| This is a discussion on Prius AM Radio within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 2005 Prius, package 6. The radio has given me problems from the start, replaced once, and is ... |
Prius AM Radio
| Junior Member Join Date: Mar 2008 Location: Fayetteville, GA
Friends: 0 | I have a 2005 Prius, package 6. The radio has given me problems from the start, replaced once, and is defective again. The AM portion which is all I use only operates normally about 5% of the time. The rest of the time it is so full of static it is unusable. The tech at my dealer told me that it coud not be fixed (still in warranty). I believ there is a bad connection in the system. FM, disc, and tape operate normally. Even using the brake generates noise on AM. Would appreciate any comment on this problem. Essentially I don't have a radio. Thanks, DonG |
| Senior Member Join Date: Feb 2007 Location: Somerset West, South Africa
My Car: 2006 Prius Model: Package: #6 Touring Thanks: 2
Does anybody know where the AM antenna would be or whether it uses a ferrite core coil antenna inside the head unit? The FM antenna is the little beesting on the roof. The AM antenna should be a long loop of wire. What does the static sound like? Constant hiss/swoosh = weak signal Clicking or ticking = electrical noise/spark ignition Buzzing = interference from electrical wires 60/50Hz hum Hum that changes in pitch as you drive/brake = Inverter switching noise Perhaps try a filter on the power supply to the radio head unit. If the head unit has an AM antenna input, try sticking a long wire in there and see if you're reception picks up. | |
Friends: 0 | |
Friends: 0 | The noise is a mishmash. Evidently the electrical system it self is partly to blame as evidenced by the static from the brakes. The fact that at some time it stops only adds to the confusion. The ignition does not appear to be the culprit. I am familiar with ignition static from using ham radios in the past. My problem is with the dealer trying to make it sound normal. Thanks for the input. DonG |
Friends: 0 | It is certainly not normal. My final word: Something isn't grounded to the chassis somewhere. This could be hard to find. |
| Electrical Engineer Join Date: Jan 2007 Location: Camas, WA
Friends: 1 | If under warrantee, go to techs at other dealers to get it fixed. I think the AM and FM antenna should be the same peice on the back of the roof. Maybe the shield on outside of antenna cable is not connected properly. I don't think I have listened to my AM radio for more than a couple seconds at a time when going through the modes to get from FM to CD or back. I think I better listen to it for an exended time and make sure it is working ok. |
My Car: 2001 Prius Model: Package: Pioneer #1 Thanks: 2
Friends: 15 | You may or may not be willing to chase down a bad ground somewhere in the system, but when the Prius AM radio is working correctly it is pretty darn good. I have done a lot of AM DXing to pass the time on late night drives. The antenna is indeed the stick on the roof. The shielding and isolation are indeed impressive, because any other HF radio in there will only hear the Prius' electrical system, up to about 26 MhZ. |
| Member Join Date: Dec 2007 Location: southern Illinois, near St. Louis
If not, tell them to figure out the problem and fix your radio. | |
| prius, radio |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-technical-discussion/43702-prius-am-radio.html | ||||
| Car Stereos - Auto Parts - Autos | This thread | Refback | 08-05-2009 06:39 AM | |
