This is a discussion on Non-SKS keyfob works with SKS equipped vehicle? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just bought a used 2007 equipped with the smart key system (SKS). I only have one keyfob, a silver-logo ...
Old 10-13-2007, 07:21 PM   #1
mkb
I just bought a used 2007 equipped with the smart key system (SKS). I only have one keyfob, a silver-logo SKS type. I'd like to get a second keyfob as a spare, and it seems like the non-SKS versions are much less expensive. So my question is, will a non-SKS keyfob work? Obviously not the SKS functions, but will the keyfob remote lock/unlock buttons work, and starting the car with the keyfob placed in the slot?
If so, does it matter if I buy a new factory fresh keyfob or a used one? I understand an already cut key would have to be replaced if I wanted one. Can I register the keyfob to the car myself or do I need a dealer to do it? I've read a couple of the registration "dance" procedures and get the impression people have had mixed results. Any advice?
Thanks!
mkb is offline
Old 10-13-2007, 07:38 PM   #2
cheule
cheule's Avatar
As to the compatibility of the non-sks keyfob to the sks system, I cannot say. But I do know that the used/new aspect doesn't matter. The reason is that each fob has a radio "fingerprint" and the car's computer is programmed to accept commands from that fingerprint. Many think it's the other way around, that the fob is "programmed" to work with the car, but it's not.
I do remember reading a thread on here about compatibility between non sks fob and such a while back, did you search?
Try these threads to get you started:
http://priuschat.com/index.php?showtopic=33875&hl=
http://priuschat.com/index.php?showtopic=27067&hl=
cheule is offline
Is sonar-equipped Prius sold in the US? jcristus Gen II Prius Main Forum 11 11-29-2007 12:53 PM
keyfob seaside man Gen II Prius Main Forum 4 10-05-2006 02:28 AM
Used Keyfob? AlphaTeam Gen II Prius Audio and Electronics 6 03-05-2006 07:55 PM
Can an SKS prius use a non-SKS keyfob? tmorrowus Gen II Prius Main Forum 4 11-08-2005 10:49 PM
Can you use non-HID lights on a HID-equipped Prius? bookrats Gen II Prius Care, Maintenance and Troubleshooting 7 03-26-2004 03:03 PM
