This is a discussion on tb coolant bypass modification results within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; if you are driving in traffic, heatsoak becomes a major issue with the toyota prius, since the engine shuts off ...
Old 07-27-2008, 02:25 PM   #11
statultra
uber-Senior Member
statultra's Avatar
Default Re: tb coolant bypass modification results
if you are driving in traffic, heatsoak becomes a major issue with the toyota prius, since the engine shuts off and the water pump cannot pump the antifreeze out of the engine, thus increasing the temperature of the coolant.
then when the engine fires up the hot coolant gets routed through the cooling system thus increasing the intake air temperatures, although colder air intake temps will yield a richer mixture ( i think ) it really helps in the summer.
the difference in the IAT can be observed after cruising, and driving through traffic where the IAT rarely gets above 110 degrees, versus before where it would range from 120-140 degrees in traffic with an ambient temperature of 93.
as some of you know in florida the rainy season is in full swing, and temperatures drop as much as 20 degrees when a storm is above you. during a 75 degree ambient temperature my IAT was between 85-90 degrees.
now this isnt a totally scientific experiment, but none the less the intake air temps are vastly lower than it was before the modification was completed.
i notice more low end torque in very hot weather.
2005 Toyota Prius Hybrid Package 9
2001 Toyota Prius
2005 Honda Accord Hybrid 3.0 V6
statultra is offline
Old 07-27-2008, 10:14 PM   #12
alanh
How do you measure the torque of the ICE?
alanh is offline
Old 07-28-2008, 03:58 PM   #13
statultra
uber-Senior Member
statultra's Avatar
i could feel the "pulled back into the seat" feeling.
its more noticeable than before, in hot weather I would get bogged down in traffic.also, im pretty sure its not psychological.
Old 07-28-2008, 05:30 PM   #14
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 23
How about two test runs:
0-60 mph - w/o mod
0-60 mph - w mod
If there is more 'umph', the times will tell.
bwilson4web is online now
Old 07-28-2008, 05:40 PM   #15
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 36
0-60 mph - w/o mod
0-60 mph - w mod
The battery SOC would cause issues with this test as well as the fact I do not think there is enough of a HP/TQ difference to have much effect in 0-60' times. My times were all over the place when I raced mine on a certified race track. I ran it 14 times I believe.
F8L is offline
Old 07-30-2008, 09:11 AM   #16
statultra
uber-Senior Member
statultra's Avatar
ill do a 0-60 with modification, whenever i get a chance
im going to do it on my 2001 prius, without mod and with it
Old 07-30-2008, 06:26 PM   #17
MR.K
Is it possible to put a valve to shutoff the water for summer months or when the water goes out of the T/B do it go some where else vita to the rest??
MR.K is offline
Old 07-31-2008, 09:25 PM   #18
V8Cobrakid
Friends: 5
i was going to ask that.. hehe.. a valve. btw, link this to your previous topic. I would like to see pics ( if you included them) hehe
V8Cobrakid is offline
Old 08-01-2008, 12:42 AM   #19
alanh
The reason I asked is that the "seat of the pants" feeling is highly subjective, particularly on a throttle by wire car. The Prius in particular is going to siphon off a variable amount of power depending on the battery state of charge.
alanh is offline
Old 08-01-2008, 02:26 PM   #20
statultra
uber-Senior Member
statultra's Avatar
I noticed the performance advantage specifically
when battery levels were just 2 bars.
Im going to post some 0-60 times taken by GPS, not sure how accurate it is but we will see.
bypass, coolant, modification, results
Bypass filter install phumpher Gen II Prius Modifications 37 10-13-2009 01:17 AM
TB Hot water bypass edthefox5 Gen II Prius Modifications 37 07-23-2008 09:55 PM
HCAC Bypass Valve solace2483 Gen II Prius Care, Maintenance and Troubleshooting 1 07-08-2008 04:59 PM
motion bypass for nav system mckeestown Gen II Prius Audio and Electronics 1 03-13-2008 03:06 PM
2006 GPS bypass answers Three60guy Gen II Prius Main Forum 14 04-14-2006 11:28 AM
