inside the airbox lid?
It is very restrictive to airflow into the engine and removing it was a big thing on the Tacoma forums a couple years ago when they first started showing up. It increased engine responsiveness and performance.
Yeah, I know what it's for and its removal wouldn't be very environmentaly friendly.........But someone will do it eventually.
9G-man is offline
Old 12-04-2007, 12:39 PM   #27
edthefox5
edthefox5's Avatar
Hmmmm.....I think Beale's correct at least on my 07. Is the classic using a TBI system? TBI means throttle body injection where fuel & air is combined at the throttle body. Not so on the 07. On my 07 it uses a throttle body that manages just air and at the end of the aluminum intake there is a fuel injector which injects fuel right at the valve area exactly as Beale stated. I know because I have spent a little time observing under my hood.
edthefox5 is offline
cold air intake?? AndreJ Gen II Prius Modifications 15 06-01-2007 11:18 PM
Air intake Stev0 Gen II Prius Technical Discussion 6 11-28-2006 02:23 AM
Where's the engine air intake? Bob Allen Gen II Prius Technical Discussion 2 11-18-2006 07:06 PM
Air Intake Mods mssmith95 Gen II Prius Modifications 3 03-17-2006 08:17 PM
Gas nozzle intake shocker Gen II Prius Care, Maintenance and Troubleshooting 5 03-31-2004 06:29 PM
