This is a discussion on I blew up the inverter???? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I've been reading a little more about charging the battery and I'm confused again (sorry). Should I start another thread? ...
LinkBack (7) Thread Tools
Old 09-10-2008, 08:10 AM   #301
NC_Prius
NC_Prius's Avatar
Default Re: I blew up the inverter????
I'm just wondering about the "remove the battery and trickle charge at < 3A for 12 hours" vs jump-starting the car and leaving it in "Ready" mode for an hour. Do you have to keep it < 3A when jump starting? If you use another vehicle as a donor, do you start the donor car as usual to generate the charge? I realize this is what Ginny was doing (w/a charger instead of another vehicle), so -- it's subject to frying the internals. But if I can't wait 12 hrs and AAA comes along to jump the battery, they're just going to jump it like any other battery by starting up their vehicle, etc. Is this a high-risk thing to do?
Lastly, wouldn't *any* car sustain costly electrical damage for reversing the polarity?
NC_Prius is offline
Old 09-10-2008, 08:48 AM   #302
Friends: 14
I wouldn't start the other car. Starting the other car brings another regulator and charging system into the picture. It takes little power to jump start a Prius, so there is no need for the other one to be running.
As for your other question, yes, reversing the polarity of any modern car is going to be expensive. The Prius has more electronics, so there is more potential for damage, but it's a bad thing with any vehicle.
qbee42 is online now
Old 09-10-2008, 08:58 AM   #303
NC_Prius
NC_Prius's Avatar
Thank you, Tom.
So does that mean if I call AAA and they bring a charger instead of using the truck battery to jump the Prius, they need to set the charger to 2.5 amps? Is that enough to at least start the Prius and allow the Prius to recharge itself in "Ready" mode for an hour? Or is that only enough for trickle-charging the battery directly for 12 hours?
If they used the truck battery I'd need to remember to tell them not to start up the vehicle.
As you can tell, I have zero knowledge of electronics ... and thus my overly cautious approach to all this. I *hope* this will be my last question for now, though I'm going to keep reading.
NC_Prius is offline
Old 09-10-2008, 08:59 AM   #304
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 45
Originally Posted by NC_Prius View Post
... Do you have to keep it < 3A when jump starting? If you use another vehicle as a donor, do you start the donor car as usual to generate the charge?
I agree with Tom that it is unnecessary to start the other vehicle when jumpstarting Prius. There's no need to worry about the 3A current limitation since this is a momentary situation, then the Prius system will take over.
If you reverse polarity when jumpstarting another vehicle, you'll destroy the alternator, but this probably costs $500 or less to replace. You might destroy electrical accessories that are not diode-protected - however most systems probably are protected (ECUs, stereo, nav.)
Regarding use of a charger, you definitely want to avoid the "boost" mode where 50A of current is provided to the battery for a short duration. The voltage has to be quite high to force 50A into the battery.
Patrick Wong is online now
Old 09-10-2008, 08:26 PM   #305
Friends: 14
Originally Posted by Patrick Wong View Post
<snip>
Hey PW, I have a 100A charger on my boat. How do you think that would work with the Prius battery?
Actually it would work fine as long as the configuration was set correctly. I have a 100A charger and a 100A alternator. Both are controlled by the same smart regulator system. It uses three step charging, where the initial charge rate is all that the battery can take, subject to a high limit setting. The second stage is the absorption stage, where charging voltage is kept constant by slowly lowering the charging current as the plates recharge deeper and deeper. When the charging rate drops below a low setting, the charger switches to the third and final stage, which is float charging. It maintains the float to keep the battery topped off.
Our boat battery is slightly bigger than the Prius auxiliary battery. If the boat battery were able to charge at the full 100A rate, it would still take over two and a half hours to completely recharge. I never let it discharge past half. Just like the HV battery in the Prius, we try to keep the charge/discharge cycle shallow. It's over ten years old now and still going strong.
