| This is a discussion on Block heater apparently not working within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(JimboK @ Oct 7 2007, 06:40 PM) [snapback]522568[/snapback]</div> Thanks for the suggestions, but it's not the socket, breaker, or ... |
| | #21 | |
| Tree-hugging Vegan Witch Join Date: May 2007 Location: Grays Harbor, WA, USA
My Car: 2007 Prius Model: N/A Package: Base Thanks: 258
Friends: 66 | <div class='quotetop'>QUOTE(JimboK @ Oct 7 2007, 06:40 PM) [snapback]522568[/snapback]</div> Quote:
| | #22 | |
| Senior Member Join Date: Mar 2007 Location: Albuquerque, NM
Friends: 1 | <div class='quotetop'>QUOTE(Rae Vynn @ Oct 15 2007, 09:20 AM) [snapback]525839[/snapback]</div> Quote:
| | #23 |
| Junior Member Join Date: Aug 2007
Friends: 0 | Sorry if this is a different topic but Does anyone knows how to turn off the "engine maintainance" light off? This is the light that turns on when the Prius need an oil change. Please help Thank you |
| | #24 | |
Friends: 37 | <div class='quotetop'>QUOTE(Errel @ Oct 15 2007, 01:00 PM) [snapback]525913[/snapback]</div> Quote:
Turn on the car and make sure your Odometer is on the main Odometer reading (not trip A or trip turn off the car. Press and hold the ODO button then hit the Power button twice (foot off brake) while continuing to hold the ODO button. Look at the dash display. You'll see dashes where the odometer reading should be, then the dashes will tick away as you hold the odo button, it'll flash and display the correct odometer reading and you're done. Shut down or start and go as you desire.
__________________ Evan E. Fusco, MD "It's a damn poor mind that can only think of one way to spell a word." -Andrew Jackson ![]() ![]() | |
| | #25 |
| Junior Member Join Date: May 2008 Location: Cabin John, Md.
My Car: 2008 Prius Model: N/A Package: #5 Thanks: 1
Friends: 0 | My EBH failed in the spring of 2009. Thanks to this and other posts, I knew what to look for. It turns out the cord was the culprit. But I can't figure out exactly where the cord failed. I suspect it is the female end of the cord that connects to the heater coil. The center socket seems to be missing or very thin or perhaps just burned up. I checked it with a volt meter and the ground connection is not working. I am willing to send the old cable to anyone on Priuschat who wants to do further examination. I bought a second complete EBH kit and replaced the cable and now its back in business. Thanks to you Priusheads for your help and recommendations.
__________________ Lifetime FE: 56.5 mpg or 4.16 l/100 km over 17,089 miles Engine block heater, Coastaletech EV Mode switch, ScanGuage II, Rear bumper guard, Cargo net, Routed the AUX cable out the front drawer of the center console, Rear wiper cover mod Potomac Pedalers Touring Club (PPTC) Mid-Atlantic Off Road Enthusiasts (MORE) |
| | #26 | |
| Prius named PHriuS Join Date: Feb 2008 Location: SE PA
My Car: 2007 Prius Model: Package: #5 Thanks: 12
My EBH has, over the last four months, gradually lost its effectiveness. Current and Resistance measurements read ok, but the scangauge now reads no more than 107 deg F when the car is started in the morning. The heater core appears to be dying. The only other possibility might be loss of heat transfer to the block because the grease has dried up, but this appears unlikely. A search reveals no other complaints of this symptom; by far the broken wire is the typical failure. Has anyone else experienced a failure like this?
__________________ Paul Silenced backup & seatbelt beeps / All door unlock / Shaved rear windshield wiper cover / Tire Pressure 44/42 / Custom front floor mats / Scangauge II / "Prius" license plate frame / Blocked grille / WeatherTech Cargo Liner Mat / HeatShield Sunshade / Custom Hood for MFD / EBH / Prius Hoods Leather Console and Front / Rear Armrest Covers / CE28 Eco Drive Wheels ![]() | |
| | #27 | |
Friends: 37 | Quote:
I'd bet the reason you're seeing lower engine temps is b/c the weather is getting colder. We're probably measuring different things, but I see as high as 145F or so in the summer and as low as 110 in the winter with the EBH. Perhaps you can graph the ambient temp vs ICE temp for a few weeks and see if that's the correlation. I suspect that when the core burns out it'll be catstrophic and an all-or-nothing problem. I do think the dried out thermal transfer grease is a factor, but it seems that that dries out pretty quickly. | |
| | #28 | |
When (or if) we see a dry, warm day again before winter, I'll get under the car and check the grease, the core and the core plug. | |
| | #29 | |
I suggest you simply live with it unless and until it becomes non-functional--or so impaired as to not provide benefit. | |
| | #30 |
Friends: 0 | Yes, that's the reason for asking about your experience with the brittle core plug, to find out how frequently or quickly it breaks down. I am prepared with a replacement kit, just in case. Thanks, Evan, for sharing your knowledge. |
| apparently, block, heater, working |
| Coolant heater vs. block heater..issues | eastender43 | Gen II Prius Technical Discussion | 12 | 05-27-2008 07:01 AM |
| Block Heater stopped working (all else fails b4 toyota) | philmcneal | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 09-26-2007 04:41 PM |
| Block Heater | buzzard bill | Gen II Prius Technical Discussion | 15 | 11-23-2006 11:03 PM |
| EV mod & Block Heater | VaPrius | Gen II Prius Modifications | 6 | 11-22-2005 08:50 PM |
| Block Heater | Lectricar | Gen II Prius Modifications | 5 | 01-07-2005 08:14 PM |
