This is a discussion on MFD changed for no reason within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by EZW1 37 degrees is the temperature universally decided upon where the production of ice on the vehicle ...
Old 10-13-2008, 04:24 PM   #21
Friends: 14
Default Re: MFD changed for no reason
Originally Posted by EZW1 View Post
37 degrees is the temperature universally decided upon where the production of ice on the vehicle or road could occur, depending on relative humidity and speed of the vehicle. Most review mirrors that have the integrated outside temp display will begin to flash a caution to the driver at 37 degrees for this purpose...
Ah, so 37 degrees is an industry standard of sorts. I can only assume that some thought and research went into the number.
Do you know what we call 37 degrees (F)? A good day to go to the beach. That's not a bad temperature around here.
changed, reason
What I'd had changed about the Prius PoulStaugaard Gen II Prius Main Forum 4 12-17-2007 02:06 AM
Can the shifter be changed? JoeyJoeJoShabadoo Jr Gen II Prius Modifications 3 11-21-2007 01:35 PM
Has the server been changed yet? windstrings Gen II Prius Main Forum 2 01-16-2006 09:17 PM
I think I've changed my mind. daniel Gen II Prius Main Forum 12 07-29-2004 02:01 AM
Changed Around a Few Things Danny PriusChat Website Questions 2 03-29-2004 08:30 PM