Black 2006 package #7
Northern Michigan
Old 09-11-2008, 07:36 AM   #306
jelloslug
It buffed right out!
jelloslug's Avatar
Thank you, Tom.
One thing to keep in mind when thinking about the Prius 12v battery is that it's main function is to power up the computers and accessories before the car is in READY mode. Since it never actually runs a starter it has no need to produce high current so therefor you would never need a charger or jump pack to be set to a high current mode to jump start the car. My salvage 08 came with an extra dead 12v battery (the aftermarket alarm had drained it to 4.2 volts) and it took 3 days with my charger set to 2 amps to recharge it. I charged it with the battery in the car but with the terminals unhooked.
jelloslug is offline
Old 09-11-2008, 09:28 AM   #307
Patrick Wong
DIY Enthusiast
Friends: 45
Originally Posted by jelloslug View Post
... My salvage 08 came with an extra dead 12v battery (the aftermarket alarm had drained it to 4.2 volts) and it took 3 days with my charger set to 2 amps to recharge it...
Glad you could restore that battery to service. Note that some chargers may refuse to deliver charging current to a battery with such low voltage.
Old 10-20-2008, 09:26 PM   #308
donalmilligan089
Chriss do not trust gealer mechanics. I learned more from a manual than the dealer mech.For instance he didn't know that the rear hatc wouldn' open when 12 volt battery was dead. They said I had a bad inverter/converter at a cost of 4100 $. I called Steve at (autobeyours) with the scan info, He said that the parts would be under $450 I took it to him and he found tha other problems would mislead the inexpereinced. He found that the throttle body and a few other things was the problem. Steve has rebuilt 28+ prius's. He is honest and dependable
donalmilligan089 is offline
Old 10-26-2008, 09:34 AM   #309
rpg51
Never mind.
Last edited by rpg51; 10-26-2008 at 12:48 PM. Reason: I posted a dumb comment and didn't want anyone to see it!
rpg51 is offline
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-technical-discussion/48575-i-blew-up-inverter.html
Mi Toyota Prius - Cambio de la batería auxiliar antes de cumplir 3 años - Prius 2004/2005/2006/2007/2008/2009 This thread Refback 08-20-2009 03:33 PM
Mi Toyota Prius - problema con un Prius - varios avisos de error - Prius 2004/2005/2006/2007/2008/2009 This thread Refback 08-15-2009 06:45 PM
Mi Toyota Prius - problema con un Prius - varios avisos de error - Prius 2004/2005/2006/2007/2008/2009 This thread Refback 08-13-2009 02:01 AM
Automotive Battery Charger Repair, Different Types Of Automotive Battery Terminals, Automotive Battery Tester - Peugeottools This thread Refback 03-14-2009 07:07 AM
Ford Focus Wrc Hoods, Ford Focus Wheels, Ford Fore 6000 Dollers - Aftermarketheadlights This thread Refback 03-07-2009 02:36 AM
MacGregorSailors.com &bull; View topic - How many Hybrid (Prius, etc) owners on the Mac board??? This thread Refback 07-21-2008 04:29 PM
MacGregorSailors.com &bull; View topic - How many Hybrid (Prius, etc) owners on the Mac board??? This thread Refback 07-21-2008 11:30 AM
Updated: Silverstars blew... again (Replaced with Phillips X-Treme Power bulbs. See Pg 2) Tideland Prius Gen II Prius Modifications 64 02-10-2010 05:48 PM
Inverter gone bad... tr_blankenship Gen II Prius Care, Maintenance and Troubleshooting 11 10-20-2008 09:43 PM
Low Inverter Coolant nitewolfgtr Gen II Prius Care, Maintenance and Troubleshooting 9 10-20-2008 09:35 PM
Looks like Inverter problems psycho_pete Gen II Prius Technical Discussion 13 06-15-2008 04:34 PM
what's the inverter reservoir? Bob Allen Gen II Prius Care, Maintenance and Troubleshooting 17 07-06-2005 10:27 PM
