This is a discussion on Remote Repair - Stuck "Open" Button within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; After less than 6 months my remote quit working when the "Open" button stuck down. I took it to the ...
Old 06-08-2008, 12:47 PM   #1
showard
Default Remote Repair - Stuck "Open" Button
After less than 6 months my remote quit working when the "Open" button stuck down. I took it to the dealer who said it "couldn't be fixed" and sold me a new one for $348. The other one just broke the same way and I decided to take matters into my own hands.
You can't just use it with the switch stuck down because the car won't start with the button pushed (two things going on at once) and it burns the battery in a few hours. I thought to just disable or remove the switch and still use the transpoder part to be able to start the car.
I saw a post with a picture of a disassembled remote but couldn't figure how to crack the case. Read a post indicating it is glued together. Inserted a knife on the "physical key" side and cracked it open just along that side.
Viola! Releasing the pressure slightly did the trick. The switch popped back up and I have a working remote again for $0. I'm trying the same thing on the other one.
I hoped this might help someone else.
showard is offline
Old 06-08-2008, 01:06 PM   #2
richard schumacher
Destination: Eschaton
Default Re: Remote Repair - Stuck "Open" Button
Thanks!
richard schumacher is offline
Old 06-08-2008, 01:14 PM   #3
V8Cobrakid
Friends: 5
my Open button has worn though. I don't even use it! i used smart start and smart entry!... i'm glad mine hasn't gotten stuck yet. thanks for the heads up.. i can't afford another fob at this time in my life.
V8Cobrakid is offline
Old 06-09-2008, 05:13 PM   #4
tmanson
Geetar-playin' Traveler
tmanson's Avatar
Why wasn't the remote replacement covered under the warranty?
tmanson is offline
Old 06-09-2008, 10:32 PM   #5
hiremichaelreid
Wrnchs OScopes Computers oh my
hiremichaelreid's Avatar
Package: Pioneer #3
Because it's too easy for the dealer to say "User abuse" when a FOB button is broken ?
hiremichaelreid is offline
Old 06-09-2008, 10:45 PM   #6
rfruth
rfruth's Avatar
My Car: Other Hybrid
Friends: 23
would an extra FOB (ya get 2 so 3 total) be a good thing to request @ vehicle purchase time ?
rfruth is offline
Old 06-09-2008, 11:52 PM   #7
wchardin
Advertise Here
wchardin's Avatar
Friends: 25
And if you need a new one, check ebay. You can get one on there for about 100 bucks and then take it into the dealer to get it programmed.
wchardin is offline
Old 06-10-2008, 09:12 AM   #8
But make sure the eBay fob will work with your model of Prius. Some people buy the wrong one.
Old 06-10-2008, 10:13 AM   #9
hiremichaelreid
Package: Pioneer #3
Two should be fine, unless you expect to lose both of them before you can program a new one.
sqeals like a "stuck pig!" Green Cat Gen II Prius Main Forum 6 03-10-2008 04:34 PM
SCARY; gas pedal stuck, dropped into "b" gear spinjunkie53 Gen II Prius Main Forum 1 09-09-2006 01:22 PM
Dashboard Chrome trim ring around the "Power" Button bshef Gen II Prius Modifications 9 05-23-2006 07:38 PM
Fuel gage stuck on "FULL" radtech Gen II Prius Main Forum 7 04-21-2006 09:26 PM
"Only with a Prius" repair costs erinishuman Gen II Prius Main Forum 21 10-18-2004 01:57 PM
