This is a discussion on Hurricane Ike - Floridian - YIKES! Prius as basic generator advice. within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by hobbit Hey KK, are you talking about one of Honda's "inverter" series? What did you do to ...
Old 09-07-2008, 01:49 PM   #11
KK6PD
_ . _ . / _ _ . _
KK6PD's Avatar
Friends: 11
Default Re: Hurricane Ike - Floridian - YIKES! Prius as basic generator advice.
What did you do to convert to propane? [yes, all this is totally
prius-unrelated..]
_H*
Hi there, No this is one of the 1995 era Honda's 6kW. However the propane conversion can be done to ANY gasoline motor. The kit I bought replaces the float bowl on the carb with a solid piece of aluminium that mates up just like the old float bowl!! Also included was a regulator to supply just enough Propane to the motor. The float valve that was in the old carb is unneeded and removed. I mounted the generator and 20lb Propane BBQ tank to a metal cart that I can roll out in a moments notice!!!
I bought all of this the day after the Northridge Earthquake!!!
That was a helluva wake up call!!
Google Propane conversions you should find kits for almost any engine. I looked in the Phone book back then and was able to find a company that sold these kits in about 3 or 4 phone calls!!
Good Luck de Pat KK6PD
KK6PD is offline
Old 09-18-2008, 10:40 AM   #12
[H]ackerK
Geek
Have a look here, some crazy dude make their Prius as part of their UPS!
Son of PriUPS
[H]ackerK is offline
floridia, hurricane, inverter, priups
Prius as a Generator Revisited georgekessel Gen II Prius Modifications 40 12-18-2008 12:28 PM
Yikes – More Prius Damage! effwitt Gen II Prius Main Forum 13 07-30-2008 04:34 PM
Prius and hurricane evacuation Texguy Gen II Prius Main Forum 9 07-09-2008 07:27 PM
The Prius as an Emergency Generator? dave34733 Gen II Prius Main Forum 1 09-10-2007 11:39 PM
Prius Whole House Generator Cheap! Gen II Prius Technical Discussion 2 07-26-2007 06:20 PM
