| This is a discussion on Help! 2004 - 150K miles and battery issues within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I'd just keep quite and trade it in on a new one.... |
| | #11 |
Friends: 1 | I'd just keep quite and trade it in on a new one. |
| | #12 |
My Car: 2005 Prius Model: Package: #4 Thanks: 6
Friends: 4 | I think this is an option more people should probably explore. 150k miles is not a bad lifespan for a new vehicle. Someone can certainly put a used or refurb battery in and keep it going for another 50k, 100k, or more miles. Ultimately it just depends on if you're willing to put up with an increasing amount of maintenance issues (like any older/high mileage car). My folks had a head gasket fail in an early 90s Toyota van w/ ~110k miles on the clock. Way out of warranty, and very pricey to fix. Dealer ended up giving them a very generous trade in on a new van, or offered to help with part of the repair cost. Trade in was much better deal so they took it. Dealer should give you at least $9-10k for yours, if not a bit more as a good will gesture. Thats a pretty good chunk out of a new or low mileage used one .... Batteries can last 200-300k miles, but like anything YMMV. Temperatures, SOC excursions, driving style, terrain, initial process variation will all play into how long your particular battery will end up lasting. BTW, I would second consulting another dealer. There is quite a lot of data they can read from the battery down to the individual pack level to determine the health of the battery. However the most likely outcome of that is still, you probably need a new battery. Then your choices are buy new from dealer, buy used from junkyard, or try to have your pack rebuilt by one of several pioneering individuals. rob |
| | #13 |
| AmeriKan Citizen Join Date: Apr 2005 Location: San Diego, CA
My Car: 2005 Prius Model: Package: #1 Thanks: 0
Friends: 7 | |
| | #14 |
| Junior Member Join Date: Sep 2007 Location: Texas
My Car: 2007 Prius Model: Package: #5 Thanks: 0
Friends: 0 | Have you replaced you 12v battery yet? A bad 12v volt battery can drag down you traction battery due to the 12v converter trying to keep dead 12v at 14.7v or what ever the regulator is set to. 4 years is about the service life of a lead acid battery.Jim |
| | #15 |
Friends: 0 | It may not be a battery problem at all. If the ICE has lost compression and is producing less power after 150K miles, the electric side is having to do more work, draining the battery faster. Have them do a compression and leakdown check of the ICE. |
| | #16 |
Friends: 1 | Especially since I don't trust that dealership to change my oil anymore. And don't let them change your cabin air filter, they charge $18 for the labor. Buy the filter and do it yourself in 3 minutes for free. Did Joel (unless they have more than 1 Certified Prius Tech now) look at it or did they give it to some generic mechanic that probably doesn't even know there are 2 batteries in it? After telling the service manager why I would no longer be bringing our Prii there for general maintenance, he said if I did bring it there, only the Prius Tech would touch it. I'm due for my 60K which includes a valve clearance check. Still trying to decide if I trust them or I should try the dealer in St. Albans. I don't think there is any reason to let it idle 3-5 minutes in the mornings before you head out, especially since you have a long downhill before you get to I/89. I have noticed that my car uses the electric motor more when the engine is cold. More than likely, your ICE is just idling while you go down the hill anyway (not that this has ANY bearing on your current issue).
__________________ Bruce Mine: Driftwood '04 BC 24 Sept 2004 - added: mudflaps, door edge guards, side panel moldings, Coastal Tech EV switch, OEM Integrity tires, WeatherTech window deflectors. Last tank - 14 Jul '09: 728.9 miles - MFD MPG: 56.0 Actuals Lifetime: 93,087.3 miles, 48.90 MPG. Wife's: Barcelona '06 #7 May 2006 - added: front mudflaps, Coastal Tech EV switch. OEM Integrity tires. Last tank - 21 May '09: 419.4 miles - MFD MPG: 46.7 Actuals Lifetime: 31571.4 miles, 44.82 MPG. Last edited by bruceha_2000; 02-05-2008 at 04:38 PM. |
| | #17 |
Friends: 0 | |
| | #18 |
| Senior Member Join Date: Dec 2004
My Car: Model: Package: Thanks: 3
Friends: 0 | i had the same issues last summer when i was on a trip to CA. my charge went down lower and my 05' prius seemed to struggle. i was near 100k and needed to do a radiator flush. i've since changed my radiator fluid and haven't had any issues. maybe you can check out your fluids. i'm at 120k and going fine now but i haven't hit the mtns yet. |
| | #19 |
| Junior Member Join Date: Nov 2009 Location: DE
My Car: Other Non-Hybrid Model: N/A Package: N/A Thanks: 0
Friends: 0 | I would definitely start small. Start with getting the 12V battery tested. As stated previously the 12V battery can bring the system down. But as a tech and you saying "they couldn't figure it out" I am thinking they could not duplicate the problem and since it's not throwing any codes they are saying it "ok" I would take the tech on a test drive and show him/her the issue, if its replicated that easily. Again, start small then work to larger issues. Before jumping to the hybrid battery packs. |
| | #20 |
Friends: 10 | hmmm... well, 150,000 miles that is 3000 gallons of gas which is savings of (very conservative estimate) 2000 gallons over a compact car getting 30 mpg (guessing that your weather and driving means only a very small compact will average that)... 2000 gallons saved at same $2.50 is $5,000 you saved by driving the Pri. what other money have you put into it?? brakes?? anything? well, replacing the battery is about a $3,000 job i think... could offer Sandy something for the brand new traction battery she has in her garage. if not that, i believe there are several options for getting a battery cheap... it is unfortunate the battery may seem to be dying, but all cars have something on them that will potentially fail eventually. not but all cars will save you 3 cents a mile while driving them... in 150,000 miles that adds up
__________________ My Blue 2010 : Last tank 541.9 @ 49.48 pump (56.7 MFD) 5.54 CPM, 21 MPH, Lifetime:5442.2 miles 56.5 MPG pump. (62.22 MFD) 4.72 CPM. Summer MPG 57.4 Winter: 49.5 My 2006 SPM: Last tank 376.6 miles @38.21 pump (40.8 MFD) 7.17 cpm winter mpg 49.64 summer mpg 53.41 lifetime: 42,563.5 miles 51.5 mpg pump (52.7 mpg MFD) 5.51 cpm My 2007 Zenn total "fuel cost" $166.58 on "about" 9599.7 miles. 1.74 cents per mile (granted i plug in for free at work!!) My Plate: DUALPWR (Dual Power) |
| 150k, 2004, battery, issues, miles |
