This is a discussion on Block heater apparently not working within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Up here, we are lucky to get 2 winters out of a plug...
Old 10-19-2009, 08:34 PM   #31
jayman
Default Re: Block heater apparently not working
jayman is offline
Old 10-20-2009, 07:25 AM   #32
PaulHS
Prius named PHriuS
PaulHS's Avatar
What is the failure mode, jayman? Broken wire? Burned out element? Brittle core socket?
TIA
PaulHS is offline
apparently, block, heater, working
Coolant heater vs. block heater..issues eastender43 Gen II Prius Technical Discussion 12 05-27-2008 07:01 AM
Block Heater stopped working (all else fails b4 toyota) philmcneal Gen II Prius Care, Maintenance and Troubleshooting 3 09-26-2007 04:41 PM
Block Heater buzzard bill Gen II Prius Technical Discussion 15 11-23-2006 11:03 PM
EV mod & Block Heater VaPrius Gen II Prius Modifications 6 11-22-2005 08:50 PM
Block Heater Lectricar Gen II Prius Modifications 5 01-07-2005 08:14 PM
